I run TX2 tegra multimedia API sample 11_camera_object_identification with command line:./camera_caffe -width 1920 -height 1080 -lib opencv_consumer_lib/libopencv_consumer.so -model $HOME/Work/caffe/caffe-master/models/bvlc_reference_caffenet/deploy.prototxt -trained $HOME/Work/caffe/caffe-master/models/bvlc_reference_caffenet/bvlc_reference_caffenet.caffemodel -mean $HOME/Work/caffe/caffe-master/data/ilsvrc12/imagenet_mean.binaryproto -label $HOME/Work/caffe/caffe-master/data/ilsvrc12/synset_words.txt according to README. While it outputs that:
LoadOverridesFile: looking for override file [/Calib/camera_override.isp] 1/16LoadOverridesFile: looking for override file [/data/nvcam/settings/camera_overrides.isp] 2/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16LoadOverridesFile: looking for override file [/data/nvcam/camera_overrides.isp] 5/16LoadOverridesFile: looking for override file [/data/nvcam/settings/e3326_front_P5V27C.isp] 6/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/e3326_front_P5V27C.isp] 7/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/e3326_front_P5V27C.isp] 8/16---- imager: No override file found. ----
LoadOverridesFile: looking for override file [/data/nvcam/settings/usb@video1.isp] 6/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/usb@video1.isp] 7/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/usb@video1.isp] 8/16---- imager: No override file found. ----
initializeDevNode: Failed to open dev node '/dev/camera/video1'; No such file or directory, trying alternate default location
(NvOdmDevice) Error BadParameter: Control 10094858 not found (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function findControlById(), line 1518)
(NvOdmDevice) Error BadParameter: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function getControlRange(), line 306)
initialize: focus query failed
(Argus) Error InvalidState: Scf SensorModeType 0 not found (in src/common/ScfTranslate.cpp, function fromNvMMSensorModeType(), line 322)
LoadOverridesFile: looking for override file [/data/nvcam/settings/usb@video2.isp] 6/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/usb@video2.isp] 7/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/usb@video2.isp] 8/16---- imager: No override file found. ----
initializeDevNode: Failed to open dev node '/dev/camera/video2'; No such file or directory, trying alternate default location
PRODUCER: Creating output stream
PRODUCER: Launching consumer thread
Failed to query video capabilities: Inappropriate ioctl for device
libv4l2_nvvidconv (0):(774) (INFO) : Allocating (10) OUTPUT PLANE BUFFERS Layout=1
libv4l2_nvvidconv (0):(790) (INFO) : Allocating (10) CAPTURE PLANE BUFFERS Layout=0
create vidoe converter return true
CONSUMER: Waiting until producer is connected...
PRODUCER: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
WARNING: Logging before InitGoogleLogging() is written to STDERR
Video1 and video2 are my external USB cameras whose location are /dev/video1 and /dev/video2. While it outputs that “Failed to open dev node ‘/dev/camera/video2’”. Do the samples can only identifie the on-board camera? How to identifie external USB cameras? Could someone give me some suggestions? Thank you in advance!
