=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2023.07.03 10:43:22 =~=~=~=~=~=~=~=~=~=~=~=
ÿ⍊[0000.064] I> MB1 (version: 0.32.0.0-t234-54845784-57325615)
[0000.069] I> t234-A01-0-Silicon (0x12347) Prod
[0000.074] I> Boot-mode : Coldboot
[0000.077] I> Emulation:
[0000.079] I> Entry timestamp: 0x00000000
[0000.083] I> last_boot_error: 0x0
[0000.086] I> BR-BCT: preprod_dev_sign: 0
[0000.090] I> rst_source: 0x0, rst_level: 0x0
[0000.094] I> Task: Bootchain select WAR set (0x5000ba65)
[0000.099] I> Task: Enable SLCG (0x5000bab1)
[0000.103] I> Task: CRC check (0x5001ea19)
[0000.107] I> Task: Initialize MB2 params (0x5000cb51)
[0000.113] I> MB2-params @ 0x40060000
[0000.116] I> Task: Crypto init (0x5001d981)
[0000.120] I> Task: Secure debug controls (0x5000c0a9)
[0000.125] I> Task: strap war set (0x5000ba2d)
[0000.129] I> Task: Initialize SOC Therm (0x5001bd35)
[0000.134] I> Task: Program NV master stream id (0x5000c05d)
[0000.139] I> Task: Verify boot mode (0xd4820f1)
[0000.145] I> Task: Alias fuses (0x5001095d)
[0000.150] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.157] I> Task: Print SKU type (0x5000f5f1)
[0000.162] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0000.167] I> FUSE_OPT_GPC_DISABLE = 0x00000001
[0000.171] I> FUSE_OPT_TPC_DISABLE = 0x0000000f
[0000.175] I> FUSE_OPT_DLA_DISABLE = 0x00000002
[0000.180] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.184] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.188] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.193] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.197] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0000.201] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.206] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.210] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.214] I> FUSE_SKU_INFO_0 = 0xd4
[0000.217] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.221] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.225] I> SKU: Prod
[0000.227] I> Task: Boost clocks (0x500148a1)
[0000.231] I> Initializing PLLC2 for AXI_CBB.
[0000.235] I> AXI_CBB : src = 35, divisor = 0
[0000.239] I> Task: Voltage monitor (0x50014b49)
[0000.244] I> VMON: Vmon re-calibration and fine tuning done
[0000.249] I> Task: UPHY init (0x5000d065)
[0000.255] I> HSIO UPHY init done
[0000.258] E> Skipping GBE UPHY config
[0000.262] I> Task: Boot device init (0x50000be9)
[0000.266] I> Boot_device: QSPI_FLASH instance: 0
[0000.271] I> Qspi clock source : pllc_out0
[0000.275] I> QSPI Flash: Macronix 64MB
[0000.279] I> QSPI-0l initialized successfully
[0000.283] I> Task: TSC init (0x50020a4d)
[0000.287] I> Task: Load membct (0x50011fe9)
[0000.291] I> RAM_CODE 0x4000421
[0000.294] I> Loading MEMBCT
[0000.296] I> Slot: 0
[0000.299] I> Binary[0] block-0 (partition size: 0x40000)
[0000.304] I> get_binary_info: Binary name: MEM-BCT-0
[0000.309] I> Size of crypto header is 8192
[0000.312] I> BCH load address is : 0x40050000
[0000.317] I> Size of crypto header is 8192
[0000.321] I> BCH of MEM-BCT-0 read from storage
[0000.325] I> BCH address is : 0x40050000
[0000.329] I> MEM-BCT-0 header integrity check is success
[0000.334] I> Binary magic in BCH component 0 is MEM0
[0000.339] I> component binary type is 0
[0000.343] I> MEM-BCT-0 binary is read from storage
[0000.348] I> MEM-BCT-0 binary integrity check is success
[0000.353] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.360] I> RAM_CODE 0x4000421
[0000.365] I> RAM_CODE 0x4000421
[0000.369] I> Task: Load Page retirement list (0x500115b1)
[0000.375] I> Task: SDRAM params override (0x50011fc5)
[0000.380] I> Task: Save mem-bct info (0x50014fa1)
[0000.384] I> Task: Carveout allocate (0x50015005)
