Can I use below link to use ros2 on jetson nano(R32.6.1 with jetpack 4.6).
Thank you.
Thank you.
Hi @forumuser, the ROS2 containers from https://github.com/dusty-nv/jetson-containers are more recently updated/maintained than the ones from that repo are. That ros2_jetson repo is mainly intended as a github.io page that lists ROS2 resources for Jetson: ros2-jetson
