The Omniverse Client Library has Python bindings that we use in the helloWorld.py
sample. If you run help(omni.client)
you’ll get some nice documentation. Here are the docs for 1.13.19
NAME
omni.client
PACKAGE CONTENTS
_omniclient
FUNCTIONS
break_url(...) method of builtins.PyCapsule instance
break_url(arg0: str) -> omni.client._omniclient.Url
combine_urls(...) method of builtins.PyCapsule instance
combine_urls(arg0: str, arg1: str) -> str
combine_with_base_url(...) method of builtins.PyCapsule instance
combine_with_base_url(arg0: str) -> str
copy(src_url: str, dst_url: str, behavior: omni.client._omniclient.CopyBehavior = CopyBehavior.ERROR_IF_EXISTS) -> omni.client._omniclient.Result
Synchronously copy a thing from ``src_url`` to ``dst_url``. **(Blocking version.)**
The thing can be anything that supports copying (files, folders, etc..)
If both src and dst are on the same server, this is done on the server
Otherwise the file is first downloaded from 'src' then uploaded to 'dst'
Destination folders will be created as needed
Args:
src_url (str): Source url.
dst_url (str): Destination url.
behavior (omni.client.CopyBehavior, default:ERROR_IF_EXISTS): behavior if the destination exists.
Returns:
(omni.client.Result): Result.
copy_async(src_url: str, dst_url: str, behavior: omni.client._omniclient.CopyBehavior = CopyBehavior.ERROR_IF_EXISTS) -> omni.client._omniclient.Result
Asynchronously copy a thing from ``src_url`` to ``dst_url``. **(Coroutine version.)**
Args:
Returns:
copy_with_callback(...) method of builtins.PyCapsule instance
copy_with_callback(src_url: str, dst_url: str, callback: Callable[[omni.client._omniclient.Result], None], behavior: omni.client._omniclient.CopyBehavior = CopyBehavior.ERROR_IF_EXISTS) -> omni.client._omniclient.Request
Asynchronously copy a thing from ``src_url`` to ``dst_url``. **(Callback version.)**
Args:
callback (Callable[omni.client.Result]): Callback to be called with the result.
Returns:
(omni.client.Request): Request object.
create_checkpoint(url: str, comment: str, force: bool = False) -> omni.client._omniclient.Result
Synchronously create a checkpoint. **(Blocking version.)**
Args:
url (str): Url.
comment (str): Comment to associate with the checkpoint
force (bool): Set to true to force creating a checkpoint even if there are no changes
Returns:
(Tuple[omni.client.Result, CheckpointQuery]): Result and query that can be used to refer to this checkpoint
create_checkpoint_async(url: str, comment: str, force: bool = False) -> omni.client._omniclient.Result
Asynchronously create a checkpoint. **(Coroutine version.)**
Args:
url (str): Url.
Returns:
create_checkpoint_with_callback(...) method of builtins.PyCapsule instance
create_checkpoint_with_callback(url: str, comment: str, force: bool = False, callback: Callable[[omni.client._omniclient.Result, str], None]) -> omni.client._omniclient.Request
Asynchronously create a checkpoint. **(Callback version.)**
Args:
url (str): Url.
callback (Callable[omni.client.Result, CheckpointQuery]): Callback to be called with the result.
Returns:
create_folder(url: str) -> omni.client._omniclient.Result
Synchronously create a folder. **(Blocking version.)**
Args:
url (str): Url.
Returns:
create_folder_async(url: str) -> omni.client._omniclient.Result
Asynchronously create a folder. **(Coroutine version.)**
Args:
url (str): Url.
Returns:
create_folder_with_callback(...) method of builtins.PyCapsule instance
create_folder_with_callback(url: str, callback: Callable[[omni.client._omniclient.Result], None]) -> omni.client._omniclient.Request
Asynchronously create a folder. **(Callback version.)**
Args:
url (str): Url.
Returns:
delete(url: str) -> omni.client._omniclient.Result
Synchronously delete something (file, folder, mount, liveFile, channel etc..). **(Blocking version.)**
Args:
url (str): Url.
