Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.4.0.7363
other
Host Machine Version
native Ubuntu 18.04
other
I am having trouble locating documentation for the setup of cross-compiling toolchain for the Ubuntu target.
I have a kernel module to build and building on target is failing due to missing kernel sources.
On target, kernel 4.14.150-rt67-tegra is installed but there are no headers available for 4.14, only 4.15.
I install the 4.15 headers but this does not appear to be sufficent.
The kernel module is looking for /lib/module/uname -r/build so it needs the .config et. al. (/usr/src/linux)
I either need a package for the target for kernel src & build files or I need instructions for manual installation of the toolchains and supporting files (which include the kernel src and build files).
Is there a shell file to source to setup the cross build environment?
i.e. What is the procedure to use the cross toolchain to build a kernel module?