[0000.389] I> RCM blob carveout will not be allocated
[0000.393] I> ECC region[0]: Start:0x0, End:0x0
[0000.398] I> ECC region[1]: Start:0x0, End:0x0
[0000.402] I> ECC region[2]: Start:0x0, End:0x0
[0000.406] I> ECC region[3]: Start:0x0, End:0x0
[0000.410] I> ECC region[4]: Start:0x0, End:0x0
[0000.415] I> Non-ECC region[0]: Start:0x80000000, End:0x280000000
[0000.421] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.425] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.430] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.435] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.444] I> allocated(CO:31) base:0x278000000 size:0x8000000 align: 0x8000000
[0000.451] I> allocated(CO:43) base:0x274000000 size:0x4000000 align: 0x200000
[0000.458] I> allocated(CO:20) base:0x272000000 size:0x2000000 align: 0x2000000
[0000.466] I> allocated(CO:24) base:0x270000000 size:0x2000000 align: 0x2000000
[0000.473] I> allocated(CO:28) base:0x26e000000 size:0x2000000 align: 0x2000000
[0000.480] I> allocated(CO:22) base:0x26d000000 size:0x1000000 align: 0x1000000
[0000.487] I> allocated(CO:35) base:0x26c200000 size:0xe00000 align: 0x10000
[0000.494] I> allocated(CO:02) base:0x26b800000 size:0x800000 align: 0x800000
[0000.501] I> allocated(CO:03) base:0x26b000000 size:0x800000 align: 0x800000
[0000.507] I> allocated(CO:06) base:0x26a800000 size:0x800000 align: 0x800000
[0000.514] I> allocated(CO:10) base:0x26a000000 size:0x800000 align: 0x800000
[0000.521] I> allocated(CO:56) base:0x269800000 size:0x800000 align: 0x200000
[0000.528] I> allocated(CO:07) base:0x269400000 size:0x400000 align: 0x400000
[0000.535] I> allocated(CO:33) base:0x269000000 size:0x400000 align: 0x200000
[0000.542] I> allocated(CO:23) base:0x26c000000 size:0x200000 align: 0x200000
[0000.549] I> allocated(CO:01) base:0x268f00000 size:0x100000 align: 0x100000
[0000.556] I> allocated(CO:04) base:0x268e00000 size:0x100000 align: 0x100000
[0000.563] I> allocated(CO:05) base:0x268d00000 size:0x100000 align: 0x100000
[0000.570] I> allocated(CO:08) base:0x268c00000 size:0x100000 align: 0x100000
[0000.577] I> allocated(CO:09) base:0x268b00000 size:0x100000 align: 0x100000
[0000.584] I> allocated(CO:15) base:0x268a00000 size:0x100000 align: 0x100000
[0000.591] I> allocated(CO:17) base:0x268900000 size:0x100000 align: 0x100000
[0000.597] I> allocated(CO:27) base:0x268800000 size:0x100000 align: 0x100000
[0000.604] I> allocated(CO:42) base:0x268700000 size:0x100000 align: 0x100000
[0000.611] I> allocated(CO:54) base:0x268680000 size:0x80000 align: 0x80000
[0000.618] I> allocated(CO:34) base:0x268670000 size:0x10000 align: 0x10000
[0000.625] I> allocated(CO:47) base:0x268200000 size:0x400000 align: 0x200000
[0000.632] I> allocated(CO:72) base:0x268000000 size:0x200000 align: 0x10000
[0000.639] I> allocated(CO:48) base:0x268650000 size:0x20000 align: 0x10000
[0000.645] I> allocated(CO:69) base:0x268630000 size:0x20000 align: 0x10000
[0000.652] I> allocated(CO:49) base:0x268620000 size:0x10000 align: 0x10000
[0000.659] I> allocated(CO:50) base:0x268610000 size:0x10000 align: 0x10000
[0000.665] I> NSDRAM base: 0x80000000, end: 0x268670000
[0000.670] I> Task: Thermal check (0x50021d55)
[0000.675] I> max_chip_limit = 105
[0000.678] I> min_chip_limit = -28
[0000.681] I> max temp read = 33
[0000.684] I> min temp read = 32
[0000.687] I> Task: Update FSI SCR with thermal fuse data (0x50021e61)
[0000.693] I> Task: Enable WDT 5th expiry (0x50021a41)
[0000.698] I> Task: I2C register (0x50000b85)
[0000.702] I> Task: Reset FSI (0x500148b1)
[0000.706] I> Task: Pinmux init (0x5001397d)
[0000.710] I> skipped mmio_addr = 0x9240008
