I god my debug info attached as a .txt file . Can you help to take a look?
I’m NOT sure about this line [0000.629] I> Failed to read CVB eeprom data @ AE.
Oh, BTW, this time, I did flash Xavier AGXusing SDK Manager on Ubuntu 18.04. But, I did insert a TF card inside Xavier AGX. It looks before flashing, there is NOWHERE to let me select flash into EMMC or flash into TF card??
I feel you still didn’t understand my question here according to your reply…
Every board in this “Jetson AGX Xavier” forum is using Xavier AGX… but not every of them is devkit…
Thus, your reply “this is a Xavier AGX for sure” is pointless. I never doubt that at all.
The keyword here is “devkit”… My question is are you using “devkit” or not. Only the carrier board/base board released by NVIDIA is devkit. Other kinds of carrier board are custom board…
The point of this question is because devkit won’t have eeprom read problem…
Also, your understanding to second question is also wrong…
Secondly: are you sugguesting while I was flashing, it’s better to take out the TF/SD card while flashing? Let’s try it…
No, I am not suggesting to take out SD card. My point is this does not matter the sdcard is plugged or not… Our flash tool does not support to flash sdcard… You may only flash nvme/usb and emmc. If you don’t choose to flash external drive (nvme/usb), then by default it will flash to emmc…
I purchased my kit from NVIDIA. On the back of the kit, it’s clearly written: NVIDIA P2972. I believe there must some other way to print out my board’s info while this board connected to my host computer ??
Since I’m now using SDK Manager under Ubuntu 18.04 for flashing, I believe ths system has been successfully flashed into EMMC.
I remember a couple of years ago, I was still able to use command line for flashing ? I mean: there must be a way for rebuild our own system from source, just by using all source provided NVIDIA Jetson Linux, and flash our own drivers into the system. I clearly did that 2/3 years ago. However, now, I cannot deal with this Jetpack 5.0.2 …Hmmm
As @user100090 said, both jp4.x or 5.x can flash the board manually.
Actually, I only want to deal with your boot hang issue. Could you full flash your board again and share me the serial console log? Please make sure you didn’t make any customization to the software.
