Load Maya Connector plug-in failed
I have installed the Maya Connector in Omniverse, and when I start the Maya 2023 the message shows bellow.
And I can’t re-Load the plug-in in Maya plug-in manager.
When I click the Loaded, the error message shows:
Thank you very much.
Maya version: 2023
Omniverse version: 1.5.5
Maya connector version: 103.3.0
OS Windows 10 Pro.
GPU: RTX A4000
GPU Driver version: 516.25
Hello @frank_liu! I’ve reached out to the development team to get more help!
Could you send us a copy of you logs found at?
C:\Users\<USERNAME>\Documents\Omniverse\Maya? It may have information that will help us troubleshoot the issue.
Hey there, when using the omniverse plugin, you have to disable maya’s usd plugin:
If you attempt to reload the OmniverseMayaLoader.mll and still have “mayaUsdPlugin.mll” loaded. That window will still come up.
If mayaUsdPlugin.mll appears like:
mayaUsdPlugin.mll needs to appear like this:
Make sure to relaunch maya after this :-)
Hi @WendyGram and @dm3dxyz ,
Thank you very much for the reply.
I can open the omniverse plug-in after uninstalling the MayaUSD extension and Bifrost extension.
Frank Liu