[0000.714] I> skipped mmio_addr = 0x9240000
[0000.718] I> skipped mmio_addr = 0x9240010
[0000.722] I> skipped mmio_addr = 0x9240018
[0000.726] I> skipped mmio_addr = 0x9240020
[0000.730] I> skipped mmio_addr = 0x9240030
[0000.734] I> skipped mmio_addr = 0x9240028
[0000.738] I> skipped mmio_addr = 0x9240038
[0000.742] I> skipped mmio_addr = 0x9240040
[0000.746] I> skipped mmio_addr = 0x9240048
[0000.750] I> skipped mmio_addr = 0x9241000
[0000.754] I> skipped mmio_addr = 0x9241008
[0000.758] I> skipped mmio_addr = 0x9241010
[0000.762] I> skipped mmio_addr = 0x9241018
[0000.765] I> skipped mmio_addr = 0x9241020
[0000.769] I> skipped mmio_addr = 0x9241028
[0000.773] I> skipped mmio_addr = 0x9241030
[0000.777] I> skipped mmio_addr = 0x9241038
[0000.781] I> skipped mmio_addr = 0x9241040
[0000.785] I> skipped mmio_addr = 0x9242000
[0000.789] I> skipped mmio_addr = 0x9242008
[0000.793] I> Task: Prod config init (0x50013ddd)
[0000.797] I> Task: Pad voltage init (0x50013a2d)
[0000.802] I> Task: Prod init (0x50013e21)
[0000.806] I> Task: Common rail init (0x50014575)
[0000.810] I> DONE: Thermal config
[0000.814] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.822] I> DONE: SOC rail config
[0000.826] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.833] I> DONE: MEMIO rail config
[0000.837] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0000.843] I> DONE: GPU rail info
[0000.847] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0000.853] I> DONE: CV rail info
[0000.856] I> Task: Mem clock src (0x50011de9)
[0000.860] I> Task: Misc. board config (0x5001461d)
[0000.865] W> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.871] I> Task: SDRAM init (0x50011ded)
[0000.875] I> SDRAM-params @ 0xd485000
[0000.878] I> MemoryType: 4 MemBctRevision: 1
[0000.885] I> MSS code-drop: NvBootSdramInit
[0000.889] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0000.896] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0000.904] I> MSS CAR: Init PLLM
[0000.907] I> MSS CAR: Init PLLHUB
[0000.912] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.923] I> mb1_sdram_init Done !
[0000.926] I> SDRAM Size in Total 0x200000000
[0000.930] I> Task: Dram Ecc scrub (0x500116f5)
[0000.935] I> Task: DRAM alias check (0x50011fbd)
[0000.946] I> Task: Program NSDRAM carveout (0x50015961)
[0000.952] I> NSDRAM carveout encryption is enabled
[0000.957] I> Program NSDRAM carveout
[0000.962] I> Task: Register checker (0x50011fc1)
[0000.969] I> Task: Enable clock-mon (0x50020a35)
[0000.975] I> FMON: Fmon re-programming done
[0000.979] I> Task: Mapper init (0x5001ef4d)
[0000.984] I> Task: SC7 Context Init (0x50020d3d)
[0000.990] I> Task: CCPLEX IST init (0x5000c925)
[0000.996] I> Task: CPU WP0 (0x5000bb15)
[0001.001] I> Loading MCE
[0001.004] I> Slot: 0
[0001.006] I> Binary[8] block-0 (partition size: 0x80000)
[0001.012] I> get_binary_info: Binary name: MCE
[0001.017] I> Size of crypto header is 8192
[0001.022] I> BCH load address is : 0x4003e000
[0001.027] I> Size of crypto header is 8192
[0001.032] I> BCH of MCE read from storage
[0001.036] I> BCH address is : 0x4003e000
[0001.041] I> MCE header integrity check is success
[0001.046] I> Binary magic in BCH component 0 is MTSM
[0001.052] I> component binary type is 8
[0001.056] I> Size of crypto header is 8192
[0001.062] I> MCE binary is read from storage
[0001.068] I> MCE binary integrity check is success
[0001.073] I> Binary MCE loaded successfully at 0x40000000 (0x2c880)
[0001.080] I> Size of crypto header is 8192
[0001.095] I> Size of crypto header is 8192
[0001.099] I> Sending WP0 mailbox command to PSC
[0001.110] I> Task: XUSB Powergate (0x50000b91)
[0001.115] I> Skipping powergate XUSB.
