Self-defined carrier board for Xavier about auto power on
Here i have some question about auto power on for xavier in self-defined carrier board
1, without MCU and power button, how can i achieve the auto power on like TX2 ?(In tx2 design, i connect A49 CHARGER_PRSNT# to GND)
2, I want to use 12V as the SYS_VIN_HV power, how much current should i design for it ?
3, As similar above, how much current should i design for SYS_VIN_MV ?
Q1 please refer to the OEM DG section “4.4.1 Power-On - No MCU”, ACOK_L pulled to GND.
https://developer.nvidia.com/embedded/dlc/jetson-xavier-oem-product-designguide
Q2 SYS_VIN_HV power = 20V*5.4A = 108W, when 12V, current = 108W/12V = 9A.
Q3 same calc way.
I have got you replay, and i am now analyzing the OEM DG section “4.4.1 Power-On - No MCU”.
And if I use the the mcu EFM8SB10F8G-A the same as NVIDIA JETSON AGX XAVIER DEVELOPER KIT, can NVIDIA provide the code for MCU?
Do you have detail analysis about OEM DG section “4.4.1 Power-On - No MCU”, and in that section it says the way to achieve the Auto-power on, But the timing sequence is not described, and I cannot fully understand it.
Can you provide the detail and help me?
You can also refer to reference schematic for more info about No MCU design. All doc we can provide are in DLC, if you have questions, please describe in detail.