Returns:
delete_async(url: str) -> omni.client._omniclient.Result
Asynchronously delete something (file, folder, mount, liveFile, channel etc..). **(Coroutine version.)**
Args:
url (str): Url.
Returns:
delete_with_callback(...) method of builtins.PyCapsule instance
delete_with_callback(url: str, callback: Callable[[omni.client._omniclient.Result], None]) -> omni.client._omniclient.Request
Asynchronously delete something (file, folder, mount, liveFile, channel etc..). **(Callback version.)**
Args:
url (str): Url.
Returns:
get_acls(url: str) -> Tuple[omni.client._omniclient.Result, List[omni.client._omniclient.AclEntry]]
Get the ACL's (permissions lists) on a folder/file. **(Blocking version.)**
Args:
url (str): Url.
callback (Callable[omni.client.Result, List[AclEntry]): Callback to be called with the result and current ACLs.
Returns:
get_acls_async(url: str) -> Tuple[omni.client._omniclient.Result, List[omni.client._omniclient.AclEntry]]
"Get the ACL's (permissions lists) on a folder/file. **(Coroutine version.)**
Args:
url (str): Url.
Returns:
get_acls_with_callback(...) method of builtins.PyCapsule instance
get_acls_with_callback(url: str, callback: Callable[[omni.client._omniclient.Result, list], None]) -> omni.client._omniclient.Request
Asynchronously get the ACL's on a folder/file. **(Callback version.)**
Args:
url (str): Url.
Returns:
get_branch_and_checkpoint_from_query(...) method of builtins.PyCapsule instance
get_branch_and_checkpoint_from_query(arg0: str) -> tuple
get_log_level(...) method of builtins.PyCapsule instance
get_log_level(arg0: omni.client._omniclient.LogLevel) -> str
get_server_info(url: str) -> Tuple[omni.client._omniclient.Result, omni.client._omniclient.ServerInfo]
Get server info by url (blocking version).
get_server_info_async(url: str) -> Tuple[omni.client._omniclient.Result, omni.client._omniclient.ServerInfo]
Get server info by url (async version).
get_server_info_with_callback(...) method of builtins.PyCapsule instance
get_server_info_with_callback(arg0: str, arg1: Callable[[omni.client._omniclient.Result, omni.client._omniclient.ServerInfo], None]) -> omni.client._omniclient.Request
get_version(...) method of builtins.PyCapsule instance
get_version() -> str
initialize(...) method of builtins.PyCapsule instance
initialize(version: int = 281530811285523) -> bool
join_channel_with_callback(...) method of builtins.PyCapsule instance
join_channel_with_callback(url: str, callback: Callable[[omni.client._omniclient.Result, omni.client._omniclient.ChannelEvent, str, omni.client._omniclient.Content], None]) -> omni.client._omniclient.Request
Asynchronously join a channel. **(Callback version.)**
Args:
url (str): Url.
callback (Callable[omni.client.Result, omni.client.ChannelEvent, str, omni.client.Content]): Callback to be called with the result.
Returns:
list(url: str) -> Tuple[omni.client._omniclient.Result, Tuple[omni.client._omniclient.ListEntry]]
Synchronously list content of a folder. **(Blocking version.)**
Args:
url (str): Url.
Returns:
(Tuple[Result, Tuple[omni.client.ListEntry]]]): Result and tuple of entries.
list_async(url: str) -> Tuple[omni.client._omniclient.Result, Tuple[omni.client._omniclient.ListEntry]]
Asynchronously list content of a folder. **(Coroutine version.)**
Args:
url (str): Url.
Returns:
list_checkpoints(url: str) -> Tuple[omni.client._omniclient.Result, Tuple[omni.client._omniclient.ListEntry]]
Synchronously list checkpoints of a file. **(Blocking version.)**
Args:
url (str): Url.
Returns:
list_checkpoints_async(url: str) -> Tuple[omni.client._omniclient.Result, Tuple[omni.client._omniclient.ListEntry]]
Asynchronously list checkpoints of a file. **(Coroutine version.)**
Args:
url (str): Url.