[0001.119] I> Task: MB1 fixed firewalls (0x5002006d)
[0001.130] W> Firewall readback mismatch
[0001.135] W> Firewall readback mismatch
[0001.143] W> Firewall readback mismatch
[0001.153] I> Task: Load bpmp-fw (0x500203c9)
[0001.158] I> Slot: 0
[0001.161] I> Binary[15] block-0 (partition size: 0x180000)
[0001.167] I> get_binary_info: Binary name: BPMP_FW
[0001.172] I> Size of crypto header is 8192
[0001.177] I> BCH load address is : 0x807fe000
[0001.182] I> Size of crypto header is 8192
[0001.187] I> BCH of BPMP_FW read from storage
[0001.191] I> BCH address is : 0x807fe000
[0001.197] I> BPMP_FW header integrity check is success
[0001.202] I> Binary magic in BCH component 0 is BPMF
[0001.207] I> component binary type is 15
[0001.212] I> Size of crypto header is 8192
[0001.227] I> BPMP_FW binary is read from storage
[0001.234] I> BPMP_FW binary integrity check is success
[0001.240] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xfddc0)
[0001.248] I> Slot: 0
[0001.250] I> Binary[16] block-10000 (partition size: 0x400000)
[0001.257] I> get_binary_info: Binary name: BPMP_FW_DTB
[0001.262] I> Size of crypto header is 8192
[0001.267] I> BCH load address is : 0x807fc000
[0001.272] I> Size of crypto header is 8192
[0001.277] I> BCH of BPMP_FW_DTB read from storage
[0001.282] I> BCH address is : 0x807fc000
[0001.287] I> BPMP_FW_DTB header integrity check is success
[0001.293] I> Binary magic in BCH component 0 is BPMD
[0001.299] I> component binary type is 16
[0001.303] I> Size of crypto header is 8192
[0001.309] I> BPMP_FW_DTB binary is read from storage
[0001.315] I> BPMP_FW_DTB binary integrity check is success
[0001.321] I> Binary BPMP_FW_DTB loaded successfully at 0x807dbff0 (0x1fe80)
[0001.329] I> Task: Load psc-fw (0x50020551)
[0001.335] I> Slot: 0
[0001.337] I> Binary[17] block-0 (partition size: 0xc0000)
[0001.343] I> get_binary_info: Binary name: PSC_FW
[0001.348] I> Size of crypto header is 8192
[0001.353] I> BCH load address is : 0x80ffe000
[0001.358] I> Size of crypto header is 8192
[0001.363] I> BCH of PSC_FW read from storage
[0001.368] I> BCH address is : 0x80ffe000
[0001.373] I> PSC_FW header integrity check is success
[0001.378] I> Binary magic in BCH component 0 is PFWP
[0001.384] I> component binary type is 17
[0001.388] I> Size of crypto header is 8192
[0001.396] I> PSC_FW binary is read from storage
[0001.402] I> PSC_FW binary integrity check is success
[0001.408] I> Binary PSC_FW loaded successfully at 0x80000000 (0x59980)
[0001.416] I> Task: Load nvdec-fw (0x500205c5)
[0001.421] I> Slot: 0
[0001.424] I> Binary[7] block-0 (partition size: 0x100000)
[0001.430] I> get_binary_info: Binary name: NVDEC
[0001.435] I> Size of crypto header is 8192
[0001.439] I> BCH load address is : 0x800fe000
[0001.445] I> Size of crypto header is 8192
[0001.450] I> BCH of NVDEC read from storage
[0001.454] I> BCH address is : 0x800fe000
[0001.459] I> NVDEC header integrity check is success
[0001.465] I> Binary magic in BCH component 0 is NDEC
[0001.470] I> component binary type is 7
[0001.474] I> Size of crypto header is 8192
[0001.482] I> NVDEC binary is read from storage
[0001.487] I> NVDEC binary integrity check is success
[0001.493] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.500] I> Size of crypto header is 8192
[0001.518] I> Task: Load tsec-fw (0x5002097d)
[0001.524] I> TSEC-FW load support not enabled
[0001.528] I> Task: GPIO interrupt map (0x500147b5)
[0001.534] I> Task: SC7 context save (0x50020d79)
[0001.540] I> Slot: 0
[0001.542] I> Binary[27] block-0 (partition size: 0x100000)
[0001.549] I> get_binary_info: Binary name: BR_BCT
[0001.554] I> Size of crypto header is 8192
[0001.558] I> Size of crypto header is 8192
[0001.563] I> BR_BCT binary is read from storage
[0001.568] I> BR_BCT binary integrity check is success
[0001.574] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.581] I> Slot: 0
[0001.584] I> Binary[13] block-0 (partition size: 0x30000)
[0001.590] I> get_binary_info: Binary name: SC7-FW
[0001.595] I> Size of crypto header is 8192
[0001.599] I> Size of crypto header is 8192
[0001.604] I> BCH load address is : 0xa0002000
[0001.609] I> Size of crypto header is 8192
[0001.614] I> BCH of SC7-FW read from storage
[0001.619] I> BCH address is : 0xa0002000
[0001.624] I> SC7-FW header integrity check is success
[0001.629] I> Binary magic in BCH component 0 is WB0B
[0001.635] I> component binary type is 13
[0001.639] I> Size of crypto header is 8192
[0001.645] I> SC7-FW binary is read from storage
