However, while running installation on the TX2, OpenCV failed with
01:06:46 INFO: OpenCV on Target: conflicting packages - not installing libopencv-dev
01:06:46 INFO: OpenCV on Target: Errors were encountered while processing:
01:06:46 INFO: OpenCV on Target: /opt/nvidia/deb_repos/OpenCV-4.1.1-2-gd5a58aa75-aarch64-dev.deb
01:06:46 INFO: OpenCV on Target: Unhandled error when running sudo dpkg -i /opt/nvidia/deb_repos/OpenCV-4.1.1-2-gd5a58aa75-aarch64-dev.deb
01:06:46 INFO: OpenCV on Target: [ Package Install Finished with Error ]
01:06:46 INFO: OpenCV on Target: [ NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP Install took 48s ]
01:06:46 ERROR: OpenCV on Target: [error]: dpkg install on target failed; [exec_command]: safe_apt_install “sudo dpkg -i /opt/nvidia/deb_repos/OpenCV-4.1.1-2-gd5a58aa75-aarch64-dev.deb” 5; sleep 5; ; [deb_path]: /home/xuesu/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-dev.deb
01:06:46 ERROR: OpenCV on Target: command terminated with error
01:06:46 SUMMARY: OpenCV on Target: Failed to install debian package [target]
And VPI failed with
00:59:22 INFO: VPI on Target: verifying checksum of /home/xuesu/Downloads/nvidia/sdkm_downloads/vpi-lib-0.4.4-cuda10-aarch64-l4t.deb
00:59:22 INFO: VPI on Target: verifying checksum of /home/xuesu/Downloads/nvidia/sdkm_downloads/vpi-dev-0.4.4-cuda10-aarch64-l4t.deb
00:59:22 INFO: VPI on Target: verifying checksum of /home/xuesu/Downloads/nvidia/sdkm_downloads/vpi-samples-0.4.4-cuda10-aarch64-l4t.deb
00:59:22 INFO: VPI on Target: Found file /home/xuesu/Downloads/nvidia/sdkm_downloads/vpi-dev-0.4.4-cuda10-aarch64-l4t.deb with correct checksum, skip downloading.
00:59:23 INFO: VPI on Target: Found file /home/xuesu/Downloads/nvidia/sdkm_downloads/vpi-samples-0.4.4-cuda10-aarch64-l4t.deb with correct checksum, skip downloading.
00:59:23 INFO: VPI on Target: Found file /home/xuesu/Downloads/nvidia/sdkm_downloads/vpi-lib-0.4.4-cuda10-aarch64-l4t.deb with correct checksum, skip downloading.
01:06:46 SUMMARY: VPI on Target: Depends on failed component
Anyway to at least fix OpenCV?
