Incorrect shadow when light passing a full transparent glass material in rtx-realtime 2.0
isaac sim version 5.1.0
I have a detailed bottle model with a glass body and liquids inside it.
When rendering using rtx-realtime 2.0, the color of the liquids are generally much darker than put it outside the glass body, especially when the light intensity is weak. Putting the liquids backward a single glass plane shows similar results.
Below are the render result of the two render modes with thin walled opened for all glass mesh. The scene consists of a domelight with 500 intensity, a disk light on the far top, and a glass plane in the center of the bottle. The max bounces are all set to 20+
You can see even passing a single plane of glass drops the light radically. Passing through the glass body makes it worse.
Adding lights and increasing light intensity does make rtx2.0”s render results closer to full path tracing. But it’s not applicable because what i need is dark scene. And full path tracing is too costly for me.
Is there any way to fix the shadow in rtx-realtime2.0?
Thanks for the detailed description and screenshots.
This thread discusses a very similar issue with glass making objects behind it appear too dark in RTX renderers and includes some suggested material and rendering tweaks that might help:
Could you take a look and see if any of the suggestions there improve your scene in RTX Realtime 2.0? If not, please share your minimal USD example of your bottle setup so we can investigate further on our side.
Closing due to inactivity. The darkening of objects behind OmniGlass in RTX Realtime 2.0 is a known rendering limitation compared to full path tracing. The linked thread discusses suggested material and rendering tweaks that may help. If those don’t resolve it, feel free to reopen or start a new topic with a
minimal USD scene so the team can investigate further.
