Important: Isaac Sim support
Note: For Isaac Sim support, the community is gradually transitioning from this forum to the Isaac Sim GitHub repository so that questions and issues can be tracked, searched, and resolved more efficiently in one place. Whenever possible, please create a GitHub Discussion or Issue there instead of starting a new forum topic.
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo ( GitHub - isaac-sim/IsaacLab: Unified framework for robot learning with multi-physics/renderer support · GitHub ) following the instructions provided on Isaac Lab’s Contributing Guidelines ( Contribution Guidelines — Isaac Lab Documentation ).
Isaac Sim Version
6.1.0
6.0.1
6.0.0
5.1.0
5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 24.04
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model:
- Driver Version:
Topic Description
Detailed Description
I am facing issue to install Isaac Sim on RTX Spark. The Isaac Sim is able to be opened but black screen on the viewport.
Steps to Reproduce
Open IsaacSim.bat
(Add more steps as needed)
Error Messages
2026-11-07T02:25:08Z [4,247ms] [Error] [carb.graphics-vulkan.plugin] Flags 0x6 must be the same for both device and instance.
[4.568s] [ext: omni.iray.libs-0.0.1] startup
| Driver Version: 621.14 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA RTX Spark N1X (6144-cor.. | Yes: 0 | | 63986 MB | 10de | 7d0a0100.. |
| | | | | | 2e03 | 2fe62aa4.. |
| | | | | | 1 | |
| 1 | Microsoft Direct3D12 (NVIDIA R.. | | | 49132 MB | 10de | 7d0a0100.. |
| | | | | | 2e03 | f85db70a.. |
| | | | | | N/A | |
| OS: Windows 11 Pro, Version: 10.0 (26H1), Build: 28000, Kernel: 10.0.28000.3365
| Processor: NVIDIA RTX Spark N1X (6144-core GPU, 20-core CP
| Cores: 20 | Logical Cores: 20
| Total Memory (MB): 65516 | Free Memory: 53771
| Total Page/Swap (MB): 74732 | Free Page/Swap: 61229
[4.738s] [ext: omni.mdl-57.0.3] startup
[5.212s] [ext: omni.mdl.neuraylib-0.2.20] startup
[5.252s] [ext: omni.kit.usd.mdl-1.1.9] startup
[5.630s] [ext: omni.services.pip_archive-0.18.7] startup
[5.639s] [ext: omni.appwindow-1.2.2] startup
[5.666s] [ext: omni.kit.renderer.core-1.2.2] startup
[5.688s] [ext: omni.kit.renderer.capture-2.0.1] startup
[5.718s] [ext: omni.kit.renderer.imgui-2.0.6] startup
[5.763s] [ext: omni.ui-3.1.3] startup
[5.841s] [ext: omni.kit.mainwindow-1.0.3] startup
[5.858s] [ext: carb.audio-0.1.0] startup
[5.865s] [ext: omni.uiaudio-1.0.0] startup
[5.878s] [ext: omni.kit.uiapp-0.0.0] startup
[5.880s] [ext: omni.usd.schema.metrics.assembler-110.1.0] startup
[5.904s] [ext: omni.usd.schema.audio-0.0.1] startup
[5.935s] [ext: omni.usd_resolver-1.0.0] startup
[5.974s] [ext: omni.usd.core-1.8.3] startup
[5.994s] [ext: omni.metropolis.schema-0.0.3] startup
[6.006s] [ext: isaacsim.anim.robot.schema-0.1.1] startup
[6.023s] [ext: omni.usd.schema.anim-0.0.1] startup
[6.127s] [ext: omni.usd.schema.geospatial-0.0.1] startup
[6.152s] [ext: omni.usd.schema.omnigraph-1.0.1] startup
[6.189s] [ext: omni.usd.schema.semantics-0.0.0] startup
[6.215s] [ext: omni.activity.core-1.0.3] startup
[6.231s] [ext: omni.cubric-0.1.0] startup
[6.237s] [ext: omni.graph.exec-0.9.6] startup
[6.242s] [ext: omni.hydra.scene_delegate-0.3.5] startup
[6.253s] [ext: usdrt.scenegraph-7.6.3] startup
[6.463s] [ext: omni.hydra.usdrt_delegate-7.5.2] startup
[6.502s] [ext: omni.inspect-1.0.2] startup
[6.521s] [ext: omni.kit.actions.core-1.0.0] startup
[6.544s] [ext: omni.kit.audiodeviceenum-1.0.2] startup
[6.562s] [ext: omni.kit.commands-1.5.0] startup
[6.612s] [ext: omni.kit.exec.core-0.13.5] startup
[6.635s] [ext: omni.kit.usd_undo-0.1.8] startup
