Hi Y’all, I need a Jetson AGX Orin 64G that is mountable to a DIN rail. I have a control cabinet where I mount all the devices on DIN rails. I have been looking at the 3D CAD file of your server and could not figure out how to mount it into my cabinet. Could you please share suggestions on how to mount it? Or is possible to have a custom DIN rail mountable Jetson AGX Orin 64G from you guys?
Jetson AGX Orin 64G is a module. You have to design a carrier board to access Jetson AGX Orin features and interfaces. Or you can choose Jetson AGX Orin Developer Kit (Jetson AGX Orin 32GB module + carrier board). The mounting holes on the carrier board can be used to mount it on DIN rails. The Developer Kit 3D CAD STEP model can be found in https://developer.nvidia.com/jetson-agx-orin-developer-kit-p3730-3d-cad-step-model.
Thank you for the response. Yes, the Jetson AGX Orin Developer Kit could work for me as well. Actually, I was looking at the same 3D CAD STEP model as your link, but I don’t know if the carrier board you mentioned is already included in this model or not? I would really appreciate it if you could share me a picture to show me how that carrier board look like.
Do you mean to mount that board directly to a DIN rail? If yes, how do we put the cover and the fan for it? And we are working in the rig equipment industry, I don’t think we can just let it open and exposed like that. We would need it to be more safety. Is it possible to get a custom DIN rail mountable server from you guys? Or do you have any thing like a bracket or something that can hold the server and be mounted to a DIN rail?
We only offer a standard developer kit without mechanical accessories. I think you can design your own bracket or box based on current developer kit or carrier board dimensions, then mount it to DIN rail.
