I used Omniverse for quite a long time, but today one of my desktop just suddenly not work. No matter which usd file I open, it shows nothing! and this happens at every apps I installed, Create,Machinima, etc.
Belows is the screen shot and logs
kit_20230228_090645.log (1.2 MB)
oh, blindness! I hope they can solve this quicly for you…
Oh no! Let me get the devs to look into this. What is your current system environment: Operating System & GPU / GPU Driver. Also, could you send me a copy of your USD file? You can attach it here or email me at: omniversecommunity@nvidia-omniverse.atlassian.net
Hello @terryzhv83! The dev team mentioned that we had an IsaacSim user have the same issue as you. They had to “delete user json” which resolved their issue. If that doesn’t work, you can try flushing your cache folder and data folder. Let me know if this helps you out!
For me, Create has been rendering and loading wrong extensions
I figured out I had to call--reset-userto get it fixed.
I am submitting this to the dev team as a bug to get fixed asap!
A development ticket was created from this post. OM-84611: Render nothing at all
Hi Wendy, thanks for the reply, I will verify your workaround later.
Hi, Wendy, adding the --reset-user at the startup bash, it works! Thank you!