[0001.651] I> SC7-FW binary integrity check is success
[0001.656] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x26db0)
[0001.664] I> Slot: 0
[0001.666] I> Binary[22] block-0 (partition size: 0x30000)
[0001.672] I> get_binary_info: Binary name: PSC_RF
[0001.677] I> Size of crypto header is 8192
[0001.682] I> Size of crypto header is 8192
[0001.687] I> BCH load address is : 0xa002adb0
[0001.692] I> Size of crypto header is 8192
[0001.697] I> BCH of PSC_RF read from storage
[0001.701] I> BCH address is : 0xa002adb0
[0001.707] I> PSC_RF header integrity check is success
[0001.712] I> Binary magic in BCH component 0 is PSCR
[0001.717] I> component binary type is 22
[0001.721] I> Size of crypto header is 8192
[0001.727] I> PSC_RF binary is read from storage
[0001.733] I> PSC_RF binary integrity check is success
[0001.738] I> Binary PSC_RF loaded successfully at 0xa002cdb0 (0x1b140)
[0001.761] I> Task: Save WP0 payload to SC7 ctx (0x50021725)
[0001.768] I> Task: Load MB2rf binary to SC7 ctx (0x500216b9)
[0001.774] I> Slot: 0
[0001.777] I> Binary[14] block-0 (partition size: 0x20000)
[0001.783] I> get_binary_info: Binary name: MB2_RF
[0001.788] I> Size of crypto header is 8192
[0001.792] I> Size of crypto header is 8192
[0001.797] I> BCH load address is : 0xa00d6a48
[0001.802] I> Size of crypto header is 8192
[0001.807] I> BCH of MB2_RF read from storage
[0001.812] I> BCH address is : 0xa00d6a48
[0001.817] I> MB2_RF header integrity check is success
[0001.822] I> Binary magic in BCH component 0 is MB2R
[0001.828] I> component binary type is 14
[0001.832] I> Size of crypto header is 8192
[0001.838] I> MB2_RF binary is read from storage
[0001.843] I> MB2_RF binary integrity check is success
[0001.849] I> Binary MB2_RF loaded successfully at 0xa00d8a48 (0x1bfa0)
[0001.857] I> Task: Save Fuse-Bypass data to SC7 ctx (0x50021621)
[0001.864] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0001.872] I> SC7 context fuse-bypass data is empty
[0001.877] I> Task: Save PMIC data to SC7 ctx (0x5002144d)
[0001.883] I> Task: Save I2C bus freq data to SC7 ctx (0x500213d9)
[0001.890] I> Task: Save SOCTherm data to SC7 ctx (0x50021365)
[0001.897] I> Task: Save FMON data to SC7 ctx (0x500212f1)
[0001.904] I> Task: Save VMON data to SC7 ctx (0x50021279)
[0001.910] I> Task: Save TZDRAM data to SC7 ctx (0x5002178d)
[0001.917] I> Task: Save GPIO int data to SC7 ctx (0x50021561)
[0001.923] I> Task: Save clock data to SC7 ctx (0x50021205)
[0001.930] I> Task: Save debug data to SC7 ctx (0x50021191)
[0001.941] I> SC7 context save done
[0001.945] I> Task: Load MB2/Applet/FSKP (0x5000ca55)
[0001.951] I> Loading MB2
[0001.954] I> Slot: 0
[0001.956] I> Binary[6] block-0 (partition size: 0x80000)
[0001.962] I> get_binary_info: Binary name: MB2
[0001.967] I> Size of crypto header is 8192
[0001.971] I> BCH load address is : 0x8007e000
[0001.977] I> Size of crypto header is 8192
[0001.982] I> BCH of MB2 read from storage
[0001.986] I> BCH address is : 0x8007e000
[0001.991] I> MB2 header integrity check is success
[0001.996] I> Binary magic in BCH component 0 is MB2B
[0002.001] I> component binary type is 6
[0002.006] I> Size of crypto header is 8192
[0002.015] I> MB2 binary is read from storage
[0002.021] I> MB2 binary integrity check is success
[0002.026] I> Binary MB2 loaded successfully at 0x80000000 (0x68ee0)
[0002.034] I> Task: Map CCPLEX SHARED carveout (0x5000cbf9)
[0002.040] I> Task: Prepare MB2 params (0x5000cca9)
[0002.047] I> BR-BCT Boot Chain Fields
[0002.051] I> u32_non_gpio_select_boot_chain : 0
[0002.056] I> u32_num_boot_chains : 2
[0002.061] I> bf_bl_gpio_select_boot_chain_1b : 0
[0002.067] I> Task: Dram ecc test (0x50011791)
[0002.072] I> Task: Misc NV security settings (0x5000c529)
[0002.079] I> NVDEC sticky bits programming done
[0002.084] I> Successfully powergated NVDEC
[0002.088] I> Task: Disable/Reload WDT (0x50021a99)
[0002.094] I> Task: Program misc carveouts (0x50015381)
[0002.100] I> Program IPC carveouts
[0002.107] I> SLCG Global override status := 0x0
[0002.112] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-9c429857)
I> Emulation:
I> Entry timestamp: 0x0020d203
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x269800000, size:0x800000]
I> Task: ARI update carveout TZDRAM (0x50001e80)
I> Task: Enable hot-plug capability (0x50026c6c)
I> Task: PSC mailbox init (0x50016a7c)
I> Task: Crypto init (0x500065a8)
I> Task: Enable GP-SE clock (0x50001fe4)
I> Task: DICE Identity init (0x50019e50)
I> DICE is not enabled.