Returns:
list_checkpoints_with_callback(...) method of builtins.PyCapsule instance
list_checkpoints_with_callback(url: str, callback: Callable[[omni.client._omniclient.Result, tuple], None]) -> omni.client._omniclient.Request
Asynchronously list checkpoints. **(Callback version.)**
Args:
url (str): Url.
callback (Callable[omni.client.Result, Tuple[omni.client.ListEntry]]): Callback to be called with the result.
Returns:
list_subscribe_with_callback(...) method of builtins.PyCapsule instance
list_subscribe_with_callback(url: str, list_callback: Callable[[omni.client._omniclient.Result, tuple], None], subscribe_callback: Callable[[omni.client._omniclient.Result, omni.client._omniclient.ListEvent, omni.client._omniclient.ListEntry], None]) -> omni.client._omniclient.Subscription
Subscribe to change notifications for a url. **(Callback version.)**
If 'url' is a file, you will only receive information about that file.
If 'url' is a folder, you will additionally receive information about the files inside it.
'`list_callback` is called once with the initial list,then '`subscribe_callback`' may be called multiple times after that as items change.
Args:
url (str): Url.
list_callback(Callable[Result, Tuple[omni.client.ListEntry]]): Callback to be called once with the list.
subscribe_callback(Callable[Result, omni.client.ListEvent, omni.client.ListEntry]): Callback to be called when changes happen.
Returns:
Subscrption holder (`Subscription`).
list_with_callback(...) method of builtins.PyCapsule instance
list_with_callback(url: str, callback: Callable[[omni.client._omniclient.Result, tuple], None]) -> omni.client._omniclient.Request
Asynchronously list content of a folder. **(Callback version.)**
Args:
url (str): Url.
callback(Callable[Result, Tuple[omni.client.ListEntry]]): Callback to be called with the results.
Returns:
lock_with_callback(...) method of builtins.PyCapsule instance
lock_with_callback(arg0: str, arg1: Callable[[omni.client._omniclient.Result], None]) -> omni.client._omniclient.Request
Lock a URL so only this client can modify it. **(Callback version.)**
Args:
url (str): URL.
make_file_url(...) method of builtins.PyCapsule instance
make_file_url(arg0: str) -> str
make_query_from_branch_and_checkpoint(...) method of builtins.PyCapsule instance
make_query_from_branch_and_checkpoint(arg0: str, arg1: int) -> str
make_relative_url(...) method of builtins.PyCapsule instance
make_relative_url(arg0: str, arg1: str) -> str
make_url(...) method of builtins.PyCapsule instance
make_url(scheme: str = None, user: str = None, host: str = None, port: str = None, path: str = None, query: str = None, fragment: str = None) -> str
normalize_url(...) method of builtins.PyCapsule instance
normalize_url(arg0: str) -> str
pop_base_url(...) method of builtins.PyCapsule instance
pop_base_url(arg0: str) -> bool
push_base_url(...) method of builtins.PyCapsule instance
push_base_url(arg0: str) -> None
read_file(url: str) -> Tuple[omni.client._omniclient.Result, str, omni.client._omniclient.Content]
Read a file. **(Blocking version.)**
Args:
url (str): Url.
Returns:
(Tuple[omni.client.Result, str, omni.client.Content]): Result, version and content.
read_file_async(url: str) -> Tuple[omni.client._omniclient.Result, str, omni.client._omniclient.Content]
Asynchronously read a file. **(Coroutine version.)**
Args:
url (str): Url.
Returns:
read_file_with_callback(...) method of builtins.PyCapsule instance
read_file_with_callback(url: str, callback: Callable[[omni.client._omniclient.Result, str, omni.client._omniclient.Content], None]) -> omni.client._omniclient.Request
Asynchronously read a file. **(Callback version.)**
Args:
url (str): Url.
callback (Callable[omni.client.Result, omni.client.Content]): Callback to be called with the result.
Returns:
reconnect(...) method of builtins.PyCapsule instance
reconnect(arg0: str) -> None
Attempt to connect to a specific url
Args:
url (str): Attempt to connect to this url
register_authorize_callback(...) method of builtins.PyCapsule instance
register_authorize_callback(arg0: Callable[[str], object]) -> omni.client._omniclient.Subscription
Set authorize callback.
