Hi, anyone faces issues with keyboard when using Jetson TX2 flashed by Jetpack 4.2? When I press a key either dozens of them entered or on the other hand I need to push it several times to type a letter, any similar issue and propably a solution? Many thanks.
Hi Mbinnova,
Are you means UART not working? or when you doing init process setup setting, the keyboard not working?
For JetPack-4.2, the first boot up, you need setup init process (like: username, password, timezone…)
init process worked and everything seems to be installed correctly. The issue is that when I type anything using my keyboard it doesn’t work or instead it types one letter several times although I just pushed that key only once. Yes it looks like UART issue. Any solution for that?
hello Mbinnova,
please share your environment setups, may I know which port you’re used to connect a keyboard?
thanks
I am using a USB hub having a mouse and a keyoard connected to it. USB hub is connected to USB 3 port of the board.
Hi Mbinnova,
If you unplug and plug-in USB hub, is it working?
If still not working, please share your UART log. Thanks!
Thank you. It seems we need a replacement for the kit as it stopped working. I will get back to you if we get same issue with the new board.
I am experiencing the same issue with unresponsive keyboard. Did it turn out to be a defective board or just a coincidence?
Thanks,
Ashraf
Hi ashrafwahba,
