We do support Maya 2020.2 so I do expect it to install cleanly. Let’s see if we can see what’s happening. I have a couple questions to help me narrow down what’s happening…
Is there more information in your MayaPlugin.log? You can find it in your user documents folder /Omnvierse/Maya
Lets see if there is a plug in conflict. Do you have any other plugin currently installed on Maya 2020.2? If so can you toggle those off before trying to load the Omniverse plugin?
I also use Maya 2020.2 and it loads well. There could be some DLL conflicts with other third party plug-in in Maya 2020. Maybe you can try to not load some other third party plug-ins and try again.
Because it loads well with Maya 2019, it could be some plugin special in Maya 2020.2.
Thanks for the pointers. Turns out there was a conflict with another plugin, and that plugin was Maya’s own USD plugin. If I uninstall that then I can load the Omniverse plugin and USD import works ok.
The Maya plugin does not ship with Maya, I believe I got it from here:
I guess this means I no longer need that Maya github plugin? Does the Omniverse plugin build on top of that plugin, which is why it has the name conflict?
I have the same issue when loading the omniverse maya connector plugin. I don’t have the USD plugin installed, and I uninstalled (unload) all other plugins (even the default ones), still failing the initialization of the omniverse plugin in maya. My maya version is 2020.4
