do you provide support for importing pointcloud?
yes Omniverse does support point cloud.
this might be useful to you: PointClouds — Omniverse Create documentation
Hi
Thank you for your reply
We tried exactly this
with this e57 https://andrev.file.core.windows.net/test001/testPointCloud10Art.e57?sp=rl&st=2022-01-18T19:26:50Z&se=2022-01-19T19:26:50Z&sv=2020-08-04&sig=Cvqx0YJ4NC9f7gRIHgmXdTzdtoZQdUEmd9AlMM0fz%2B4%3D&sr=f
produced from this .ply
https://andrev.file.core.windows.net/test001/testPointCloud10Art.ply?sp=rl&st=2022-01-18T19:27:20Z&se=2022-01-19T19:27:20Z&sv=2020-08-04&sig=RLR%2B6Rdg3yXtmnsIJ4JQUKrn1zLK%2BT7C1945xBYKorY%3D&sr=f
It won’t work.
How do you support the import?
you should ask this question in the Omniverse forum rather Isaac sim, you would get better answers
@ltorabi
I asked Omniverse folks
they said to ask Isaac Sim
so who exactly would support importing the resulting e57? neither?
I will add extra post to their forum, but it won’t work.
@mfoco would you please help out
Sure!
I tried clicking on your link, but I received an XML file reporting an “AuthenticationFailed” code (the link seems to have expired two days ago).
Meanwhile, can you add information about the application and the specific version you’re using? If it’s not Omniverse Create, did you enable the “USD E57 FILE FORMAT LOADER” and “FLOW USD” extensions?
Best,
Marco
@mfoco
Hi, Thank you for your reply.
We tried importing ply via converting it to e57, obj.
updated access urls are attached.
How to convert .ply to othre formats for the import? Could you extend please?
e57
https://andrev.file.core.windows.net/test001/10_withNormals.e57?sp=rl&st=2022-01-22T03:55:17Z&se=2022-01-23T03:55:17Z&sv=2020-08-04&sig=oPdnOr83yU2EKxnRixRIE4Se807ac8dr8ubU1a%2FlVmY%3D&sr=f
obj
https://andrev.file.core.windows.net/test001/10_withNormals.obj?sp=rl&st=2022-01-22T03:55:45Z&se=2022-01-23T03:55:45Z&sv=2020-08-04&sig=61rkDQ4XQxMExuzUwKYtdISt0tk6Vw4NY7nUavQXJZ8%3D&sr=f
ply
https://andrev.file.core.windows.net/test001/10_withNormals.ply?sp=rl&st=2022-01-22T03:56:05Z&se=2022-01-23T03:56:05Z&sv=2020-08-04&sig=KoP5%2FuojMvMfxW4uKAmAytBLS5RC92HBQ3SpanwPN88%3D&sr=f
do you reffer to the pointclouds extension? as in https://docs.omniverse.nvidia.com/app_create/prod_extensions/ext_pointclouds.html ?
could you extend how to create input file e.g. from zed stereolabs, please?
so it can further be imported somehow as a pointcloud?
Unfortunately those link remain active only 24h, and expired last Sunday at 4AM (CET). Can you try a different service? Alternatively, you can use email (@nvidia.com).
Yes, that feature will also enable the extension I mentioned (USD E57…).
About file formats, for now we support e57 only, but even that is not a core component, but developed as a plugin (in the form of a USD file format plugins).
Marco
Hi Marco
Thank you for following up!
The problem with e57 is that e57 we created in meshlab from ply with vertices won’t import. So there are specific requirements for e57 format that we were not able to meet? to be able to import in isaac sim. Could you guide how to transform just recorded .ply file that has vertices but no faces into e57 that will be loadable by isaac sim [omniverse]. In our case it was not an issue to convert .ply to e57 as meshlab does it with no issues. The issue, however, is that isaac sim won’t import resulting e57.
Can you support it?
e57
https://andrev.file.core.windows.net/test001/10_withNormals.e57?sp=rl&st=2022-01-26T08:48:54Z&se=2022-01-27T08:48:54Z&sv=2020-08-04&sig=F3MxYzfNfcTQDl%2FEX05g6wvxIjMYy3kEY0e4n%2BtVAik%3D&sr=f
ply from that e57 was produced
https://andrev.file.core.windows.net/test001/10_withNormals.ply?sp=rl&st=2022-01-26T08:52:32Z&se=2022-01-27T08:52:32Z&sv=2020-08-04&sig=Er7SS3gD9DIV8FrfnSf5QdKQ686NPAe3bNJdSuBvrW0%3D&sr=f
OBJ produced from .ply
https://andrev.file.core.windows.net/test001/10_withNormals.obj?sp=rl&st=2022-01-26T08:53:01Z&se=2022-01-27T08:53:01Z&sv=2020-08-04&sig=3g7O11W31P8cjMWEtVufnafa0Uoc9SjVggdvsPvZuHU%3D&sr=f
@mfoco Hi How is it going?
Is there any update on importing pointcloud to isaac-sim/ omniverse?
In particularly zivid camera .ply or .xyz output?
Thank you
Andre
No immediate plans for NVIDIA to implement import of other point cloud formats at this time. You could potentially try the Adobe file format plugin which has some pointcloud support for PLY and converting it to USD - USD-Fileformat-plugins/ply at main · adobe/USD-Fileformat-plugins · GitHub (Please use Adobe’s GitHub for issues/requests.discussions about their plugin – thanks!).
