安装Omniverse Maya(原生)连接器出问题
在maya里面启动插件时报错:
// 错误: file: F:/moddle/maya2024/Maya2023/scripts/others/pluginWin.mel line 316: 找不到指定的模块。
(OmniNative)
请问我该如何解决
I have seen this error before. Have you tried reinstalling the Omniverse Connector for Maya ? What version of Maya are you using ? Can you try re-installing ?
Can you try this ? Turn off ECC for your video card / cards
你好,我重装过很多次,但是都显示这个问题
在我的控制面板里面没有ecc选项
在我的控制面板里面没有ecc选项,
I am not sure why your path is so strange. Normally it would be something like “c:/program files/autodesk/maya/plugins”.
Here is the installation guide for the Maya plugin. Please follow this.
Maya (Native) Connector — Omniverse Connect latest documentation
非常感谢你,我尝试修改安装路径、重新安装、按照指南安装和修改,但是并没有用,我只是普通的初学者,了解到omnivers,感叹其基于usd的便利性和实时性,想融入我的工作流,但是好像并不行,再次感谢您
When you say you have reinstalled many times, do you mean just the Maya extension? Or do you mean actual Maya? Because I honestly thing you should uninstall Maya as well and reinstall in the “default” location, “c:/program files/maya”. Then try the extension again and it might work.
