MicroUSB Power
I am trying to power my Jetson Nano through the Micro USB using a 5V 3A power bank. However, the Jetson keeps shutting down. I was able to run it using the 4A barrel jack on MAXN. So, it should be able to run on 3A on 5W mode since it is 1A less than 4A. Does the Micro USB limit power to 2A or does it allow more amps to flow?
Thanks in advance!
Just in case the information is needed, I was using a camera from the CSI-Port, a keyboard, and a mouse as peripherals.
rohan,
You may refer here:
Thank you!
