NVIDIA DGX Spark completely unresponsive after power on
Hi everyone,
I have an NVIDIA DGX Spark that is connected to the power cable, but there is no airflow from either the front or the rear, and the display stays completely black.
At first I thought it might be a problem with the monitor or the power adapter, so I swapped both with the ones from my first working Spark. I also tried holding down the power button. The symptoms remain exactly the same: the screen is still black, I can’t feel any suction from the front air intake, and it looks like the machine isn’t powered on at all — it simply won’t boot.
Has anyone encountered this issue before? Any help would be greatly appreciated.
A quick test is to plug in the power brick to something else with a USB-C port and see if it works.
Curious if you have ever tried that ?
I mix and match USB-C power bricks a lot, not tested the Spark ones though with my phone as those bricks always are in use.
