In my xform prim, the mesh is composed of several GeomSubsets and I am assigning a separate Material to each of them. However, since version 2023.1.1, the Material of the GeomSubset is not being applied, but only when the Material is applied to the parent Mesh.
How can I resolve this issue?
Hi @defective - Can you please provide information about the asset where you are seeing this issue?
Hello , I am facing a similar issue while going through the " Learn OpenUSD: Asset Structure Principles and Content Aggregation" tutorial. The GeomSubset material is not showing up using the steps mentioned.
