I’ve used Nvidia SDK manager to install Jetpack 5.1.1 along with OS, Devkits, Software components on Jetson Xavier NX Developer Kit - Ubuntu 20.04 version the same way as in NVIDIA SDK Manager Tutorial: Installing Jetson Software Explained - YouTube. However when flashing (Manual mode - NVME) error occured - Could not stat device /dev/nvme0n1 - No such file or directory. Here are the log files for that flash. Did anyone experianced similar problem? Shouldn’t it be resolved by SDK manager?
SDKM_logs_JetPack_5.1.1_(rev._1)_Linux_for_Jetson_Xavier_NX_modules_2023-06-26_00-37-22.zip (285.0 KB)
looks like SDK Manager did not find your SSD.
can you first install the system on a SD card, boot into it, and see if your SSD is correctly detected by the system?
