It is attached below:
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.38-rt25-tegra (buildbrain@mobile-u64-290) (gcc version 4.9.2 (GCC) ) #1 SMP PREEMPT RT Mon Jan 8 01:00:48 PST 2018
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7fe00000
[ 0.000000] OF: fdt: - 100000000 , 15d200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003110000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node generic_carveout, compatible id nvidia,generic_carveout
[ 0.000000] cma: Reserved 256 MiB at 0x00000000c3000000
[ 0.000000] On node 0 totalpages: 1770240
[ 0.000000] DMA zone: 5316 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 340224 pages, LIFO batch:31
[ 0.000000] Normal zone: 22344 pages used for memmap
[ 0.000000] Normal zone: 1430016 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc1dd043000 s56192 r8192 d29824 u94208
[ 0.000000] pcpu-alloc: s56192 r8192 d29824 u94208 alloc=23*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1742580
[ 0.000000] Kernel command line: root=/dev/mmcblk0p3 earlycon=uart8250,mmio32,0x03110000 console=ttyS0,115200n8 no_console_suspend=1 tegra_keep_boot_clocks cma=268435456 tegraid=18.1.2.0.0 ratchet_status=0x0 uid=1642d98421c00000015040080 earlycon=uart8250,mmio32,0x03110000 bl_prof_dataptr=65536@0x25e460000
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 12, 16777216 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 6635056K/7080960K available (12414K kernel code, 2284K rwdata, 5176K rodata, 4736K init, 829K bss, 183760K reserved, 262144K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008ca0000 ( 12416 KB)
[ 0.000000] .rodata : 0xffffff8008ca0000 - 0xffffff80091c0000 ( 5248 KB)
[ 0.000000] .init : 0xffffff80091c0000 - 0xffffff8009660000 ( 4736 KB)
[ 0.000000] .data : 0xffffff8009660000 - 0xffffff800989b008 ( 2285 KB)
[ 0.000000] .bss : 0xffffff800989b008 - 0xffffff800996a528 ( 830 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf07748000 ( 119 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1dd200000 ( 7634 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] **********************************************************
[ 0.000000] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 0.000000] ** **
[ 0.000000] ** trace_printk() being used. Allocating extra memory. **
[ 0.000000] ** **
[ 0.000000] ** This means that this is a DEBUG kernel and it is **
[ 0.000000] ** unsafe for production use. **
[ 0.000000] ** **
[ 0.000000] ** If you see this message and you are not debugging **
[ 0.000000] ** the kernel, report this immediately to your vendor! **
[ 0.000000] ** **
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000001] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000194] Console: colour dummy device 80x25
[ 0.365522] kmemleak: Kernel memory leak detector disabled
[ 0.365530] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.365532] pid_max: default: 32768 minimum: 301
[ 0.365585] Security Framework initialized
[ 0.365614] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.365617] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.367268] sched-energy: Sched-energy-costs installed from DT
[ 0.410018] ASID allocator initialised with 65536 entries
[ 0.462674] tegra-id: chipid=21817.
[ 0.462922] tegra-id: opt_subrevision=1.
[ 0.466723] Tegra Revision: A02p SKU: 144 CPU Process: 0 SoC Process: 0
[ 0.473330] DTS File Name: /dvs/git/dirty/git-master_modular/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/vcm/kernel-dts/tegra186-vcm31-p3407-0000-a00-00-base-vm.dts
[ 0.491779] DTB Build time: Dec 2 2017 10:54:13
[ 0.557076] CPU1: Booted secondary processor [4e0f0030]
[ 0.601077] CPU2: Booted secondary processor [4e0f0030]
[ 0.645043] CPU3: Booted secondary processor [411fd073]
[ 0.689126] CPU4: Booted secondary processor [411fd073]
[ 0.733220] CPU5: Booted secondary processor [411fd073]
[ 0.733287] Brought up 6 CPUs
[ 0.759081] SMP: Total of 6 processors activated.
[ 0.763785] CPU features: detected feature: 32-bit EL0 Support
[ 0.769877] CPU: All CPU(s) started at EL1
[ 0.774622] devtmpfs: initialized
[ 0.786247] Initilizing CustomIPI irq domain
[ 0.787297] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.796986] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.806889] pinctrl core: initialized pinctrl subsystem
[ 0.809278] regulator-dummy: no parameters
[ 0.813105] Initializing plugin-manager
[ 0.816893] Plugin module not found
[ 0.820297] Plugin-manager not available
[ 0.824396] Adding domain adsp-pd to PM domain ape-pd
[ 0.830218] tegra_hv: adding ivc0: rx_base=ffffff8009a00000 tx_base = ffffff8009a08000 size=8000 irq = 5 (321)
[ 0.839163] tegra_hv: added ivc0
[ 0.842504] tegra_hv: adding ivc1: rx_base=ffffff8009a10000 tx_base = ffffff8009a18000 size=8000 irq = 6 (322)
[ 0.852466] tegra_hv: added ivc1
[ 0.855651] tegra_hv: adding ivc2: rx_base=ffffff8009a20000 tx_base = ffffff8009a28000 size=8000 irq = 7 (323)
[ 0.865701] tegra_hv: added ivc2
[ 0.868881] tegra_hv: adding ivc3: rx_base=ffffff8009a30000 tx_base = ffffff8009a38000 size=8000 irq = 8 (324)
[ 0.878952] tegra_hv: added ivc3
[ 0.882118] tegra_hv: adding ivc4: rx_base=ffffff8009a40000 tx_base = ffffff8009a48000 size=8000 irq = 9 (325)
[ 0.892165] tegra_hv: added ivc4
[ 0.895349] tegra_hv: adding ivc5: rx_base=ffffff8009a50000 tx_base = ffffff8009a58000 size=8000 irq = 10 (326)
[ 0.905416] tegra_hv: added ivc5
[ 0.908741] tegra_hv: adding ivc6: rx_base=ffffff8009a60000 tx_base = ffffff8009a68000 size=8000 irq = 11 (327)
[ 0.918805] tegra_hv: added ivc6
[ 0.921984] tegra_hv: adding ivc7: rx_base=ffffff8009a70000 tx_base = ffffff8009a78000 size=8000 irq = 12 (328)
[ 0.932057] tegra_hv: added ivc7
[ 0.935380] tegra_hv: adding ivc8: rx_base=ffffff8009a80000 tx_base = ffffff8009a88000 size=8000 irq = 13 (329)
[ 0.945447] tegra_hv: added ivc8
[ 0.948627] tegra_hv: adding ivc9: rx_base=ffffff8009a90000 tx_base = ffffff8009a98000 size=8000 irq = 14 (330)
[ 0.958697] tegra_hv: added ivc9
[ 0.962021] tegra_hv: adding ivc10: rx_base=ffffff8009aa0000 tx_base = ffffff8009aa8000 size=8000 irq = 15 (331)
[ 0.972105] tegra_hv: added ivc10
[ 0.975440] tegra_hv: adding ivc11: rx_base=ffffff8009ab0000 tx_base = ffffff8009ab8000 size=8000 irq = 16 (332)
[ 0.985670] tegra_hv: added ivc11
[ 0.989011] tegra_hv: adding ivc12: rx_base=ffffff8009ac0000 tx_base = ffffff8009ac8000 size=8000 irq = 17 (333)
[ 0.999093] tegra_hv: added ivc12
[ 1.002432] tegra_hv: adding ivc13: rx_base=ffffff8009ad0000 tx_base = ffffff8009ad8000 size=8000 irq = 18 (334)
[ 1.012656] tegra_hv: added ivc13
[ 1.016000] tegra_hv: adding ivc28: rx_base=ffffff8009980000 tx_base = ffffff8009988000 size=8000 irq = 19 (335)
[ 1.026082] tegra_hv: added ivc28
[ 1.029426] tegra_hv: adding ivc29: rx_base=ffffff8009990000 tx_base = ffffff8009998000 size=8000 irq = 20 (336)
[ 1.039644] tegra_hv: added ivc29
[ 1.042990] tegra_hv: adding ivc30: rx_base=ffffff80099a0000 tx_base = ffffff80099a8000 size=8000 irq = 21 (337)
