Mobile supply
Hi, I can see that you have this:
If you design a carrier board for a vehicle and connect it directly to the 12 V battery, do you need a buck-boost converter to power the Thor module, or can it be connected directly to the battery?
I understand that input protection would be required, but can the 7–20 V input range handle the voltage dips that occur during engine cranking, when the battery voltage may momentarily drop to around 9–11 V?
Or does the module require a stable input voltage to operate reliably?
The DRIVE AGX Thor Developer Kit has different input power requirements than the 7-20V input voltage range for the Jetson Thor module. The DRIVE Dev Kit’s documentation is provided under NDA so I cannot get into further detail on this forum.
For a setup in a vehicle, there would typically be a pre-regulator to:
  • Handle the crank and load dump (overshoot) transients from a car battery
  • Provide a stable voltage to the Jetson Thor carrier board
There would also be considerations for things like reverse polarity protection, EMI, overcurrent protection (OCP), undervoltage protection (UVP) and overvoltage protection (OVP).
Okay thank you for the answer
Not using a DC/DC converter or at least some transient protection between car battery and the Jetson is definitely asking for trouble.
