I designed the self-made carrier board with reference to the P3449_B01 schematic diagram, which successfully entered the system and displayed the login interface.
The problem: the USB part schematic design is exactly the same as the P3449_B01, but now USB is not available.
Design details:
- The chip used is RTS5411S, where GPIO0 (USB_VBUS_EN0) has been pulled down to ground, and the voltage is 0V.
2, DSP_PWR1/2/3/4 output is 0V, so I use low level enabled USB_VBUS switch chip, so the USB power supply is normal, now there is 5V voltage.
Symptom: After the USB mouse is plugged in, the light at the bottom will flash for a moment and then go out, and the USB cannot be used.
Question:
1、I found the above picture through the forum. May I ask that after modifying the firmware according to the requirements in the picture, it should only modify the output enable voltage of DSP_PWR, and there will be no other effects?
2、What should I do if I need my USB to work? (I’m sure the current hardware design is the same as the official board)
3、If I am not using any USB HUB chip, can I connect the USBA pin directly to the USB 3.x port for use?
