No visual feature types specified
I am testing tracking.
Set 1 to useHighPrecisionFeature.
  useColorNames: 0     # Use ColorNames feature
  useHog: 0            # Use Histogram-of-Oriented-Gradient (HOG) feature
  useHighPrecisionFeature: 1   # Use high-precision in feature extraction. Default is [true]
Then enable-past-frame=1 in dstest2_tracker_config.txt.
I have error as
gstnvtracker: Batch processing is ON
gstnvtracker: *Past frame output is OFF*
!![ERROR] No visual feature types specified
An exception occurred. No visual feature types specified
terminate called after throwing an instance of 'std::exception'
  what():  std::exception
Aborted (core dumped)
Why I still have Past frame output is OFF?
What is the cause of error No visual feature types specified?
• DeepStream Version
• TensorRT Version
Xavier
6.0
Package: nvidia-jetpack
Version: 4.5.1-b17
Architecture: arm64
• TensorRT Version
7.1
Depends: nvidia-cuda (= 4.5-b129), nvidia-opencv (= 4.5-b129), nvidia-cudnn8 (= 4.5-b129), nvidia-tensorrt (= 4.5-b129), nvidia-visionworks (= 4.5-b129), nvidia-container (= 4.5-b129), nvidia-vpi (= 4.5-b129), nvidia-l4t-jetson-multimedia-api (>> 32.5-0), nvidia-l4t-jetson-multimedia-api (<< 32.6-0)
Hey customer, which config items did you modified in the tracker config file?
Hi thanks I got it.
I need to select hog or color as features.
