Important: Isaac Sim support
Note: For Isaac Sim support, the community is gradually transitioning from this forum to the Isaac Sim GitHub repository so that questions and issues can be tracked, searched, and resolved more efficiently in one place. Whenever possible, please create a GitHub Discussion or Issue there instead of starting a new forum topic.
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo ( GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim ) following the instructions provided on Isaac Lab’s Contributing Guidelines ( Contribution Guidelines — Isaac Lab Documentation ).
√ 6.0.0
5.1.0
5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 24.04
√ Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model: RTX 6000D
- Driver Version: 580.95.05
Topic Description
Detailed Description
When I followed the official link to attempt a minimal deployment of OSMO, I encountered the following issue:
Upon reaching Step 6 in the guide, the following error occurred:
Step 6: Helm Deploy
Deploy the OSMO components using the minimal configuration:
Deploy OSMO Service:
helm upgrade --install osmo-minimal osmo/service \
-f ./osmo_values.yaml \
–namespace osmo-minimal
Could you kindly offer any assistance? I would be most grateful and thank you.
Steps to Reproduce
copy osmo_values.yaml to local directory /home/user
vim osmo_values.yaml to replace
<insert-osmo-image-tag>according to important tips -
(Add more steps as needed)
Error Messages
Error: UPGRADE FAILED: failed to create patch: map: map does not contain declared merge key: name &&
failed to create patch: map: map does not contain declared merge key: name && failed to create patch: map:
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
(Describe any troubleshooting steps you’ve already taken)
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here)
