Hello, I’m trying to use isaac sim with lidar & robot. With full warehouse environment and Nova_Carter_ROS, when i click play button, then [Error] [omni.isaac.core_nodes] CUDA error 801: cudaErrorNotSupported - operation not supported) in terminal. How to solve this problem?
Related topics
| [Error] [omni.isaac.core_nodes] CUDA error 801: cudaErrorNotSupported - operation not supported) | 4 | 699 | April 16, 2024 | |
| CUDA error 801: cudaErrorNotSupported - operation not supported | 2 | 243 | October 7, 2024 | |
| [Error] [omni.syntheticdata.plugin] CUDA error 801: cudaErrorNotSupported - operation not supported) | 2 | 636 | June 21, 2022 | |
| Isaac sim startup segmentation fault - Could not find registered CUDA function | 16 | 2442 | April 5, 2024 | |
| Failed to set the CUDA device -1 running Isaac Sim on Fedora | 4 | 1003 | April 5, 2024 | |
| Isaac sim ROS2 lidar crashes | 14 | 1441 | January 11, 2024 | |
| Cuda update broke Lidar in Issac sim | 5 | 380 | March 14, 2025 | |
| Help with CUDA Driver CALL Failed error in IsaacSim 4.5.0 | 3 | 381 | May 27, 2025 | |
| Failed to set the CUDA device -1 running Isaac Sim | 2 | 1593 | February 19, 2023 | |
| After upgrading to Isaac SIM 4 version, RTX Lidar sensor is not working properly | 13 | 675 | May 16, 2025 |
