While rendering a sequence in Create I’m getting random parts of the next frame burning into the frame which is being rendered if that makes sense. Here is an example:
As you can see the first frame has parts of the next frame embedded into it. Also, it’s random, when running the sequence again it never occurs on the same frames as before.
Any help would be much appreciated!