The callback receives the URL prefix (such as "scheme://server:port") as a parameter and should return either:
None or False: Continue to the next authorize callback (or default authorization method)
True: Abort the connection
String: A token (usually the auth_token provided by get_server_info)
(String, String): A username and password
Args:
callback (Callable[UrlPrefix]): Callback to be called to provide authentication information.
Returns:
(omni.client.Subscription): Subscription Object. Callback will be unregistered once subcription is released.
register_connection_status_callback(...) method of builtins.PyCapsule instance
register_connection_status_callback(arg0: Callable[[str, omni.client._omniclient.ConnectionStatus], None]) -> omni.client._omniclient.Subscription
Register connection status callback.
Args:
callback (Callable[ServerUrl, OmniClientFileStatus]): Callback to be called with the status.
Returns:
register_file_status_callback(...) method of builtins.PyCapsule instance
register_file_status_callback(arg0: Callable[[str, omni.client._omniclient.FileStatus, int], None]) -> omni.client._omniclient.Subscription
Register file status callback.
Args:
callback (Callable[ServerUrl, OmniClientFileStatus, percent]): Callback to be called with the status.
Returns:
send_message_async(join_request_id: int, buffer) -> Tuple[omni.client._omniclient.Result]
Asynchronously send message to channel. **(Coroutine version.)**
Args:
join_request_id (int): Join request id you get from omni.client.join_channel_with_callback.
content (buffer): Content
Returns:
(omni.client.Result): Result object.
send_message_with_callback(...) method of builtins.PyCapsule instance
send_message_with_callback(join_request_id: int, content: buffer, callback: Callable[[omni.client._omniclient.Result], None]) -> omni.client._omniclient.Request
Asynchronously send a message to a channel. **(Callback version.)**
Args:
join_request_id (int): Request id that you get from omni.client.join_channel_with_callback.
Returns:
set_acls(url: str, acls: List[omni.client._omniclient.AclEntry]) -> Tuple[omni.client._omniclient.Result]
Set the ACL's on a folder/file. **(Blocking version.)**
Args:
url (str): Url.
acls (List[AclEntry]): The complete new set of ACLs to put on this file/folder.
Returns:
set_acls_async(url: str, acls: List[omni.client._omniclient.AclEntry]) -> Tuple[omni.client._omniclient.Result]
Set the ACL's on a folder/file. **(Coroutine version.)**
Args:
url (str): Url.
Returns:
set_acls_with_callback(...) method of builtins.PyCapsule instance
set_acls_with_callback(url: str, acls: list, callback: Callable[[omni.client._omniclient.Result], None]) -> omni.client._omniclient.Request
Asynchronously set the ACL's on a folder/file. **(Callback version.)**
Args:
url (str): Url.
acls (List[AclEntry]): the complete new set of ACLs to put on this file/folder.
Returns:
set_log_callback(...) method of builtins.PyCapsule instance
set_log_callback(arg0: Callable[[str, str, omni.client._omniclient.LogLevel, str], None]) -> None
set_log_level(...) method of builtins.PyCapsule instance
set_log_level(arg0: omni.client._omniclient.LogLevel) -> None
shutdown(...) method of builtins.PyCapsule instance
shutdown() -> None
sign_out(...) method of builtins.PyCapsule instance
sign_out(arg0: str) -> None
Sign out specific url connection.
Args:
url (str): Immediately disconnect from the server specified by this URL.
Any outstanding requests will call their callbacks with OmniClientResult.ErrorConnection.
Additionally, clear the saved authentication token so future requests to this server will
trigger re-authentication.
stat(url: str) -> Tuple[omni.client._omniclient.Result, omni.client._omniclient.ListEntry]
Synchronously retrieve information about a file or folder. **(Blocking version.)**
Args:
url (str): Url.
Returns:
(Tuple[Result, omni.client.ListEntry]]): Result and entry.
stat_async(url: str) -> Tuple[omni.client._omniclient.Result, omni.client._omniclient.ListEntry]
Asynchronously retrieve information about a file or folder. **(Coroutine version.)**
Args:
url (str): Url.