[ 1.053077] tegra_hv: added ivc30
[ 1.056410] tegra_hv: adding ivc31: rx_base=ffffff80099b0000 tx_base = ffffff80099b8000 size=8000 irq = 22 (338)
[ 1.066633] tegra_hv: added ivc31
[ 1.069980] tegra_hv: adding ivc32: rx_base=ffffff8008040000 tx_base = ffffff8008048000 size=8000 irq = 23 (339)
[ 1.080058] tegra_hv: added ivc32
[ 1.083395] tegra_hv: adding ivc33: rx_base=ffffff8009b00000 tx_base = ffffff8009b18000 size=18000 irq = 24 (340)
[ 1.093637] tegra_hv: added ivc33
[ 1.096977] tegra_hv: adding ivc56: rx_base=ffffff80099c0000 tx_base = ffffff80099c8000 size=8000 irq = 25 (341)
[ 1.107202] tegra_hv: added ivc56
[ 1.110546] tegra_hv: adding ivc76: rx_base=ffffff8009b40000 tx_base = ffffff8009b50000 size=10000 irq = 26 (342)
[ 1.120783] tegra_hv: added ivc76
[ 1.124129] tegra_hv: adding ivc99: rx_base=ffffff8009ae0000 tx_base = ffffff8009ae8000 size=8000 irq = 27 (343)
[ 1.134209] tegra_hv: added ivc99
[ 1.137551] tegra_hv: adding ivc101: rx_base=ffffff80099d0000 tx_base = ffffff80099d8000 size=8000 irq = 28 (344)
[ 1.147789] tegra_hv: added ivc101
[ 1.151288] tegra_hv: adding ivc200: rx_base=ffffff8008060000 tx_base = ffffff8008068000 size=8000 irq = 29 (345)
[ 1.161525] tegra_hv: added ivc200
[ 1.164853] tegra_hv: added mempool 0: ipa=25d3d0000 size=400000 peer=2
[ 1.171470] tegra_hv: added mempool 1: ipa=25d7d0000 size=800000 peer=2
[ 1.178086] tegra_hv: added mempool 2: ipa=25dfd0000 size=10000 peer=2
[ 1.184683] tegra_hv: added mempool 3: ipa=25e000000 size=400000 peer=1
[ 1.191301] tegra_hv: added mempool 4: ipa=25e400000 size=40000 peer=6
[ 1.197760] tegra_hv: initialized
[ 1.201592] NET: Registered protocol family 16
[ 1.207554] pstore: using zlib compression
[ 1.210469] console [pstore-1] enabled
[ 1.213426] pstore: Registered ramoops as persistent store backend
[ 1.219539] ramoops: attached 0x200000@0xffc00000, ecc: 0/0
[ 1.231296] bpmp: mail init ok
[ 1.233407] arm-smmu 12000000.iommu: probing hardware configuration…
[ 1.237559] arm-smmu 12000000.iommu: SMMUv2 with:
[ 1.242258] arm-smmu 12000000.iommu: stage 1 translation
[ 1.247655] arm-smmu 12000000.iommu: stream indexing with 128 indices
[ 1.254273] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 1.264711] arm-smmu 12000000.iommu: 32 context banks (0 stage-2 only)
[ 1.271345] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 1.282272] vdso: 2 pages (1 code @ ffffff8008ca7000, 1 data @ ffffff8009664000)
[ 1.286379] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 1.295990] atomic_pool_init():529: DMA: preallocated 2048 KiB pool for atomic allocations
[ 1.302541] Registering BPMP clocks…
[ 1.305392] clock init ok
[ 1.308057] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 1.317034] tegra_powergate_init: DONE
[ 1.317597] DTS File Name: /dvs/git/dirty/git-master_modular/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/vcm/kernel-dts/tegra186-vcm31-p3407-0000-a00-00-base-vm.dts
[ 1.335902] DTB Build time: Dec 2 2017 10:54:13
[ 1.340517] Tegra reboot handler registered.
[ 1.345448] tegra-pmc c360000.pmc: create /sys/kernel/debug/PMC/boot-chain-type
[ 1.352042] tegra-pmc: ### PMC reset source: Power on reset
[ 1.357587] tegra-pmc: ### PMC reset level: L0
[ 1.362105] tegra-pmc: ### PMC reset status reg: 0x0
[ 1.367166] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 1.374297] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 1.380493] iommu: Adding device 3460000.sdhci to group 0
[ 1.387304] iommu: Adding device 3160000.i2c to group 1
[ 1.391437] iommu: Adding device c240000.i2c to group 2
[ 1.396365] iommu: Adding device 3180000.i2c to group 3
[ 1.401590] iommu: Adding device 3190000.i2c to group 4
[ 1.406887] iommu: Adding device 31b0000.i2c to group 5
[ 1.412079] iommu: Adding device c250000.i2c to group 6
[ 1.418159] iommu: Adding device c260000.spi to group 7
[ 1.422542] iommu: Adding device 3230000.spi to group 8
[ 1.427760] iommu: Adding device 3270000.spi to group 9
[ 1.433144] iommu: Adding device 3100000.serial to group 10
[ 1.438530] iommu: Adding device 3110000.serial to group 11
[ 1.444603] iommu: Adding device 2490000.ether_qos to group 12
[ 1.450189] iommu: Adding device b000000.rtcpu to group 13
[ 1.455751] iommu: Adding device smmu_test to group 14
[ 1.460607] mc: mapped MMIO address: 0xffffff8009f80000 -> 0x2c10000
[ 1.466600] mc: mapped MMIO address: 0xffffff8009fa0000 -> 0x2c20000
[ 1.473026] mc: mapped MMIO address: 0xffffff8009fc0000 -> 0x2c30000
[ 1.479311] mc: mapped MMIO address: 0xffffff8009fe0000 -> 0x2c40000
[ 1.485739] mc: mapped MMIO address: 0xffffff800b210000 -> 0x2c50000
[ 1.492354] mc-err: mcerr ops are set to t18x
[ 1.497093] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 1.503177] iommu: Adding device 3530000.xhci to group 15
[ 1.508299] iommu: Adding device 3550000.xudc to group 16
[ 1.514117] iommu: Adding device 13e10000.host1x to group 17
[ 1.519251] iommu: Adding device 13e10000.host1x:ctx0 to group 18
[ 1.525235] iommu: Adding device 13e10000.host1x:ctx1 to group 19
[ 1.531458] iommu: Adding device 13e10000.host1x:ctx2 to group 20
[ 1.537516] iommu: Adding device 13e10000.host1x:ctx3 to group 21
[ 1.543559] iommu: Adding device 13e10000.host1x:ctx4 to group 22
[ 1.549672] iommu: Adding device 13e10000.host1x:ctx5 to group 23
[ 1.555685] iommu: Adding device 13e10000.host1x:ctx6 to group 24
[ 1.561890] iommu: Adding device 13e10000.host1x:ctx7 to group 25
[ 1.567981] iommu: Adding device 150c0000.nvcsi to group 26
[ 1.574774] tegra-reset 5000000.clock: registered 193 resets.
[ 1.579617] iommu: Adding device d000000.bpmp to group 27
[ 1.584568] bpmp d000000.bpmp: Found mempool with id 3
[ 1.589588] bpmp d000000.bpmp: ivm 0x000000025e000000
[ 1.594794] bpmp: ping status is 0
[ 1.598099] bpmp d000000.bpmp: firmware tag is 7a20186dd4ae720b05ab8a27657a7223
[ 1.608560] bpmp d000000.bpmp: probe ok
[ 1.611143] iommu: Adding device 2600000.dma to group 28
[ 1.616460] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 1.630210] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 1.639183] iommu: Adding device c1a0000.aon to group 29
[ 1.641708] sys-3v3: 3300 mV
[ 1.644361] sys-5v0: 5000 mV
[ 1.649506] iommu: Adding device 13e20000.host1xb to group 30
[ 1.653144] iommu: Adding device 15600000.isp to group 31
[ 1.658432] iommu: Adding device 15340000.vic to group 32
[ 1.663902] iommu: Adding device 154c0000.nvenc to group 33
[ 1.669391] iommu: Adding device 15480000.nvdec to group 34
[ 1.675143] iommu: Adding device 15380000.nvjpg to group 35
[ 1.680597] iommu: Adding device 15500000.tsec to group 36
[ 1.686106] iommu: Adding device 15100000.tsecb to group 37
[ 1.692462] iommu: Adding device vse@15810000 to group 38
[ 1.697074] iommu: Adding device vse@15820000 to group 39
[ 1.702333] iommu: Adding device vse@15830000 to group 40
[ 1.707724] iommu: Adding device vse@15840000 to group 41
[ 1.713421] irq: type mismatch, failed to map hwirq-328 for /interrupt-controller@3881000!