[6.647s] [ext: omni.kit.window.popup_dialog-2.0.25] startup
[6.694s] [ext: omni.kit.widget.nucleus_connector-2.3.1] startup
[6.740s] [ext: omni.timeline-1.1.0] startup
[6.758s] [ext: omni.usd-1.15.2] startup
[6.985s] [ext: omni.graph.core-3.1.2] startup
[7.008s] [ext: omni.kit.notification_manager-1.0.11] startup
[7.039s] [ext: isaacsim.core.deprecation_manager-0.4.2] startup
[7.062s] [ext: isaacsim.replicator.agent.schema-0.1.1] startup
[7.081s] [ext: isaacsim.robot.schema-6.3.6] startup
[7.159s] [ext: isaacsim.robot_motion.schema-0.2.0] startup
[7.183s] [ext: omni.anim.behavior.schema-110.1.0] startup
[7.214s] [ext: omni.anim.graph.schema-110.1.1] startup
[7.250s] [ext: omni.anim.navigation.schema-110.1.0] startup
[7.279s] [ext: omni.behavior.tree.schema-110.1.0] startup
[7.293s] [ext: omni.isaac.ml_archive-3.3.0] startup
[7.301s] [ext: omni.kit.asset_converter-5.1.4] startup
[7.370s] [ext: omni.pip.cloud-1.5.3] startup
[7.386s] [ext: omni.usd.schema.flow-110.0.0] startup
[7.398s] [ext: omni.usd.schema.mujoco-1.1.0] startup
[7.413s] [ext: omni.usd.schema.newton-1.2.0] startup
[7.431s] [ext: omni.usd.schema.omni_lens_distortion-1.0.0] startup
[7.444s] [ext: omni.usd.schema.omni_projectors-1.0.0] startup
[7.456s] [ext: omni.usd.schema.omni_sensors-0.0.0] startup
[7.491s] [ext: omni.usd.schema.omniscripting-1.0.1] startup
[7.527s] [ext: omni.usd.schema.physical_lighting-0.1.0] startup
[7.554s] [ext: omni.usd.schema.physx-110.1.11] startup
[7.690s] [ext: omni.usd.schema.render_settings.rtx-1.0.2] startup
[7.717s] [ext: omni.usd.schema.scene.visualization-2.0.2] startup
[7.741s] [ext: omni.usd.schema.usd_particle_field-1.0.0] startup
[7.755s] [ext: omni.kit.clipboard-1.1.1] startup
[7.765s] [ext: omni.kit.collaboration.telemetry-1.1.0] startup
[7.781s] [ext: omni.kit.collaboration.channel_manager-1.1.1] startup
[7.814s] [ext: omni.kit.usd.layers-2.6.1] startup
[7.903s] [ext: omni.kit.collaboration.presence_layer-1.2.1] startup
[7.939s] [ext: omni.kit.menu.core-1.2.0] startup
[7.951s] [ext: omni.kit.widget.context_menu-1.4.0] startup
[7.978s] [ext: omni.kit.context_menu-1.9.0] startup
[8.002s] [ext: omni.kit.helper.file_utils-0.1.10] startup
[8.019s] [ext: omni.kit.hotkeys.core-1.3.12] startup
[8.064s] [ext: omni.kit.menu.utils-2.2.3] startup
[8.103s] [ext: omni.kit.widget.nucleus_info-2.0.2] startup
[8.119s] [ext: omni.kit.search_core-1.0.8] startup
[8.135s] [ext: omni.kit.stage_template.core-1.1.22] startup
[8.146s] [ext: omni.kit.widget.path_field-2.0.13] startup
[8.163s] [ext: omni.kit.widget.browser_bar-2.0.10] startup
[8.183s] [ext: omni.kit.widget.filebrowser-2.13.4] startup
[8.264s] [ext: omni.kit.widget.options_menu-1.1.6] startup
[8.309s] [ext: omni.kit.widget.filter-1.1.5] startup
[8.324s] [ext: omni.kit.widget.options_button-1.0.3] startup
[8.337s] [ext: omni.kit.widget.prompt-1.0.7] startup
[8.350s] [ext: omni.kit.widget.search_delegate-1.0.9] startup
[8.370s] [ext: omni.kit.widget.versioning-1.4.11] startup
[8.412s] [ext: omni.ui.scene-2.0.1] startup
[8.453s] [ext: omni.kit.window.filepicker-2.15.5] startup
[8.680s] [ext: omni.kit.widget.live_session_management.ui-1.0.4] startup
[8.748s] [ext: omni.kit.widget.searchable_combobox-1.0.7] startup
[8.765s] [ext: omni.kit.widget.settings-2.0.0] startup
[8.789s] [ext: omni.kit.window.preferences-1.8.3] startup
[8.840s] [ext: omni.kit.widget.live_session_management-1.2.28] startup
[8.885s] [ext: omni.kit.widget.searchfield-1.1.8] startup
[8.906s] [ext: omni.kit.window.file_exporter-1.0.36] startup
[8.931s] [ext: omni.kit.widget.stage-4.3.0] startup