I> Task: OEM SC7 context save init (0x50019550)
I> Task: I2C register (0x50001e44)
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001e2c)
I> Task: Program CBB PCIE AMAP regions (0x50019b64)
I> Task: Boot device init (0x50001d74)
I> Task: Partition Manager Init (0x50001d70)
I> Found 57 partitions in QSPI_FLASH (instance 0)
I> Task: Load and authenticate registered FWs (0x5001ce48)
I> Task: Load AUXP FWs (0x5002680c)
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x268c00000
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x268900000
I> dce : oem authentication of header done
I> dce : meta-blob integrity check is success.
I> dce : will be decompressed at 0x272000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> dce : decompressed to 9445504 bytes
I> dce: plain binary integrity check is success
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x272000000
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x269400000
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x268d00000
I> Task: Carveout setup (0x5001f55c)
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM (0x50016950)
I> Task: Enable FSI VMON (0x500164d8)
I> Task: Validate FSI Therm readings (0x50016530)
I> Task: Restore XUSB sec (0x50001d44)
I> Task: Enable FSI SE clock (0x50016ed8)
I> Task: Initialize SBSA UART CAR (0x50001f48)
I> Task: Ratchet update (0x50027d08)
W> OPTIN fuse not set, skip ratchet update
I> Task: Initialize CPUBL Params (0x50017e0c)
I> CPUBL-params @ 0x26e000000
I> Task: Prepare eeprom data (0x50017bd8)
I> Task: FSI padctl context save (0x500196e0)
E> Skipping FSI padctl config save: fsi not enabled
I> Task: Unpowergate APE (0x50017640)
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: OEM firewalls (0x5002397c)
I> OEM firewalls configured
I> Task: Powergate APE (0x500177b4)
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings (0x50023dd0)
I> Task: Unhalt AUXPs (0x50026a74)
I> Unhalting SPE..
I> Enabling combined UART
ÿýÿe: early_init
vic initialized
tsc initialized
aon lic initialized
spe: tag is 243b265b351d6bb9cc7b2e3acc5d90f8
spe: SafeRTOS v8.4
spe: init
scheduler initialized
aon hsp initialized
tag initialized
tcu initialized
bpmp ipc initialized
spe: late init
cpu_nic clock initialized
apb clock initialized
pm initialized
bpmp hsp initialized
top1 hsp initialized
ccplex ipc initialized
spe: start scheduler
ÿ> Task: Trigger mailbox for PSC-BL1 exit (0x50016afc)
I> Sending opcode 0x4d420802 to psc
ÿ牎FO: Entering psc_monitor_init!
INFO: GSC22 BOM:0x26d002000 SIZE:0x1000000 CLIENT_ACCESS1:00180000
INFO: PSCFW BUILD VERSION: 8a33b23-73b589c-8a15f76-rel-t234
INFO: mstatus:0xa00000808
INFO: Supervisor entry_point:c108c00
ÿቾ Received ACK from psc
I> Tasÿ牎FO: MONITOR: user task addr:0x26d022000, blob offset:0x00020000
INFO: MONITOR: populated user images:13
INFO: mret to Supervisor!
INFO: psc supervisor init.
INFO: psc_irq_init...
INFO: enter idle task.