[ 1.721435] irq: type mismatch, failed to map hwirq-322 for /interrupt-controller@3881000!
[ 1.739072] SCSI subsystem initialized
[ 1.739955] libata version 3.00 loaded.
[ 1.740080] usbcore: registered new interface driver usbfs
[ 1.744991] usbcore: registered new interface driver hub
[ 1.750556] usbcore: registered new device driver usb
[ 1.766955] media: Linux media interface: v0.10
[ 1.768160] Linux video capture interface: v2.00
[ 1.772853] pps_core: LinuxPPS API ver. 1 registered
[ 1.777709] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.786940] PTP clock support registered
[ 1.791408] trusty trusty: trusty version: Built: 21:28:29 Nov 29 2017
[ 1.797427] trusty trusty: selected api version: 3 (requested 3)
[ 1.806252] max77620 4-003c: PMIC Version OTP:0x4A and ES:0x1
[ 1.810862] max77620-sd0: at 1125 mV
[ 1.813626] max77620-sd1: at 1200 mV
[ 1.817300] max77620-sd2: at 1800 mV
[ 1.820845] max77620-sd3: at 3300 mV
[ 1.824553] max77620-sd4: at 600 mV
[ 1.828092] max77620-ldo0: at 1800 mV
[ 1.831615] max77620-ldo1: at 800 mV
[ 1.835294] max77620-ldo2: at 3300 mV
[ 1.839110] i2c i2c-4: deserialize_i2c ret -22
[ 1.842999] i2c i2c-4: — message dump for debugging —
[ 1.848396] i2c i2c-4: addr 0x3c flags 0x0 len 2 data:
[ 1.853451] i2c i2c-4: 29
[ 1.856232] i2c i2c-4: f2
[ 1.858850] i2c i2c-4:
[ 1.861290] max77620-pmic max20024-pmic: Regulator 8 mode set failed: -22
[ 1.868159] max77620-pmic max20024-pmic: driver callback failed to parse DT for regulator ldo3
[ 1.876914] random: fast init done
[ 1.876952] max77620-ldo3: at 3300 mV
[ 1.884114] max77620-ldo4: at 800 mV
[ 1.888442] i2c i2c-4: deserialize_i2c ret -22
[ 1.892015] i2c i2c-4: — message dump for debugging —
[ 1.897411] i2c i2c-4: addr 0x3c flags 0x0 len 2 data:
[ 1.902470] i2c i2c-4: 2d
[ 1.905242] i2c i2c-4: f2
[ 1.907864] i2c i2c-4:
[ 1.910307] max77620-pmic max20024-pmic: Regulator 10 mode set failed: -22
[ 1.917260] max77620-pmic max20024-pmic: driver callback failed to parse DT for regulator ldo5
[ 1.926042] max77620-ldo5: at 3300 mV
[ 1.930100] max77620-ldo6: at 1800 mV
[ 1.933841] max77620-ldo7: at 1000 mV
[ 1.937605] max77620-ldo8: at 800 mV
[ 1.941217] gpiochip_setup_dev: registered GPIOs 248 to 255 on device: gpiochip2 (max77620-gpio)
[ 1.951747] i2c i2c-4: deserialize_i2c ret -22
[ 1.953997] i2c i2c-4: — message dump for debugging —
[ 1.959395] i2c i2c-4: addr 0x3c flags 0x0 len 2 data:
[ 1.964453] i2c i2c-4: 0d
[ 1.967230] i2c i2c-4: ef
[ 1.969847] i2c i2c-4:
[ 1.972288] max77620 4-003c: Failed to sync masks in d
[ 1.977883] max77620 4-003c: max77620 probe successful
[ 1.983690] max929x_i2c_client_init: called
[ 1.987502] tegra_hv_wdt tegra_hv_wdt: id=32 irq=23 peer=3 num=1 size=128
[ 1.987506] tegra_hv_wdt tegra_hv_wdt: ivc channel ready
[ 1.999046] vdd-1v1: Bringing 0uV into 1100000-1100000uV
[ 2.004159] vdd-1v1: 1100 mV
[ 2.007333] vdd-1v2: Bringing 0uV into 1200000-1200000uV
[ 2.012426] vdd-1v2: 1200 mV
[ 2.015576] vdd-1v8-ddr: Bringing 0uV into 1800000-1800000uV
[ 2.021139] vdd-1v8-ddr: 1800 mV
[ 2.024598] vdd-3v3: Bringing 0uV into 3300000-3300000uV
[ 2.029677] vdd-3v3: 3300 mV
[ 2.032791] spmic-sd4: Bringing 0uV into 1100000-1100000uV
[ 2.038185] spmic-sd4: 1100 mV
[ 2.041523] vdd-1v8-pll: Bringing 0uV into 1800000-1800000uV
[ 2.046904] vdd-1v8-pll: 1800 mV
[ 2.050395] spmic-ldo1: Bringing 0uV into 800000-800000uV
[ 2.055618] spmic-ldo1: 800 mV
[ 2.058931] vdd-v3v-ao: Bringing 0uV into 3300000-3300000uV
[ 2.064329] vdd-v3v-ao: 3300 mV
[ 2.067812] en-vdd-rtc: Bringing 0uV into 800000-800000uV
[ 2.073009] en-vdd-rtc: 800 mV
[ 2.076331] vdd-1v8-ao: Bringing 0uV into 1800000-1800000uV
[ 2.081716] vdd-1v8-ao: 1800 mV
[ 2.085075] vdd-1v05: Bringing 0uV into 1050000-1050000uV
[ 2.090334] vdd-1v05: 1050 mV
[ 2.093507] spmic-ldo8: Bringing 0uV into 800000-800000uV
[ 2.098700] spmic-ldo8: 800 mV
[ 2.103269] vdd-1v8: supplied by vdd-1v8-ddr
[ 2.106213] vdd-1v8: 1800 mV
[ 2.109458] vdd-rtc: supplied by en-vdd-rtc
[ 2.113344] vdd-rtc: at 800 mV
[ 2.116927] en-vdd-sdcard1: supplied by vdd-1v8
[ 2.121012] en-vdd-sdcard1: 3300 mV
[ 2.126987] camchar: rtcpu character device driver loaded
[ 2.130164] clocksource: Switched to clocksource arch_sys_counter
[ 2.168977] VFS: Disk quotas dquot_6.6.0
[ 2.169715] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.184737] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 2.190048] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 2.198505] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 2.207046] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 2.215615] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type AO-therm
[ 2.223861] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tj-therm
[ 2.233623] isomgr_init(): iso emc max clk=1600000KHz
[ 2.237182] isomgr_init(): max_iso_bw=23040000KB
[ 2.241861] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 2.248880] tegra-carveouts tegra-carveouts: generic-0 :dma coherent mem declare 0x00000000d3100000,749731840
[ 2.258178] tegra-carveouts tegra-carveouts: assigned reserved memory node generic_carveout
[ 2.258969] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 2.259300] NET: Registered protocol family 2
[ 2.259950] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 2.260560] TCP bind hash table entries: 65536 (order: 9, 3670016 bytes)
[ 2.262322] TCP: Hash tables configured (established 65536 bind 65536)
[ 2.262393] UDP hash table entries: 4096 (order: 7, 524288 bytes)
[ 2.262744] UDP-Lite hash table entries: 4096 (order: 7, 524288 bytes)
[ 2.263244] NET: Registered protocol family 1
[ 2.264141] RPC: Registered named UNIX socket transport module.
[ 2.264143] RPC: Registered udp transport module.
[ 2.264145] RPC: Registered tcp transport module.
[ 2.264147] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.264161] PCI: CLS 0 bytes, default 128
[ 2.264347] Unpacking initramfs…
[ 2.279662] Freeing initrd memory: 4628K (ffffffc003420000 - ffffffc0038a5000)
[ 2.297999] host1x 13e10000.host1x: initialized
[ 2.310372] genirq: Flags mismatch irq 66. 00002004 (host_status) vs. 00002004 (host_status)
[ 2.310446] host1x 13e20000.host1xb: general irq request failed, but continuing
[ 2.311263] host1x 13e20000.host1xb: initialized
[ 2.312060] irq: type mismatch, failed to map hwirq-328 for /interrupt-controller@3881000!
[ 2.312130] irq: type mismatch, failed to map hwirq-329 for /interrupt-controller@3881000!
