Jetson TX2 4 usb not working
I changed the software source and executed sudo apt-get update and sudo apt-get upgrade. Then I restarted tx2. After booting to the desktop, the mouse and keyboard failed, and the mouse light did not light up. I speculated that there was a problem with the USB port. Repeat the above operation after flashing the phone, and the USB port will malfunction again.
Do you use TX2 developer kit? If you use developer kit, please reflash to Jetpack 4.6.4 and check if the issue persists in clean system image. If it occurs in clean system image, probably the TX2 module is physically broken.
