I am using a linux machine to install jetpack 4.6 and SDK components on Nvidia AGX. I have to use a proxy for my internet connection and that is the root of my problem.
I have set the proxy for SDK manager. I have successfully flashed AGX device with the operating system. I have created my user profile on AGX device and logged into it. I have setup proxy settings for both the host and AGX devices correctly so that I can run apt commands and they work. I have also installed some custom CA-certificates for internet connection ran dpkg-reconfigure and all. I can ping 192.168.55.1 from host device and 192.168.55.100 from AGX device.
The problem occurs when the SDK manager moves on to installing SDK Components. It does three things:
Check Disk Space
Check Internet Connection
Check Access to APT repository
It checks out on Disk and APT steps but it fails on Check Internet Connection step outputing an error message saying: “Internet connection.: Internet connection check failure (ping -c 3 nvidia.com).”
Ping doesn’t work with proxy and my company won’t let any connection without proxy.
What can I do?
Thanks,
Cem