[ 2.312213] irq: type mismatch, failed to map hwirq-330 for /interrupt-controller@3881000!
[ 2.312309] irq: type mismatch, failed to map hwirq-331 for /interrupt-controller@3881000!
[ 2.312524] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.316204] audit: initializing netlink subsys (disabled)
[ 2.316231] audit: type=2000 audit(2.308:1): initialized
[ 2.316921] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 2.321150] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.322129] NFS: Registering the id_resolver key type
[ 2.322144] Key type id_resolver registered
[ 2.322146] Key type id_legacy registered
[ 2.322231] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 2.322258] ntfs: driver 2.1.32 [Flags: R/O].
[ 2.322628] fuse init (API version 7.26)
[ 2.333508] NET: Registered protocol family 38
[ 2.333531] io scheduler noop registered
[ 2.333533] io scheduler deadline registered
[ 2.333779] io scheduler cfq registered (default)
[ 2.337975] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 2.338303] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 2.341005] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 2.345184] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 2.348036] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 2.348645] kfuse 3830000.kfuse: initialized
[ 2.349118] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 2.350857] console [ttyS0] disabled
[ 2.528190] 3110000.serial: ttyS0 at MMIO 0x3110000 (irq = 43, base_baud = 25500000) is a Tegra
[ 2.536852] console [ttyS0] enabled
[ 2.543802] bootconsole [uart8250] disabled
[ 2.560870] nvmap: nvmap_setup_t18x_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 2.563938] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 42, base_baud = 0) is a TEGRA_UART
[ 2.637308] loop: module loaded
[ 2.639170] zram: Added device: zram0
[ 2.678003] nvmap: nvmap_select_cache_ops() nvmap cache ops set to (null)
[ 2.678283] tegra_profiler: Branch: Dev
[ 2.678285] tegra_profiler: Version: 1.114
[ 2.678288] tegra_profiler: Samples version: 41
[ 2.678289] tegra_profiler: IO version: 22
[ 2.678298] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.678301] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.678304] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.678307] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 2.678309] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.678311] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 2.678313] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.678315] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.678317] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.678319] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.678321] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.678323] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.678603] tegra_profiler: auth: init
[ 2.692100] qspi_mtd spi6.0: s25fs512s SSG 8 0 1000 4000000
[ 2.692103] qspi_mtd spi6.0: s25fs512s (65536 Kbytes)
[ 2.692107] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x4000000 (64MiB) .erasesize = 0x00040000 (256KiB) .numeraseregions = 0
[ 2.692361] 1 ofpart partitions found on MTD device spi6.0
[ 2.692363] Creating 1 MTD partitions on “spi6.0”:
[ 2.692366] 0x000000000000-0x000004000000 : “Whole_flash”
[ 2.692553] libphy: Fixed MDIO Bus: probed
[ 2.692793] tun: Universal TUN/TAP device driver, 1.6
[ 2.692795] tun: © 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.692975] e1000e: Intel® PRO/1000 Network Driver - 3.2.6-k
[ 2.692978] e1000e: Copyright© 1999 - 2015 Intel Corporation.
[ 2.693024] igb: Intel® Gigabit Ethernet Network Driver - version 5.4.0-k
[ 2.693026] igb: Copyright © 2007-2014 Intel Corporation.
[ 2.694080] PPP generic driver version 2.4.2
[ 2.695280] PPP BSD Compression module registered
[ 2.695392] PPP Deflate Compression module registered
[ 2.695651] PPP MPPE Compression module registered
[ 2.695772] NET: Registered protocol family 24
[ 2.697194] usbcore: registered new interface driver asix
[ 2.698630] usbcore: registered new interface driver ax88179_178a
[ 2.698648] usbcore: registered new interface driver cdc_ether
[ 2.698664] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 31 41 47
[ 2.698668] usbcore: registered new interface driver smsc95xx
[ 2.698683] usbcore: registered new interface driver net1080
[ 2.698700] usbcore: registered new interface driver cdc_subset
[ 2.698719] usbcore: registered new interface driver zaurus
[ 2.698814] usbcore: registered new interface driver cdc_ncm
[ 2.701643] libphy: dwc_phy: probed
[ 2.703052] tegra-xusb 3530000.xhci: No USB2 port has OTG_CAP
[ 2.703055] tegra-xusb 3530000.xhci: No USB3 port has OTG_CAP
[ 2.711096] Could not get extcon-dev /xhci@3530000:id(0)
[ 2.713358] usbcore: registered new interface driver usb-storage
[ 2.714314] Could not get extcon-dev /xudc@3550000:vbus(0)
[ 2.714825] mousedev: PS/2 mouse device common for all mice
[ 2.714931] usbcore: registered new interface driver xpad
[ 2.715443] i2c /dev entries driver
[ 2.716392] usbcore: registered new interface driver uvcvideo
[ 2.716394] USB Video Class driver (1.1.1)
[ 2.716758] max77620-power max20024-power: Event recorder REG_NVERC : 0x54
[ 2.717030] tegra-tj-thermal tegra-tj: found thermal zone PLL-therm + offset 5500
[ 2.717033] tegra-tj-thermal tegra-tj: PLL-therm driver not initialized… Deferring the probe
[ 2.717288] FAN dev name: pwm-fan
[ 2.717372] FAN:gpio request success.
[ 2.717629] pwm_fan_driver pwm-fan: cap state:4, cap pwm:256
[ 2.717703] pwm_fan_driver pwm-fan: got pwm for fan
[ 2.717970] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 2.718061] pwm_fan_driver pwm-fan: fan tach request irq success
[ 2.718099] pwm_fan_driver pwm-fan: tach period: 400
[ 2.718726] pwm_fan_driver pwm-fan: index 0: pwm=90, rpm=1470, rru=5, rrd=5, state:2
[ 2.718729] pwm_fan_driver pwm-fan: index 1: pwm=115, rpm=1890, rru=5, rrd=5, state:2
[ 2.718733] pwm_fan_driver pwm-fan: index 2: pwm=141, rpm=2310, rru=10, rrd=10, state:2
[ 2.718736] pwm_fan_driver pwm-fan: index 3: pwm=231, rpm=3780, rru=5, rrd=5, state:3
[ 2.718738] pwm_fan_driver pwm-fan: index 4: pwm=256, rpm=4200, rru=1, rrd=1, state:3
[ 2.718741] pwm_fan_driver pwm-fan: index 5: pwm=256, rpm=4200, rru=1, rrd=1, state:3
[ 2.718744] pwm_fan_driver pwm-fan: index 6: pwm=256, rpm=4200, rru=1, rrd=1, state:3
[ 2.718747] pwm_fan_driver pwm-fan: index 7: pwm=256, rpm=4200, rru=1, rrd=1, state:3
[ 2.718750] pwm_fan_driver pwm-fan: index 8: pwm=256, rpm=4200, rru=1, rrd=1, state:3
[ 2.718753] pwm_fan_driver pwm-fan: index 9: pwm=256, rpm=4200, rru=1, rrd=1, state:3
[ 2.721211] trusty-virtio trusty:virtio: initializing
[ 2.721407] trusty_ipc virtio0: vring0: va(pa) ffffffc1cfce2000(0) qsz 32 notifyid 1
[ 2.721424] trusty_ipc virtio0: vring1: va(pa) ffffffc1cfcf0000(0) qsz 32 notifyid 2
[ 2.721881] trusty_ipc virtio0: is online
[ 2.721912] trusty-virtio trusty:virtio: initializing done
[ 2.722337] softdog-platform soft_watchdog: Software Watchdog Timer: initialized
[ 2.722592] device-mapper: uevent: version 1.0.3
[ 2.722850] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 2.723209] sdhci: Secure Digital Host Controller Interface driver
[ 2.723210] sdhci: Copyright© Pierre Ossman
[ 2.723212] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.723626] hidraw: raw HID events driver © Jiri Kosina
[ 2.724195] usbcore: registered new interface driver usbhid
[ 2.724196] usbhid: USB HID core driver
[ 2.724245] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 2.727322] sdhci-tegra 3460000.sdhci: vqmmc supply missing
[ 2.727334] sdhci-tegra 3460000.sdhci: vqmmc supply missing
[ 2.728657] tegra_hv_pm_ctl tegra_hv_pm_ctl: tegra_hv_pm_ctl_probe: Probed
[ 2.729217] isc-mgr isc-mgr.0: isc_mgr_probeing…
[ 2.729333] isc-mgr isc-mgr.1: isc_mgr_probeing…
[ 2.729464] isc-pwm isc_pwm_gen: isc_pwm_probeing…
[ 2.729507] isc-pwm isc_pwm_gen: isc_pwm_probe success to get PWM
[ 2.729647] nct1008_nct72 1-004c: find device tree node, parsing dt
[ 2.729649] nct1008_nct72 1-004c: starting parse dt
[ 2.729817] nct1008_nct72 1-004c: success parsing dt
[ 2.729906] nct1008_nct72 1-004c: success in enabling nct72 VDD rail
[ 2.729961] THERMAL EST: found 1 subdevs
[ 2.729984] THERMAL EST num_resources: 0
[ 2.729987] [THERMAL EST subdev 0]
[ 2.730300] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type thermal-fan-est
[ 2.730302] THERMAL EST: thz register success.
