Omniverse doesn't load big models from nucleus
after successfully setting up my nucleus server I now wanted to try and import different models from Plant Simulation to Omniverse via the Omniverse Connector inside Plant.
While this works with small models (live and export), Omniverse has trouble importing bigger/medium sized project and doesn’t load the textures at all, even crashes when I try to establish a live connection to Plant Sim. Did anyone else have this problem yet?
Best regards, Chris
This connector is unfortunately not created by us at NVIDIA. You would have to check with the connector developer.
You really need to isolate the exact problem. You said it does not load a large model from Nucleus? So first, try saving the usd file from your connector to your local hard drive. Try that, and see if that makes a difference. Do not try to use Nucleus or the LIVE connector. Just old school, export and import.
I am closing this thread at this time, for inactivity. If you respond, I will reopen.