ÿ⊢pmp: socket 0
bpmp: base binary md5 is 1377b684fe55be78e1d7fc3e0f143b55
bpmp: combined binary md5 is 463f4d5b75234b74bb7f05b524d2a015
bpmp: firmware tag is 463f4d5b75234b74bb7f-1377b684fe5
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized hwwdt
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
471 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized tj_init
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
ÿ Staÿ⩮itialized avfs_clk_platform
initialized powergate
ÿᲴ secure NOR provision (0xÿ⩮itialized dvs
initialized clk_mach_config
initialized pm
initialized suspend
initialized strap
initialized mce_dbell
ÿᵰ01997c)
I> Task: Load FSI keyblob (0x50016f20)
I> Task: Unhalt AUXPs (0x50026a7c)
I> SCE unhalt skipped
I> Unhalting RCE
I> RCE unhalt successful
I> DCE unhalt successful
I> APE unhalt skipped
I> FSI unhalt skipped
I> Task: Load CPUBL (0x50017f04)
I> Task: Load TOS (0x50018608)
I> Task: Load and authenticate registered FWsÿ⩮itialized emcÿ因 2.481116] Camera-FW on t234-rce-safe started
ÿ⍿唃U early console enaÿ⊩nitialized emc_mrq
initialized clk_cal
initialized ÿ墬ed.
ÿ⵰hy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
initialized uphy
initialized pg_late
initialized pg_mrq_init
swdtimer_init: 0 reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
ÿ芿ᠨ0x5001ce48)
I> Partition name: A_cpuÿ⩮itialized clk_cal_late
initialized noc_late
initialized cvc
ÿ᭢ootloader
I> Size of partitiÿ⩮itialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initialized fuse_late
initialized mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: init complete
ÿ因 2.602264] Camera-FW on t234-rce-safe ready SHA1=97e50cbf (crt 17.517 ms, total boot 139.727 ms)
ÿᯮ: 3670016
I> Binary@ device:3/0 block-24832 (partition size: 0x380000), name: A_cpu-bootloader
ÿ脃E: FW Boot Done
ÿቾ Partition name: A_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-32000 (partition size: 0x400000), name: A_secure-os
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x268200000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0x277dfe000
I> Relocating OP-TEE dtb from: 0x277eff770 to 0x268630000, size: 0x1976
I> [0] START: 0x80000000, SIZE: 0x1e8670000
I> [1] START: 0x26e000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: A_eks
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x269800200
I> EKB detected (length: 0x410) @ VA:0x269800200
I> Task: Prepare TOS params (0x50018580)
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0x268630000
I> Task: OEM SC7 context save (0x500197dc)
I> OEM sc7 context saved
I> Task: Disable MSS perf stats (0x50026b08)
I> Task: Program display sticky bits (0x50026a84)
I> Task: Storage device deinit (0x50001eec)
I> Task: SMMU external bypass disable (0x50016a60)
I> Task: SMMU init (0x5001697c)
I> Task: Program GICv3 registers (0x50026ba8)
I> Task: Audit firewall settings (0x50023bd0)
I> Task: Bootchain failure check (0x50002434)
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> MB2 finished
ÿ䎏TICE: BL31: v2.6(release):07eea4970
NOTICE: BL31: Built : 07:55:15, Mar 19 2023
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.19 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Sun Mar 19 15:02:44 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: WARNING: Test OEM keys are being used!
I/TC: This is only for TZ-SE testing and should NOT be used for a shipping product!
I/TC: Primary CPU switching to normal world boot
ÿኊetson UEFI firmware (version 3.1-32827747 built on 2023-03-19T14:56:32+00:00)
e[2Je[04De[=3he[2Je[09D
Jetson UEFI firmware (version 3.1-32827747 built on 2023-03-19T14:56:32+00:00)
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
** WARNING: Test Key is used. **
Error: Could not detect network connection.