[ 2.730336] THERMAL EST: end of probe, return err: 0
[ 2.732373] tsec 15500000.tsec: initialized
[ 2.733507] tsec 15100000.tsecb: initialized
[ 2.735841] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 2.736705] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 2.737563] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 2.738455] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 2.739334] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 2.740145] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 2.740970] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 2.741769] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 2.744163] vhost-client 15340000.vic: initialized
[ 2.745011] vhost-client 154c0000.nvenc: initialized
[ 2.747939] vhost-client 15480000.nvdec: initialized
[ 2.748746] vhost-client 15380000.nvjpg: initialized
[ 2.749200] CHRDEV “tegra_dc_ext” major number 233 goes below the dynamic allocation range
[ 2.749298] scrncapt: init (heads:3 wins:6 planes:4)
[ 2.749660] tegradccommon 15200000.dc_common: host1x channel mapped
[ 2.749667] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 2.749714] tegradccommon 15200000.dc_common: dma mapping done
[ 2.751219] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor
[ 2.751750] tegradc 15200000.nvdisplay: DT parsed successfully
[ 2.751881] tegradc 15200000.nvdisplay: Display dc.ffffff800bba0000 registered with id=0
[ 2.752534] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 2.757684] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011d27f size=53888
[ 2.758111] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 2.758150] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 2.758368] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 2.759581] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 2.759640] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 2.759681] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 2.759720] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 2.759747] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 2.759851] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9180-0xb200 TX[1x8192]=0xb200-0xd280
[ 2.760366] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (55)
[ 2.760369] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 2.761944] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=6cd7938ef896bacc0f835ef3635e8c3f30d00721
[ 2.764805] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 2.764815] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.764820] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 2.764822] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 2.764934] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 2.764938] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 2.765013] register_ari_mca_banks: Registered MCA ROC:IOB
[ 2.765125] register_ari_mca_banks: Registered MCA ROC:CCE
[ 2.765244] tegra_mce_write_uncore_mca: failed (ret=-1)
[ 2.765246] tegra18_denver_serr_enable:mce write failed: error=0x0
[ 2.765281] tegra_mce_write_uncore_mca: failed (ret=-1)
[ 2.765283] tegra18_denver_serr_enable:mce write failed: error=0x0
[ 2.766184] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.766499] tegra18_a57_serr_init: on CPU 2 a Denver Core
[ 2.767189] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 2.768465] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.768873] irq: type mismatch, failed to map hwirq-322 for /interrupt-controller@3881000!
[ 2.768987] tegra_mce_write_uncore_perfmon: failed (ret=-1)
[ 2.768992] perfmon status error: 4294967295
[ 2.768993] ARI CMD:1 REG:6 CTR:0 Data:2
[ 2.769016] irq: type mismatch, failed to map hwirq-322 for /interrupt-controller@3881000!
[ 2.769062] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 2.769204] Denver: backdoor interface is NOT available.
[ 2.770263] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 2.770267] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 2.770574] tegra_hv_vse vse@15810000: Virtual SE Stream ID: 72
[ 2.770582] tegra_hv_vse vse@15810000: Virtual SE channel number: 76
[ 2.772144] tegradc 15200000.nvdisplay: probed
[ 2.773296] tegra_hv_vse vse@15820000: Virtual SE Stream ID: 72
[ 2.774372] tegra_hv_vse vse@15830000: Virtual SE Stream ID: 72
[ 2.775114] tegra_hv_vse vse@15840000: Virtual SE Stream ID: 72
[ 2.776731] tegra18x-cpufreq: Using hv path
[ 2.778516] cpufreq: platform driver Initialization: pass
[ 2.779770] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 2.782578] sdhci-tegra 3460000.sdhci: vqmmc supply missing
[ 2.782590] sdhci-tegra 3460000.sdhci: vqmmc supply missing
[ 2.783717] GACT probability NOT on
[ 2.783726] Mirror/redirect action on
[ 2.783733] u32 classifier
[ 2.783735] Actions configured
[ 2.783740] Netfilter messages via NETLINK v0.30.
[ 2.784234] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 2.784371] ctnetlink v0.93: registering with nfnetlink.
[ 2.784803] xt_time: kernel timezone is -0000
[ 2.784810] IPVS: Registered protocols ()
[ 2.784877] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 2.784970] IPVS: Creating netns size=1744 id=0
[ 2.785759] IPVS: ipvs loaded.
[ 2.785827] gre: GRE over IPv4 demultiplexor driver
[ 2.786255] nct72: Enabled overheat logging at 112.00C
[ 2.786303] ip_tables: © 2000-2006 Netfilter Core Team
[ 2.786420] arp_tables: arp_tables: © 2002 David S. Miller
[ 2.786523] nct1008_nct72 1-004c: nct1008_probe: initialized
[ 2.786588] Initializing XFRM netlink socket
[ 2.787160] NET: Registered protocol family 10
[ 2.788212] mip6: Mobile IPv6
[ 2.788289] ip6_tables: © 2000-2006 Netfilter Core Team
[ 2.789195] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.789736] ip6_gre: GRE over IPv6 tunneling driver
[ 2.789971] NET: Registered protocol family 17
[ 2.789984] NET: Registered protocol family 15
[ 2.790022] 8021q: 802.1Q VLAN Support v1.8
[ 2.790049] Key type dns_resolver registered
[ 2.790354] Registered cp15_barrier emulation handler
[ 2.790402] Registered setend emulation handler
[ 2.792183] registered taskstats version 1
[ 2.795627] tegra-xusb 3530000.xhci: No USB2 port has OTG_CAP
[ 2.795630] tegra-xusb 3530000.xhci: No USB3 port has OTG_CAP
[ 2.804824] tegra-xudc-new 3550000.xudc: USB charger detection disabled
[ 2.804853] tegra-xudc-new 3550000.xudc: device mode on
[ 2.805269] tegra-tj-thermal tegra-tj: found thermal zone PLL-therm + offset 5500
[ 2.805404] tegra-tj-thermal tegra-tj: found thermal zone AO-therm + offset 6000
[ 2.806299] isc-mgr isc-mgr.0: isc_mgr_probeing…
[ 2.806741] isc-mgr isc-mgr.0: isc_mgr_probe: success to get PWM
[ 2.807196] CHRDEV “isc-mgr.7.a” major number 232 goes below the dynamic allocation range
[ 2.807416] isc-mgr isc-mgr.1: isc_mgr_probeing…
[ 2.807493] isc-mgr isc-mgr.1: isc_mgr_probe: success to get PWM
[ 2.807751] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 2.807856] CHRDEV “isc-mgr.2.c” major number 231 goes below the dynamic allocation range
[ 2.809060] hvc_sysfs: log is unavailable
[ 2.809064] hvc_sysfs: pct is available
[ 2.812406] isp 15600000.isp: initialized
[ 2.864276] tegra-xusb 3530000.xhci: Firmware timestamp: 2016-09-01 11:32:41 UTC, Version: 55.05 release
[ 2.864294] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 2.864307] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[ 2.865076] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
[ 2.865308] tegra-xusb 3530000.xhci: irq 61, io mem 0x03530000
[ 2.865467] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.865470] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.865473] usb usb1: Product: xHCI Host Controller
