Nvsipl_camera Display Initialization Fails (wfdCreateDevice failed)
DRIVE OS Version: 7.2.5
Issue Description:
We are working on DRIVE AGX Thor and are able to bring up the camera. The camera streams correctly when running without display output. But, when display output is enabled (-d option), nvsipl_camera fails.
Command to Stream
./nvsipl_camera -c AR0827_REV2_96717_BGTM_OFF_CPHY_x2 -m “0x0 0x0 0x0001 0x0” --showfps --disableISP1Output --disableISP2Output -d 1
FYI, GDM is disable.
Error Logs
nvsipl_camera: Register with compositor for output:1 of sensor:8nvsipl_camera: Compositor: Registered output:1 from link:0 of quad:2 as id:33nvsipl_camera: Profiler initialization for output:1 of sensor:8nvsipl_camera: Consumer initialization for output:1 of sensor:8nvsipl_camera: Initializing compositor
nvsipl_camera: Attempting to create WFD device (WFD_DEFAULT_DEVICE_ID=0)nvsipl_camera: ERROR: wfdCreateDevice failed
nvsipl_camera: DRM connector /sys/class/drm/card1-DP-4/status: connectednvsipl_camera: DRM connector /sys/class/drm/card1-DP-2/status: connectednvsipl_camera: DRM connector /sys/class/drm/card1-DP-5/status: connectednvsipl_camera: DRM connector /sys/class/drm/card1-DP-3/status: connectednvsipl_camera: DRM connector /sys/class/drm/card1-DP-1/status: connected
Display connector(s) detected at DRM level, but WFD API not availableThis may indicate WFD is not supported in this configuration (e.g., hypervisor VM)
nvsipl_camera: ERROR: Hint: Run without '-d' option if display output is not requirednvsipl_camera: ERROR: Unable to initialize IDisplayManagernvsipl_camera: ERROR: Compositor: InitDisplay failednvsipl_camera: ERROR: Compositor initialization failed. status: 4
nvsipl_camera: Queue timeoutnvsipl_camera: Queue timeoutnvsipl_camera: Queue timeout
nvsipl_camera: Compositor: Skipping full Deinit (Init did not complete)nvsipl_camera: CompositeHelper: Skipping WfdClearDisplay - display interface not initializednvsipl_camera: CompositeHelper: Skipping ClearVICBuffers - 2D not fully initialized
Dear @anurag.sahu1 ,
Do you see display monitor working after flash? Could you check running sudo rmmod tegradisp_drm before running nvsipl_camera?
Hi Siva,
Thanks with this command “sudo rmmod tegradisp_drm” atleast nvsipl_camera is working with -d 1 option. But on Monitor display we are seeing blank screen, no images.
If we enable the gdm:-
sudo systemctl start gdm
sudo systemctl enable gdm
then normal Nvidia GUI is coming up, but when we disabling the GDM services then camera is not displaying any images.
Mayur
You mean, you notice blank screen on monitor and then when you run nvsipl_camera with -d 1, you notice output on monitor display?
Yes blank screen is coming or say nothing is coming on display monitor when we are running nvsipl_camera with -d 1. So we checked with enabling gdm then we can see Nvidia GUI desktop on our monitor. So our display monitor is working fine and connected properly but when disabling gdm service the display screen goes blank (which is normal earlier also on SDK 7.0.3) , and when we are running nvsipl_camera with -d 1 we are seeing the frames on display monitor but now with SDK 7.2.5 screen is still blank no camera display frames are coming.
I am confused.
What do you mean by it is working? You don’t see any error with nvsipl_camera applicatiom log but no image display on monitor?
Could you please share syslog, application log of nvsipl_camera after unloading tegradisp_drm module.
nvsipl_camera_7_2_5_output_log_with_display.txt (62.7 KB)
syslog_7_2_5_with_display_option.txt (77.3 KB)
Attaching both the logs syslog and camera log.
And yes Siva, we dont see error with nvsipl_camera application now after unloading tegradisp_drm module, but no image is coming on monitor.
Dear @mayur.verma ,
Is it Thor X or Thor U? Could you please share the used bind and flash command?
Hi Siva,
We have Thor U machine.
For bind:
./make/bind_partitions -b p3960-10-sw03 drive_av.linux -p dev_nsr ENABLE_THOR_U=y
For flashing:
./bootburn.py --init_persistent_partitions -b p3960-10-sw03 --board_config /drive/drive-foundation/platform-config/hardware/nvidia/platform/t264/automotive/automotive-platform-configs/driveos_customer_config/nv_platforms/p3960/p3960-10/p3960-10-sw03/board_configs/p3960-10-sw03_thor_u.json
Hi Siva,
I think our binding and flashing commands are proper. Do you see any other issue why we are not getting the frames on our display monitor? From nvspli_camera and syslog file dump also i cant see any display related errors.
Kindly let us know your input, we need to resolve it as soon possible.
Thanks & Regards
Mayur
Hi @SivaRamaKrishnaNV,
Any updated on this? could you please help us on resolving this issue?
Mayur
Dear @mayur.verma ,
I am waiting for internal team feedback. I will update here once I have feedback.
Thanks Siva. Will wait for the updates.
Is the camera module working in DOS 7.0.3?
May I know the camera module ? Assuming used platform config is specific to your camera module
Yes this same camera works on Drive OS 7.0.3.
Entron module.
On that DOS we are disabling gdm first and then issue command to enable stream and output to screen. Same method here on 7.0.3 and 6.0.10 etc.
Is the entron module listed in DRIVE Ecosystem Thor Vendor | NVIDIA Developer ? If not, May I know if you have any other support channel as forum support is limited to cameras in above list.
Hi Siva,
Yes Entron module is already listed on site.
Entron F018A120RM0A onsemi - AR0827 8.3 RGGB 120 LCE - LCA862-100 Contact Sensor Vendor onsemi Entron
Dear @mayur.verma ,
We also notice display issue with nvsipl_camera. Does it block your development? If it is to verify display output, is it ok to use sample_camera from DW?
Could you please provide any update for this topic?
