I am trying to run the DriveWork sample program which called sample_camera_gmsl with Sekonix SF3325 camera on E3350 , I didn’t use any additional command option (it means i just type ./sample_camera_gmsl), and the output is very strange, here is the screenshot: [url]https://imgur.com/sKpW8Hs[/url].
Is this just a hardware issue or i just miss type something on command option?
Dear andy_su,
The default value of camera-type parameter is ar0231-rccb-bae-sf3324.
Could you check using ./sample_camera_gmsl --camera-type=ar0231-rccb-bae-sf3325
I got the same result which is of low-quality output. I also using ./sample_camera_gmsl --camera-type=ar0231-rccb-bae-sf3325 --cameragroup=a, but the output still the same.
Dear andy_su,
DO you see same issue outside as well? The camera capture mode does not suit in office premises and we also notice pink color artifacts when moving camera.
Hallo, we got also the same problem. Moving camera rapidly produces really ugly pink color on the object edges. Is this normal? Tried also outside same problem but not so prominent.
