I am trying to flash the tegra A and tegra B using Driveinstall 5.0.5.0b. Among requirements there is:
3. Connect Drive px2 AutoChauffeur device to the internet with an ethernet cable.
I tried to plug an Ethernet cable to the PX2 but I cannot connect to the Internet. I am sure that the Ethernet cable is working and the light on the Ethernet port of the PX2 lights up.
Moreover if I access to the Network settings of Ubuntu I get the following error:
“The system network services are not compatible with this version”
and I don’t have any Wired connection to set, but only a Network proxy.
Regarding “The system network services are not compatible with this version” error you may try following command:
sudo service network-manager restart
I have same issue, I can’t just connect it to internet. could you please give me some advice?
I’m using ethernet cable connection (university internet with no proxy server) with following config:
802.1x security, authentication: PEAP, CA certificate: NONE, Inner authentication: MSCHAPv2
