On a custom based board, I would need to access an I2C peripheral connected to the Orin Nano module pins 98/100, that is to say DP1_AUX_N & DP1_AUX_P.
According to the pinmux config spreadsheet, it should be possible to get these pins the alternate function I2C6 (Address map: 0x31b0000).
However these pins seem to be a bit special (I found related posts, but on different platforms than t23x), and I was not able to get them driven from i2c commands so far. I suspect it requires some specific changes in the device tree.
Thanks for your reply.
No, I will see to check with the spreadsheet. The display function should already be off - any special point you recommend to check about this?
FYI, the spreadsheet is not convenient for Linux users since it the macros do not run properly under LibreOffice.
