Which part are you having trouble with? I cam see the Omniverse menu item on the top shelf.
When I select “add server”, I get the message “failed to be connected”.
2 things - make sure localhost nucleus server is running. Don’t use the IP address for the server. There’s an issue with UE4 where it won’t accept a “.” in the server name.
Did you get the local sync to work?
I’m sorry. I overlooked your message.
I changed the server name to “localhost” and it connected.
Thank you very much for your help.
@dtyner - the IP Address bug is now fixed, just an FYI.