e[2Je[01;01HUEFI Interactive Shell v2.2
EDK II
UEFI v2.70 (EDK II, 0x00010000)
e[1me[33me[40mMapping tablee[0me[37me[40m
e[1me[33me[40m FS1:e[0me[37me[40m e[1me[37me[40mAlias(s):e[0me[37me[40mF1:
MemoryMapped(0xB,0x268200000,0x2684A3B67)
e[1me[33me[40m FS0:e[0me[37me[40m e[1me[37me[40mAlias(s):e[0me[37me[40mF0:
Fv(49A79A15-8F69-4BE7-A30C-A172F44ABCE7)
e[1me[33me[40m BLK0:e[0me[37me[40m e[1me[37me[40mAlias(s):e[0me[37me[40m
VenHw(1E5A432C-0466-4D31-B009-D4D9239271D3)/MemoryMapped(0xB,0x1416000
0,0x1417FFFF)/PciRoot(0x0)/Pci(0x0,0x0)/Pci(0x0,0x0)/NVMe(0x1,01-00-00-00-00-00-
00-00)
e[1me[33me[40m BLK1:e[0me[37me[40m e[1me[37me[40mAlias(s):e[0me[37me[40m
00-00)/HD(1,GPT,82C4471A-FAC6-4F3E-A829-4FB9700D1205,0x186F28,0xECF5000)
e[1me[33me[40m BLK7:e[0me[37me[40m e[1me[37me[40mAlias(s):e[0me[37me[40m
00-00)/HD(2,GPT,283DBB4B-BAFA-4168-BB6F-B90689DF7A4C,0x28,0x20000)
e[1me[33me[40m BLK8:e[0me[37me[40m e[1me[37me[40mAlias(s):e[0me[37me[40m
00-00)/HD(3,GPT,1BF84221-CA5A-4F29-AAC4-FD6099C9984A,0x20028,0x380)
e[1me[33me[40m BLK9:e[0me[37me[40m e[1me[37me[40mAlias(s):e[0me[37me[40m
00-00)/HD(4,GPT,19E2A01B-BEBB-4E0C-AA18-B745DEE08B1D,0x203A8,0x10000)
e[1me[33me[40m BLK10:e[0me[37me[40m e[1me[37me[40mAlias(s):e[0me[37me[40m
00-00)/HD(5,GPT,1911DF25-3BA7-4E3F-BF63-F7273BDB5F55,0x303A8,0x20000)
e[1me[33me[40m BLK11:e[0me[37me[40m e[1me[37me[40mAlias(s):e[0me[37me[40m
00-00)/HD(6,GPT,742FB2C1-BCDE-4B02-A011-301B150CCF73,0x503A8,0x380)
e[1me[33me[40m BLK12:e[0me[37me[40m e[1me[37me[40mAlias(s):e[0me[37me[40m
00-00)/HD(7,GPT,293C616A-DCB3-468B-8E02-AE25CD25E10F,0x50728,0x10000)
e[1me[33me[40m BLK13:e[0me[37me[40m e[1me[37me[40mAlias(s):e[0me[37me[40m
00-00)/HD(8,GPT,0764474F-EDE1-48E9-B5CF-047C9F396418,0x60728,0x28000)
e[1me[33me[40m BLK14:e[0me[37me[40m e[1me[37me[40mAlias(s):e[0me[37me[40m
00-00)/HD(9,GPT,74942DCD-8F2A-4941-9DFB-524018E9D11C,0x88728,0x400)
e[1me[33me[40m BLK2:e[0me[37me[40m e[1me[37me[40mAlias(s):e[0me[37me[40m
00-00)/HD(10,GPT,2AAA4A24-6AD8-470C-A1C8-4C69458CA246,0x88B28,0x96000)
e[1me[33me[40m BLK3:e[0me[37me[40m e[1me[37me[40mAlias(s):e[0me[37me[40m
00-00)/HD(11,GPT,66363532-8CCC-4A4A-9E55-3B114DD51800,0x11EB28,0x20000)
e[1me[33me[40m BLK4:e[0me[37me[40m e[1me[37me[40mAlias(s):e[0me[37me[40m
00-00)/HD(12,GPT,18574B87-6E48-46F2-ACB6-A41DAC2A6931,0x13EB28,0x28000)
e[1me[33me[40m BLK5:e[0me[37me[40m e[1me[37me[40mAlias(s):e[0me[37me[40m
00-00)/HD(13,GPT,0531A9F0-19AB-459C-A705-C906B15C6179,0x166B28,0x400)
e[1me[33me[40m BLK6:e[0me[37me[40m e[1me[37me[40mAlias(s):e[0me[37me[40m
00-00)/HD(14,GPT,409ED689-1707-41F9-8768-306DF337DB69,0x166F28,0x20000)
Press e[1me[37me[40mESCe[0me[37me[40m in 5 seconds to skip e[1me[33me[40mstartup.nshe[0me[37me[40m or any other key to continue.e[72DPress e[1me[37me[40mESCe[0me[37me[40m in 4 seconds to skip e[1me[33me[40mstartup.nshe[0me[37me[40m or any other key to continue.e[72DPress e[1me[37me[40mESCe[0me[37me[40m in 3 seconds to skip e[1me[33me[40mstartup.nshe[0me[37me[40m or any other key to continue.e[72DPress e[1me[37me[40mESCe[0me[37me[40m in 2 seconds to skip e[1me[33me[40mstartup.nshe[0me[37me[40m or any other key to continue.e[72DPress e[1me[37me[40mESCe[0me[37me[40m in 1 seconds to skip e[1me[33me[40mstartup.nshe[0me[37me[40m or any other key to continue.
e[1me[33me[40mShell> e[0me[37me[40m
日志我直接复制上来吧,
另外单机备份/还原,就直接使用的如下截图的方式:
