When possible, please provide the following info:
Hardware Platform: [: DRIVE AGX Xavier™ Developer Kit]
Software Version: [: DRIVE Software 10]
Host Machine Version: [: native Ubuntu 18.04]
SDK Manager Version: [: 1.1.0.6343]
- 09:27:54 INFO : Flash Xavier A+B in parallel : Processor found in ttyUSB3
- 09:27:54 INFO : Flash Xavier A+B in parallel : Aurix port /dev/ttyUSB3 found. Fetching board revision from InfoROM …
- 09:27:57 INFO : Flash Xavier A+B in parallel : Failed to bind partitions!
- 09:27:59 INFO : Flash Xavier A+B in parallel : pdkinstaller cannot continue! Check the log file for details: /home/j1/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/pdkinstaller/pdkinstaller.log
- 09:27:59 ERROR : Flash Xavier A+B in parallel :
- 09:27:59 ERROR : Flash Xavier A+B in parallel : [exec_command]: /bin/bash -c cd pdkinstaller && ./pdkinstaller --installtype bindflash --boardtype ES --pdkinstalledpath /home/j1/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS --configjson ./manifests/install_pdk_config/av_ddp_pegasus_hyp71_linux_tegraAB_install_config.json --consoleout enable; [error]: exit status 140
- 09:27:59 INFO : Flash Xavier A+B in parallel : [ Component Install Finished with Error ]
- 09:27:59 INFO : Flash Xavier A+B in parallel : [ 529.35 MB used. Disk Avail: 319.93 GB ]
- 09:27:59 INFO : Flash Xavier A+B in parallel : [ NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP Install took 8m44s ]
- 09:27:59 ERROR : Flash Xavier A+B in parallel : [error]: Run commands failed at step Install: command cd pdkinstaller && ./pdkinstaller --installtype bindflash --boardtype ES --pdkinstalledpath /home/j1/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS --configjson ./manifests/install_pdk_config/av_ddp_pegasus_hyp71_linux_tegraAB_install_config.json --consoleout enable finished with error
- 09:27:59 ERROR : Flash Xavier A+B in parallel : command terminated with error
- 09:28:01 ERROR : Flash Xavier A+B in parallel : Install ‘Flash Xavier A+B in parallel’ failure, command < using adapter to install NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX to /home/j1/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX > terminated with error.
- 09:28:03 INFO : All done!
pdkinstaller.log (15.5 KB)