Returns:
stat_subscribe_with_callback(...) method of builtins.PyCapsule instance
stat_subscribe_with_callback(url: str, stat_callback: Callable[[omni.client._omniclient.Result, omni.client._omniclient.ListEntry], None], subscribe_callback: Callable[[omni.client._omniclient.Result, omni.client._omniclient.ListEvent, omni.client._omniclient.ListEntry], None]) -> omni.client._omniclient.Subscription
If 'url' is a folder, you will only receive information about that folder.
'`stat_callback` is called once with the initial stat info,then '`subscribe_callback`' may be called multiple times after that the item changes.
Args:
url (str): Url.
stat_callback(Callable[Result, omni.client.ListEntry]): Callback to be called once with the initial stat.
Returns:
stat_with_callback(...) method of builtins.PyCapsule instance
stat_with_callback(url: str, callback: Callable[[omni.client._omniclient.Result, omni.client._omniclient.ListEntry], None]) -> omni.client._omniclient.Request
Asynchronously retrieve information about a file or folder. **(Callback version.)**
Args:
url (str): Url.
callback(Callable[Result, omni.client.ListEntry]): Callback to be called with the results.
Returns:
unlock_with_callback(...) method of builtins.PyCapsule instance
unlock_with_callback(arg0: str, arg1: Callable[[omni.client._omniclient.Result], None]) -> omni.client._omniclient.Request
Unlock a URL so other clients can modify it. **(Callback version.)**
Args:
url (str): URL.
usd_live_get_default_enabled(...) method of builtins.PyCapsule instance
usd_live_get_default_enabled() -> bool
Get default live update mode.
usd_live_get_latest_server_time(...) method of builtins.PyCapsule instance
usd_live_get_latest_server_time(url: str) -> int
Returns the server timestamp of the most recently received message (0 if no messages have been received).
usd_live_get_mode_for_url(...) method of builtins.PyCapsule instance
usd_live_get_mode_for_url(arg0: str) -> omni.client._omniclient.UsdLiveMode
Get live update mode for specific URL.
Args:
url (str): Layer URL.
Returns:
(omni.client.OmniUsdLiveMode): Live update mode.
usd_live_process(...) method of builtins.PyCapsule instance
usd_live_process() -> None
Call this to process live updates received from the server.
usd_live_process_up_to(...) method of builtins.PyCapsule instance
usd_live_process_up_to(url: str, server_time: int) -> None
Same as omni.client.usd_live_process(false) but you can specify a server time to stop processing updates.
Args:
url (str): URL to process.
server_time (int): The server time to stop processing updates.
usd_live_set_default_enabled(...) method of builtins.PyCapsule instance
usd_live_set_default_enabled(enabled: bool) -> None
Live mode means updates from other users are applied to your scene.
This API will change the live update mode for all layers if you don't set
it for each layer.
Args:
enabled (bool): Enable live update mode globally or not.
usd_live_set_mode_for_url(...) method of builtins.PyCapsule instance
usd_live_set_mode_for_url(url: str, mode: omni.client._omniclient.UsdLiveMode) -> None
Set live update mode for each layer.
Args:
mode (omni.client.OmniUsdLiveMode): Set live update mode per layer.
usd_live_wait_for_pending_updates(...) method of builtins.PyCapsule instance
usd_live_wait_for_pending_updates() -> None
Call this to wait for all pending live updates to complete.
write_file(url: str, buffer) -> Tuple[omni.client._omniclient.Result]
Create a new file, overwriting if it already exists. **(Blocking version.)**
Args:
url (str): Url.
Returns:
write_file_async(url: str, buffer) -> Tuple[omni.client._omniclient.Result]
Asynchronously create a new file, overwriting if it already exists. **(Coroutine version.)**
Args:
url (str): Url.
Returns:
write_file_with_callback(...) method of builtins.PyCapsule instance
write_file_with_callback(url: str, content: buffer, callback: Callable[[omni.client._omniclient.Result], None]) -> omni.client._omniclient.Request
Asynchronously create a new file, overwriting if it already exists. **(Callback version.)**
Args:
url (str): Url.
Returns:
DATA
Callable = typing.Callable
List = typing.List
Tuple = typing.Tuple
VERSION = 281530811285523
FILE
samples\_build\target-deps\omni_client_library\release\bindings-python\omni\client\__init__.py
