I am trying to power the Jetson Nano using a power supply that has a 1-2 second ramp up time on the 5V. I have this connected connected to the DC Barrel Jack.
When I turn on the power supply, the Nano does not turn on (no lights nothing). If I use the button power-on then the Jetson runs fine.
Hi, you have figured out the issue already. Generally, the power supply has a delay before rising up 5V. That delay might cause problems to some system. I use a power supply which is connected to the Barrel Jack too, I have to use the power button so as to avoid problems.
Or you can power up the supply first, wait for a few seconds and then plug it into the Barrel Jack.