[ 2.865475] usb usb1: Manufacturer: Linux 4.9.38-rt25-tegra xhci-hcd
[ 2.865478] usb usb1: SerialNumber: 3530000.xhci
[ 2.865756] hub 1-0:1.0: USB hub found
[ 2.865782] hub 1-0:1.0: 4 ports detected
[ 2.866131] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 2.866138] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[ 2.866372] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.866375] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.866378] usb usb2: Product: xHCI Host Controller
[ 2.866380] usb usb2: Manufacturer: Linux 4.9.38-rt25-tegra xhci-hcd
[ 2.866382] usb usb2: SerialNumber: 3530000.xhci
[ 2.866619] hub 2-0:1.0: USB hub found
[ 2.866641] hub 2-0:1.0: 3 ports detected
[ 2.867638] Wake76 for irq=199
[ 2.867640] Wake77 for irq=199
[ 2.867641] Wake78 for irq=199
[ 2.867642] Wake79 for irq=199
[ 2.867643] Wake80 for irq=199
[ 2.867644] Wake81 for irq=199
[ 2.867645] Wake82 for irq=199
[ 2.881343] sdhci-tegra 3460000.sdhci: vqmmc supply missing
[ 2.881354] sdhci-tegra 3460000.sdhci: vqmmc supply missing
[ 2.892076] mmc0: hw tuning done …
[ 2.892077] ======= mmc0: Tuning windows =======
[ 2.892080] mmc0: tuning window[0]: 0xffffffff
[ 2.892082] mmc0: tuning window[1]: 0xffffffcf
[ 2.892084] mmc0: tuning window[2]: 0xffff8fff
[ 2.892086] mmc0: tuning window[3]: 0x7f8fffff
[ 2.892087] mmc0: tuning window[4]: 0x0
[ 2.892089] mmc0: tuning window[5]: 0x0
[ 2.892091] mmc0: tuning window[6]: 0x0
[ 2.892092] mmc0: tuning window[7]: 0x0
[ 2.892094] sdhci: Tap value: 0 | Trim value: 5
[ 2.892095] ==================================
[ 2.892096] Vendor clock ctrl: 0x538d069
[ 2.892097] Vendor SysSW ctrl: 0x38607002
[ 2.892099] Vendor Err interrupt status : 0x40000
[ 2.892100] Vendor Cap overrides: 0x1107
[ 2.892101] Vendor Misc ctrl: 0xfffd0081
[ 2.892102] Vendor Misc ctrl_1: 0x0
[ 2.892103] Vendor Misc ctrl_2: 0x20e00000
[ 2.892104] Vendor IO trim ctrl: 0x11
[ 2.892105] Vendor Tuning ctrl: 0x7c024057
[ 2.892106] SDMEM comp padctrl: 0x8000007
[ 2.892107] Autocal config: 0x20010505
[ 2.892108] Autocal status: 0xf0d0a08
[ 2.897316] mmc0: new HS400 MMC card at address 0001
[ 2.897700] mmcblk0: mmc0:0001 064G32 59.3 GiB
[ 2.897900] mmcblk0rpmb: mmc0:0001 064G32 partition 3 4.00 MiB
[ 2.899343] GPT:Primary header thinks Alt. header is not at the end of the disk.
[ 2.899345] GPT:124190719 != 124321791
[ 2.899345] GPT:Alternate GPT header not at the end of the disk.
[ 2.899346] GPT:124190719 != 124321791
[ 2.899347] GPT: Use GNU Parted to correct GPT errors.
[ 2.899355] mmcblk0: p1 p2 p3 p4
[ 3.190226] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 3.334056] usb 1-2: New USB device found, idVendor=0480, idProduct=0900
[ 3.334059] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.334062] usb 1-2: Product: External USB 3.0
[ 3.334065] usb 1-2: Manufacturer: TOSHIBA
[ 3.334067] usb 1-2: SerialNumber: 20180531002199F
[ 3.334932] usb-storage 1-2:1.0: USB Mass Storage device detected
[ 3.335385] scsi host0: usb-storage 1-2:1.0
[ 3.451489] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 3.484045] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 3.484048] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.484050] usb 2-1: Product: 4-Port USB 3.0 Hub
[ 3.484052] usb 2-1: Manufacturer: Generic
[ 3.493699] hub 2-1:1.0: USB hub found
[ 3.495100] hub 2-1:1.0: 4 ports detected
[ 3.594216] usb 1-3: new high-speed USB device number 3 using tegra-xusb
[ 3.746621] usb 1-3: New USB device found, idVendor=0bda, idProduct=5411
[ 3.746624] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.746627] usb 1-3: Product: 4-Port USB 2.0 Hub
[ 3.746629] usb 1-3: Manufacturer: Generic
[ 3.747702] hub 1-3:1.0: USB hub found
[ 3.748616] hub 1-3:1.0: 4 ports detected
[ 4.038253] usb 1-3.1: new low-speed USB device number 4 using tegra-xusb
[ 4.144761] usb 1-3.1: New USB device found, idVendor=413c, idProduct=2113
[ 4.144765] usb 1-3.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 4.144768] usb 1-3.1: Product: Dell KB216 Wired Keyboard
[ 4.149303] input: Dell KB216 Wired Keyboard as /devices/3530000.xhci/usb1/1-3/1-3.1/1-3.1:1.0/0003:413C:2113.0001/input/input0
[ 4.206402] hid-generic 0003:413C:2113.0001: input,hidraw0: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-3530000.xhci-3.1/input0
[ 4.211842] input: Dell KB216 Wired Keyboard as /devices/3530000.xhci/usb1/1-3/1-3.1/1-3.1:1.1/0003:413C:2113.0002/input/input1
[ 4.270399] hid-generic 0003:413C:2113.0002: input,hidraw1: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-3530000.xhci-3.1/input1
[ 4.350221] usb 1-3.2: new low-speed USB device number 5 using tegra-xusb
[ 4.357151] scsi 0:0:0:0: Direct-Access TOSHIBA External USB 3.0 5438 PQ: 0 ANSI: 6
[ 4.358974] sd 0:0:0:0: [sda] 1953525164 512-byte logical blocks: (1.00 TB/932 GiB)
[ 4.359438] sd 0:0:0:0: [sda] Write Protect is off
[ 4.359442] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[ 4.359878] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 4.454983] usb 1-3.2: New USB device found, idVendor=413c, idProduct=301a
[ 4.454988] usb 1-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.454991] usb 1-3.2: Product: Dell MS116 USB Optical Mouse
[ 4.454993] usb 1-3.2: Manufacturer: PixArt
[ 4.457810] input: PixArt Dell MS116 USB Optical Mouse as /devices/3530000.xhci/usb1/1-3/1-3.2/1-3.2:1.0/0003:413C:301A.0003/input/input2
[ 4.458123] hid-generic 0003:413C:301A.0003: input,hidraw2: USB HID v1.11 Mouse [PixArt Dell MS116 USB Optical Mouse] on usb-3530000.xhci-3.2/input0
[ 4.538218] usb 1-3.3: new high-speed USB device number 6 using tegra-xusb
[ 4.609015] nvmap_page_pool_init: Total RAM pages: 1725457
[ 4.609016] nvmap_page_pool_init: nvmap page pool size: 215682 pages (842 MB)
[ 4.609125] nvmap_background_zero_thread: PP zeroing thread starting.
[ 4.609431] misc nvmap: created heap generic-0 base 0x00000000d3100000 size (732160KiB)
[ 4.636179] tegradc 15200000.nvdisplay: fb registered
[ 4.642131] gpio tegra-gpio wake19 for gpio=120(P:0)
[ 4.646848] nvcsi 150c0000.nvcsi: initialized
[ 4.653261] usb 1-3.3: New USB device found, idVendor=058f, idProduct=6387
[ 4.659791] usb 1-3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.667111] usb 1-3.3: Product: Mass Storage
[ 4.667114] usb 1-3.3: Manufacturer: Generic
[ 4.667116] usb 1-3.3: SerialNumber: C7E5E5AB
[ 4.667458] tegra-vi4 15700000.vi: initialized
[ 4.668771] usb-storage 1-3.3:1.0: USB Mass Storage device detected
[ 4.669240] scsi host1: usb-storage 1-3.3:1.0
[ 4.775391] tegradc 15200000.nvdisplay: hdmi: plugged
[ 5.700293] scsi 1:0:0:0: Direct-Access Generic Flash Disk 8.07 PQ: 0 ANSI: 4
[ 5.701611] sd 1:0:0:0: [sdb] 15728640 512-byte logical blocks: (8.05 GB/7.50 GiB)
[ 5.702409] sd 1:0:0:0: [sdb] Write Protect is off
[ 5.702412] sd 1:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 5.703188] sd 1:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 5.708805] sdb: sdb1
[ 5.740001] sd 1:0:0:0: [sdb] Attached SCSI removable disk
[ 7.444157] sda: sda1
[ 7.451619] sd 0:0:0:0: [sda] Attached SCSI disk
[ 7.452777] Freeing unused kernel memory: 4736K (ffffffc0011c0000 - ffffffc001660000)
[ 7.467518] INITRAMFS STARTS
[ 7.577442] EXT4-fs (mmcblk0p3): couldn’t mount as ext3 due to feature incompatibilities
[ 7.583012] EXT4-fs (mmcblk0p3): couldn’t mount as ext2 due to feature incompatibilities
[ 7.760595] EXT4-fs (mmcblk0p3): 19 orphan inodes deleted
[ 7.762718] EXT4-fs (mmcblk0p3): recovery complete
[ 7.775027] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 7.838562] Trying chroot to /new_root
[ 7.839146] INITRAMFS END
[ 7.879408] systemd[1]: System time before build time, advancing clock.
