I’m using drive Xavier with ubuntu. The drive has been flashed with sdkmanager. All applications are closed after locking for around half an hour and re-login. The Xorg crash error also happens and “system problem detected” is reported.
The messages in .xsession-errors are:
Xsession: X session started for nvidia at Thu Aug 22 12:53:23 CST 2019
localuser:nvidia being added to access control list
openConnection: connect: No such file or directory
cannot connect to brltty at :0
upstart: Failed to spawn window-stack-bridge main process: unable to execute: No such file or directory
upstart: update-notifier-crash (/var/crash/_usr_lib_xorg_Xorg.0.crash) main process (10992) terminated with status 1
Is this error immediately after flashing DRIVE™ Software 9.0?
If yes, could you please upload the full logs available at below locations for your topic?
~/.nvsdkm/sdkm.log
~/.nvsdkm/logs
Or is it an error that occurred while doing something? Thanks.
Drive Software 9.0 was flashed three days ago. It seems not to be a problem with Drive Software since before flashing, this problem also occurred with the preinstalled Ubuntu if i remember correctly. I did nothing except that a web browser was opened. Additionally, after locked for a while, i need to login twice with “nvidia” user(i.e. looping twice in the login page).
Anyway, the logs are uploaded. I guess i may need to do a full re-flashing to see what the problem is. Thanks.
