I use a robot controlled with LulaKinematicsSolver and a camera created with replicator. If I use the function omni.replicator.core.orchestrator.step(), then the robot does not move if I apply an action.
If I do not the replicator step, then the robot moves as wished.
Does someone know how works exactly the function step from the replicator and its impact ?
How does it defer from the World step function ?
the replicator step function ends up calling omni.kit.app.get_app().update() in order to simulate the world you would need to call world.step() as well. The offline_pose_estimation tutorial is a good example showing how one can use replicator’s step function together with isaac sim’s world step.
UPDATE:
using rep.orchestrator.step(pause_timeline=False) will make sure the simulation will not get paused, or calling timeline.get_timeline_interface().play() again after the step function.
