Missing "Create Local Server" Option in Omniverse Nucleus
I’m using NVIDIA Omniverse on a system with the following specs:
GPU: NVIDIA RTX 3060
CPU: Intel Core i9-11900F
RAM: 16 GB
OS: Windows 11 Pro
When accessing the Omniverse Nucleus panel, I only see the options to “Connect to a Server” and “Create Cloud Server.” The option to “Create Local Server” is missing. How can I resolve this issue?
Thanks in advance for your assistance!
Yes you are close. You can either use “Connect to a server” and add “localhost” or you can use the “Add Server” menu item on the left hand menu under Omniverse and again add “localhost”.
However, this should have been done automatically when you installed your localhost Nucleus server. To do this again, you may want to uninstall Nucleus and do it again, using this menu
