Nvidia jetson nano 2gb doesnt start. Production mode: infused. I tried to overwrite the sdcard image required for the 2gb version - unsuccessfully. Linux host x64 can’t detect nvidia in recovery mode, so I can’t flash it through sdk manager. I recorded the logs from the uart. Please help me solve this problem
logs.txt (24.1 KB)
[0002.515] device_query_partition_size: failed to open partition spiflash0:USP !
[0002.522] USP partition read failed!
[0002.526] blob_init: blob-partition USP header read failed
[0002.531] android_boot Unable to update recovery partition
[0002.537] kfs_getpartname: name = LNX
[0002.540] Loading kernel from LNX
[0002.550] Found 19 BFS partitions in “spiflash0”
[0002.866] Failed to validate boot-image
[0002.870] Failed while loading kernel and ramdisk images
[0002.875] Failed to boot Android
[0002.878] starting fastboot mode
[0002.883] fastboot cmd_init done.
[0002.886] platform does not support off-mode-charge
[0002.891] usbdcd_init Initialize USBF driver
[0002.895] usbdcd_phy_open oscfreq = 5
[0002.904] usbdcd_start Start the initialized controller
[0002.910] get_fastboot-- suspend –
_[0002.914] instructions: Error -2 finding instructions in /chosen
[0002.920] display_console_clear: No display init
[0002.924] [fastboot_init]Error in fastboot menu
[0002.929] Continue booting …
[0002.932]
[0002.933] display_console_clear: No display init
[0002.937] [menu_handle_on_select]Error in printing the selected option
[0002.944] kfs_getpartname: name = LNX
[0002.948] Loading kernel from LNX
[0002.957] block-device “spiflash0:BCT” already registered
[0002.962] block-device “spiflash0:NVC” already registered
[0002.967] block-device “spiflash0:PT” already registered
[0002.973] block-device “spiflash0:NVC_R” already registered
[0002.978] block-device “spiflash0:TBC” already registered
[0002.984] block-device “spiflash0:RP1” already registered
[0002.989] block-device “spiflash0:EBT” already registered
[0002.994] block-device “spiflash0:WB0” already registered
When usb is connected in recovery mode, the x64 linux system cannot recognize nvidia jetson nano