[ 7.900962] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 7.916000] systemd[1]: Detected architecture arm64.
[ 7.935007] systemd[1]: Set hostname to .
[ 8.056412] systemd[1]: Reached target Swap.
[ 8.070279] systemd[1]: Listening on udev Kernel Socket.
[ 8.086400] systemd[1]: Created slice System Slice.
[ 8.092355] systemd[1]: Listening on Journal Audit Socket.
[ 8.110263] systemd[1]: Listening on LVM2 poll daemon socket.
[ 8.126259] systemd[1]: Listening on udev Control Socket.
[ 8.142234] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 8.429175] usbcore: registered new interface driver rndis_host
[ 8.725970] systemd-journald[425]: Received request to flush runtime journal from PID 1
[ 10.364913] CAN device driver interface
[ 10.420200] Message RAM Configuration
| base addr |0x0c312000|
| sidfc_flssa |0x00000000|
| xidfc_flesa |0x00000040|
| rxf0c_f0sa |0x000000c0|
| rxf1c_f1sa |0x00000300|
| rxbc_rbsa |0x00000540|
| txefc_efsa |0x00000780|
| txbc_tbsa |0x00000800|
| tmc_tmsa |0x00000c80|
[ 10.420414] Release 3.2.0 from 19.12.2014
[ 10.513456] net can0: mttcan device registered (regs=ffffff8009f7e000, irq=365)
[ 10.518023] Message RAM Configuration
| base addr |0x0c322000|
[ 10.518326] Release 3.2.0 from 19.12.2014
[ 10.607425] net can1: mttcan device registered (regs=ffffff800b20e000, irq=366)
[ 11.276216] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 12.425845] tegradc 15200000.nvdisplay: hdmi: plugged
[ 12.863465] random: crng init done
[ 13.326786] [TRUSTY] [secure_storage] E> super_block_valid:155: bad magic, 0x330c32d743bfc62f
[ 13.327319] [TRUSTY] [secure_storage] E> super_block_valid:155: bad magic, 0x330c32d743bfc62f
[ 13.327322] [TRUSTY] [secure_storage] E> fs_init_from_super:313: clear requested, create empty
[ 13.335297] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 13.342024] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.354778] Bluetooth: Core ver 2.22
[ 13.354890] NET: Registered protocol family 31
[ 13.354892] Bluetooth: HCI device and connection manager initialized
[ 13.354902] Bluetooth: HCI socket layer initialized
[ 13.354906] Bluetooth: L2CAP socket layer initialized
[ 13.354926] Bluetooth: SCO socket layer initialized
[ 13.893430] systemd[1]: Started CUPS Scheduler.
[ 14.474929] tegradc 15200000.nvdisplay: blank - powerdown
[ 14.497491] tegradc 15200000.nvdisplay: unblank
[ 14.498538] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 14.498680] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 14.499433] Parent Clock set for DC plld2
[ 14.505928] tegradc 15200000.nvdisplay: hdmi: pclk:151473K prod-setting:prod_c_hdmi_111m_223m
[ 14.508185] tegradc 15200000.nvdisplay: unblank
[ 15.527785] bpmp: mounted debugfs mirror
[ 16.931082] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 16.932017] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 17.617223] nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based firewall rule not found. Use the iptables CT target to attach helpers instead.
[ 17.657452] IPVS: Creating netns size=1744 id=1
[ 17.682540] tegradc 15200000.nvdisplay: blank - powerdown
[ 17.738287] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 17.739485] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 17.739729] tegradc 15200000.nvdisplay: unblank
[ 17.741349] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 17.741484] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 17.742036] Parent Clock set for DC plld2
[ 17.749169] tegradc 15200000.nvdisplay: hdmi: pclk:151473K prod-setting:prod_c_hdmi_111m_223m
[ 17.750792] tegradc 15200000.nvdisplay: unblank
[ 17.867257] IPVS: Creating netns size=1744 id=2
[ 18.264664] IPVS: Creating netns size=1744 id=3
[ 18.979230] FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 18.998241] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 20.144131] IPVS: Creating netns size=1744 id=4
[ 191.244158] eqos ioctl: HW PTP not running
[ 205.538275] eqos ioctl: HW PTP not running
[ 205.544652] sample_radar_re[2109]: unhandled level 2 translation fault (11) at 0x00000000, esr 0x92000006
[ 205.544659] pgd = ffffffc1b62ec000
[ 205.545204] [00000000] *pgd=00000002013f2003
[ 205.548988] , *pud=00000002013f2003
[ 205.549020] , *pmd=0000000000000000
[ 205.549035] CPU: 1 PID: 2109 Comm: sample_radar_re Not tainted 4.9.38-rt25-tegra #1
[ 205.549038] Hardware name: drive-px2-autocruise (DT)
[ 205.549042] task: ffffffc178cbe580 task.stack: ffffffc1c585c000
[ 205.549047] PC is at 0x7fadfdb104
[ 205.549049] LR is at 0x7fadfdbdcc
[ 205.549052] pc : [<0000007fadfdb104>] lr : [<0000007fadfdbdcc>] pstate: 60000000
[ 205.549053] sp : 0000007fd170a2e0
[ 205.549055] x29: 0000007fd170a2e0 x28: 000000000000000a
[ 205.549060] x27: 0000000005201fc0 x26: 0000000005201f58
[ 205.549065] x25: 00000000000015b2 x24: 0000000000000000
[ 205.549069] x23: 0000000000000000 x22: 0000007fd170a440
[ 205.549073] x21: 0000000000000000 x20: 0000007fd170a4c0
[ 205.549078] x19: 0000000005201fc0 x18: 0000000000000000
[ 205.549082] x17: 0000007fab81b3b0 x16: 0000007fafd475c0
[ 205.549086] x15: 0000007fafe7dcc0 x14: 0000000000000000
[ 205.549090] x13: ffffffffffffffff x12: 0000000000000005
[ 205.549094] x11: 000000000000000a x10: 0000007fab8abe18
[ 205.549098] x9 : 0000007fab8ac718 x8 : 0000000005201fcc
[ 205.549102] x7 : 0000000005201fdc x6 : 0000000000000000
[ 205.549106] x5 : 0000000000000000 x4 : 01010101b2150002
[ 205.549110] x3 : 0000000000000000 x2 : 0000000000000000
[ 205.549114] x1 : 0000000000000001 x0 : 0000000005201fec
[ 205.549125] vdso base = 0x7fafe7c000
[ 210.511375] eqos ioctl: HW PTP not running
[ 214.164507] eqos ioctl: HW PTP not running
[ 214.170112] sample_radar_re[2119]: unhandled level 2 translation fault (11) at 0x00000000, esr 0x92000006
[ 214.170119] pgd = ffffffc16e43b000
[ 214.170507] [00000000] *pgd=00000001f3213003
[ 214.174459] , *pud=00000001f3213003
[ 214.174492] , *pmd=0000000000000000
[ 214.174514] CPU: 2 PID: 2119 Comm: sample_radar_re Not tainted 4.9.38-rt25-tegra #1
[ 214.174516] Hardware name: drive-px2-autocruise (DT)
[ 214.174520] task: ffffffc178cbd700 task.stack: ffffffc1811bc000
[ 214.174524] PC is at 0x7f8a62e104
[ 214.174526] LR is at 0x7f8a62edcc
[ 214.174532] pc : [<0000007f8a62e104>] lr : [<0000007f8a62edcc>] pstate: 60000000
[ 214.174535] sp : 0000007fe10fdfc0
[ 214.174539] x29: 0000007fe10fdfc0 x28: 000000000000000a
