N.Miya
1
Hardware Platform: [DRIVE AGX Xavier™ Developer Kit]
Software Version: [DRIVE Software 10]
Host Machine Version: [Ubuntu 18.04]
SDK Manager Version: [Example: 1.0.1.5538]
I want to use LiDAR of VLS128 with the following settings.
fps: 10 (600rpm)
mode: Dual
However, I am connected to a 1Gbps port, but packet loss occurs.
It does not occur when mode is single.
Does AGX deliver 1 Gbps throughput?
VickNV
2
Hi @N.Miya,
Could you provide the detailed steps of how to reproduce the packet loss issue and the related log? Thanks!
N.Miya
4
Hi, @VickNV
I ran the following commands in strongest and dual mode.
/usr/local/driveworks/bin/sample_lidar_replay --protocol=lidar.socket --params=device=VELO_VLS128,ip=192.168.1.201,port=2368,scan-frequency=10
lidar_log.zip (75.0 KB)
thanks!
VickNV
5
Please try if increasing the socket receive buffer settings help. Thanks!
sysctl -w net.core.rmem_max=33554432
sysctl -w net.core.rmem_default=33554432
