After installing Drive5 onto a PX2, the gmsl camera image stream appears to have a green tint over the images. I tried with two cameras and the same effect appears in both.
Prior to upgrading to drive5, the camera color was normal.
Any idea as to why this is so/ how to correct this?
Dear mpechon,
Could you please let us know you’re using application and upload the abnormal screen? Thanks.
I am using both the sample for Driveworks in the /usr/local/driveworks/bin
Dear mpechon,
It seems this symptom is from RCCB camera.
Could you please let me know you’re using command for the camera and you used DriveWorks version? Thanks.
Dear SteveNV,
Thanks for the hint; it works now under the camera type ar0231-rccb-ss3322
I was previously using the command ./sample_camera_multiple_gmsl --selector-mask=0011 without specifying camera type. Driveworks version: 0.6
Hello all,
same problem is here after upgarde px2 to 0.6 gmsl cameras output became greenish. Do you have any idea?
Setting the camera type to the correct type fixed it for me.
Cheers
Linn