[ 214.174549] x27: 0000000005201fc0 x26: 0000000005201f58
[ 214.174557] x25: 00000000000015b2 x24: 0000000000000000
[ 214.174564] x23: 0000000000000000 x22: 0000007fe10fe120
[ 214.174571] x21: 0000000000000000 x20: 0000007fe10fe1a0
[ 214.174595] x19: 0000000005201fc0 x18: 0000000000000000
[ 214.174602] x17: 0000007f87e6e3b0 x16: 0000007f8c39a5c0
[ 214.174611] x15: 0000007f8c4d0cc0 x14: 0000000000000000
[ 214.174615] x13: ffffffffffffffff x12: 0000000000000005
[ 214.174646] x11: 000000000000000a x10: 0000007f87efee18
[ 214.174652] x9 : 0000007f87eff718 x8 : 0000000005201fcc
[ 214.174657] x7 : 0000000005201fdc x6 : 0000000000000000
[ 214.174662] x5 : 0000000000000000 x4 : 01010101b2150002
[ 214.174666] x3 : 0000000000000000 x2 : 0000000000000000
[ 214.174670] x1 : 0000000000000001 x0 : 0000000005201fec
[ 214.174683] vdso base = 0x7f8c4cf000
[ 230.048357] eqos 2490000.ether_qos eth0: Link is Down
[ 233.604893] eqos ioctl: HW PTP not running
[ 233.611337] sample_radar_re[2127]: unhandled level 2 translation fault (11) at 0x00000000, esr 0x92000006
[ 233.611344] pgd = ffffffc165644000
[ 233.611687] [00000000] *pgd=0000000211d60003
[ 233.615580] , *pud=0000000211d60003
[ 233.615686] , *pmd=0000000000000000
[ 233.615708] CPU: 1 PID: 2127 Comm: sample_radar_re Not tainted 4.9.38-rt25-tegra #1
[ 233.615711] Hardware name: drive-px2-autocruise (DT)
[ 233.615715] task: ffffffc178cbc880 task.stack: ffffffc18136c000
[ 233.615719] PC is at 0x7fb41cd104
[ 233.615721] LR is at 0x7fb41cddcc
[ 233.615726] pc : [<0000007fb41cd104>] lr : [<0000007fb41cddcc>] pstate: 60000000
[ 233.615728] sp : 0000007ff2ff1e90
[ 233.615730] x29: 0000007ff2ff1e90 x28: 000000000000000a
[ 233.615736] x27: 0000000005201fc0 x26: 0000000005201f58
[ 233.615741] x25: 00000000000015b2 x24: 0000000000000000
[ 233.615745] x23: 0000000000000000 x22: 0000007ff2ff1ff0
[ 233.615750] x21: 0000000000000000 x20: 0000007ff2ff2070
[ 233.615754] x19: 0000000005201fc0 x18: 0000000000000000
[ 233.615758] x17: 0000007fb1a0d3b0 x16: 0000007fb5f395c0
[ 233.615763] x15: 0000007fb606fcc0 x14: 0000000000000000
[ 233.615767] x13: ffffffffffffffff x12: 0000000000000005
[ 233.615771] x11: 000000000000000a x10: 0000007fb1a9de18
[ 233.615775] x9 : 0000007fb1a9e718 x8 : 0000000005201fcc
[ 233.615779] x7 : 0000000005201fdc x6 : 0000000000000000
[ 233.615784] x5 : 0000000000000000 x4 : 01010101b2150002
[ 233.615788] x3 : 0000000000000000 x2 : 0000000000000000
[ 233.615792] x1 : 0000000000000001 x0 : 0000000005201fec
[ 233.615804] vdso base = 0x7fb606e000
[ 238.556528] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 3843.159795] tegradc 15200000.nvdisplay: blank - powerdown
[ 3843.210453] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 3843.211148] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 3850.619376] tegradc 15200000.nvdisplay: hdmi: plugged
[ 3850.621326] tegradc 15200000.nvdisplay: blank - powerdown
[ 3850.621334] tegradc 15200000.nvdisplay: unblank
[ 3850.622288] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 3850.622402] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 3850.622894] Parent Clock set for DC plld2
[ 3850.627364] tegradc 15200000.nvdisplay: hdmi: pclk:151473K prod-setting:prod_c_hdmi_111m_223m
[ 3850.629266] tegradc 15200000.nvdisplay: unblank
[70557.773239] tegradc 15200000.nvdisplay: unblank
[70557.788196] tegradc 15200000.nvdisplay: blank - powerdown
[70557.843693] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[70557.844428] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[70557.844510] tegradc 15200000.nvdisplay: unblank
[70557.845327] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[70557.845442] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[70557.845917] Parent Clock set for DC plld2
[70557.850368] tegradc 15200000.nvdisplay: hdmi: pclk:151473K prod-setting:prod_c_hdmi_111m_223m
[70557.852005] tegradc 15200000.nvdisplay: unblank
[70572.345482] eqos ioctl: HW PTP not running
[70572.352350] sample_radar_re[6085]: unhandled level 2 translation fault (11) at 0x00000000, esr 0x92000006
[70572.352358] pgd = ffffffc1c542a000
[70572.352809] [00000000] *pgd=0000000211d56003
[70572.356758] , *pud=0000000211d56003
[70572.356806] , *pmd=0000000000000000
[70572.356844] CPU: 1 PID: 6085 Comm: sample_radar_re Not tainted 4.9.38-rt25-tegra #1
[70572.356847] Hardware name: drive-px2-autocruise (DT)
[70572.356851] task: ffffffc178cbd700 task.stack: ffffffc165364000
[70572.356856] PC is at 0x7fa0794104
[70572.356858] LR is at 0x7fa0794dcc
[70572.356861] pc : [<0000007fa0794104>] lr : [<0000007fa0794dcc>] pstate: 60000000
[70572.356863] sp : 0000007ff3ba4cd0
[70572.356866] x29: 0000007ff3ba4cd0 x28: 000000000000000a
[70572.356872] x27: 0000000005201fc0 x26: 0000000005201f58
[70572.356877] x25: 00000000000015b2 x24: 0000000000000000
[70572.356881] x23: 0000000000000000 x22: 0000007ff3ba4e30
[70572.356886] x21: 0000000000000000 x20: 0000007ff3ba4eb0
[70572.356891] x19: 0000000005201fc0 x18: 0000000000000000
[70572.356895] x17: 0000007f9dfd43b0 x16: 0000007fa25005c0
[70572.356899] x15: 0000007fa2636cc0 x14: 0000000000000000
[70572.356904] x13: ffffffffffffffff x12: 0000000000000005
[70572.356909] x11: 000000000000000a x10: 0000007f9e064e18
[70572.356913] x9 : 0000007f9e065718 x8 : 0000000005201fcc
[70572.356918] x7 : 0000000005201fdc x6 : 0000000000000000
[70572.356922] x5 : 0000000000000000 x4 : 01010101b2150002
[70572.356926] x3 : 0000000000000000 x2 : 0000000000000000
[70572.356930] x1 : 0000000000000001 x0 : 0000000005201fec
[70572.356945] vdso base = 0x7fa2635000
[70935.345698] eqos ioctl: HW PTP not running
[70935.351744] sample_radar_re[6252]: unhandled level 2 translation fault (11) at 0x00000000, esr 0x92000006
[70935.351751] pgd = ffffffc1646ac000
[70935.352195] [00000000] *pgd=00000001db86c003
[70935.355996] , *pud=00000001db86c003
[70935.356050] , *pmd=0000000000000000
[70935.356064] CPU: 2 PID: 6252 Comm: sample_radar_re Not tainted 4.9.38-rt25-tegra #1
[70935.356067] Hardware name: drive-px2-autocruise (DT)
[70935.356071] task: ffffffc191c59d00 task.stack: ffffffc1cfc60000
[70935.356075] PC is at 0x7fa04e8104
[70935.356077] LR is at 0x7fa04e8dcc
[70935.356080] pc : [<0000007fa04e8104>] lr : [<0000007fa04e8dcc>] pstate: 60000000
[70935.356082] sp : 0000007fc075acd0
[70935.356085] x29: 0000007fc075acd0 x28: 000000000000000a
[70935.356091] x27: 0000000005201fc0 x
