TX2 Jetpack could not working
Hello,when I downloaded the JetPack-L4T-3.1-linux-x64.run ,I used the orders
chmod +x JetPack-L4T-3.1-linux-x64.run
./JetPack-L4T-3.1-linux-x64.run
but I could not get into the interface that I can downing CUDA toolkit,opencv for Tegra and so on,
In the JetPack L4T Component Manager, it appears that downloading update lock.
Now I could not flash the OS .
Hi lihuayang6,
Please check your network is workable.
Also check system requirement first:
https://docs.nvidia.com/jetpack-l4t/content/developertools/mobile/jetpack/l4t/3.2/install.htm?tocpath=_____3#System_Requirements
Hello carolyuu ,
I have flashed OS before,and I am sure that network is workable and system requirement is good.
I think it is something wrong with the network!
Hi lihuayang6,
There are no issue on my side, I can run JetPack and download package from component manager.
Please download JetPack and try again.
Let me know your result. Thanks!
JetPack-3.2: https://developer.nvidia.com/embedded/dlc/jetpack-l4t-3_2-ga
Hello carolyuu
I have the same problem.
run the command ./JetPack-L4T-3.2-linux-x64.run
cann’t download jetpack
Hi 458245412,
We have internal bug to tracking this issue.
The JetPack can’t download in China.
I will update to you when issue update, sorry for inconvenience.
Oh,We look forward to solving this issue as soon as possible.
Hello carolyuu
I am Chinese,Jetpack does not work else,hope you to solve the problem as soon as possible!
Thank you !
hello carolyuu, I also can not download packages from component manager, we looking forward you to fix it as soon as possible,thanks!
Hello carolyuu
When will the bug be solved?
Thank you!
Hi 458245412, zhanbo86 and lihuayang6,
Our China team confirmed they can download Jetpeck 3.2 from website and installed on Jetson TX2 successfully.
Please help to get it a try.
however, I tried several times today, the update problem still exists.
Try clearing the browser cache.
Hello,linuxdev
Today, I have tried several times. The problem still exists.
Could you tell me how to solve it.
Thank you!
hi, lihuayang6
What website did you access to download jetpack? developer.nvidia.com or something else?
i downloaded the jeckapck3.2 via ADSL network in china. please try again.
Hello, marcm_mk
yes,it is developer.nvidia.com.And now the problem is not solved,so I use the image to flash OS.
I do not know what the problem is , I want to know if there’s the same problem I met.
hi, lihuayang6
so, it is no problem to download the jetpack3.2 from website developer.nvidia.com, right?
Hi ,marcm_mk
yes,I could download jetpack 3.2 successfully.
hi, lihuayang6
I flashed 28.1 to TX2 by jeckpack3.2, the whole process was successful.
please indicate what exactly problem you get.
is it downloading issue by jeckpack3.2, or flashing issue in TX2?