[9.091s] [ext: omni.kit.window.content_browser_registry-0.0.6] startup
[9.107s] [ext: omni.kit.window.drop_support-1.0.8] startup
[9.121s] [ext: omni.kit.window.file_importer-1.1.21] startup
[9.133s] [ext: omni.kit.window.file-2.0.10] startup
[9.173s] [ext: omni.kit.window.content_browser-3.1.8] startup
[9.576s] [ext: omni.kit.widget.layers-1.9.2] startup
[9.708s] [ext: isaacsim.core.version-2.1.0] startup
[9.724s] [ext: isaacsim.app.about-2.3.0] startup
[9.763s] [ext: isaacsim.asset.transformer-1.2.3] startup
[9.801s] [ext: omni.scene.optimizer.core-110.1.0] startup
[9.982s] [ext: isaacsim.asset.importer.utils-1.8.0] startup
[10.020s] [ext: omni.convexdecomposition-110.1.11] startup
[10.038s] [ext: omni.physics-110.1.11] startup
[10.074s] [ext: omni.physx.gpu-110.1.11] startup
[10.080s] [ext: omni.physx.foundation-110.1.11] startup
[10.120s] [ext: omni.usdphysics-110.1.11] startup
[10.135s] [ext: omni.physx.cooking-110.1.11] startup
[10.156s] [ext: omni.physx-110.1.11] startup
[10.223s] [ext: omni.physics.physx-110.1.11] startup
[10.236s] [ext: isaacsim.asset.exporter.urdf-2.0.3] startup
[10.300s] [ext: omni.graph.tools-1.81.0] startup
[10.636s] [ext: omni.graph-1.142.5] startup
[10.912s] [ext: omni.graph.action_core-1.1.9] startup
[10.934s] [ext: omni.hydra.engine.stats-1.0.5] startup
[10.948s] [ext: omni.hydra.rtx.shadercache.vulkan-1.0.0] startup
[10.963s] [ext: omni.index.libs-387500.3473.0] startup
[10.965s] [ext: omni.index-1.0.1] startup
[10.972s] [ext: omni.ujitso.client-0.0.0] startup
[10.976s] [ext: omni.usd.schema.playback-1.0.0] startup
[10.999s] [ext: omni.volume-0.5.2] startup
[11.029s] [ext: omni.hydra.rtx-1.0.3] startup
[11.224s] [ext: omni.kit.hydra_texture-1.6.0] startup
[11.247s] [ext: omni.kit.material.library-3.1.2] startup
[11.330s] [ext: omni.kit.property.adapter.core-1.1.1] startup
[11.356s] [ext: omni.kit.property.adapter.usd-1.0.5] startup
[11.377s] [ext: omni.kit.widget.highlight_label-1.0.3] startup
[11.390s] [ext: omni.kit.window.property-1.15.1] startup
[12.010s] [ext: omni.kit.property.usd-4.8.1] startup
[12.135s] [ext: omni.kit.raycast.query-1.2.0] startup
[12.161s] [ext: omni.kit.viewport.legacy_gizmos-1.0.24] startup
[12.174s] [ext: omni.kit.viewport.registry-104.0.6] startup
[12.187s] [ext: omni.kit.viewport.scene_camera_model-1.0.7] startup
[12.205s] [ext: omni.kit.widget.viewport-109.2.0] startup
[12.257s] [ext: omni.kit.viewport.window-109.0.2] startup
[12.393s] [ext: omni.kit.viewport.utility-2.0.1] startup
[12.403s] [ext: omni.kit.widget.text_editor-1.1.1] startup
[12.419s] [ext: omni.kit.window.extensions-1.5.7] startup
[12.492s] [ext: omni.ui_query-1.1.10] startup
[12.502s] [ext: omni.graph.ui-2.10.3] startup
[12.691s] [ext: omni.graph.action_nodes_core-2.10.2] startup
[12.718s] [ext: omni.graph.action_nodes-2.10.3] startup
[12.822s] [ext: omni.graph.action-2.10.2] startup
[12.830s] [ext: omni.kit.manipulator.viewport-107.0.1] startup
[12.847s] [ext: omni.graph.visualization.nodes-2.1.4] startup
[12.983s] [ext: isaacsim.gui.components-1.8.4] startup
[13.033s] [ext: isaacsim.asset.exporter.urdf.ui-1.0.1] startup
[13.065s] [ext: isaacsim.util.debug_draw-3.2.2] startup
[13.111s] [ext: omni.physics.stageupdate-110.1.11] startup
[13.143s] [ext: isaacsim.asset.gen.omap-2.3.1] startup
[13.204s] [ext: omni.kit.primitive.mesh-1.1.0] startup
[13.262s] [ext: omni.kit.stage_templates-2.0.2] startup
[13.290s] [ext: omni.usd.metrics.assembler-110.1.2] startup
[13.312s] [ext: omni.warp.core-1.13.0] startup
[13.316s] [ext: isaacsim.core.experimental.utils-0.17.1] startup
[13.330s] [ext: isaacsim.asset.gen.omap.ui-2.6.1] startup
[13.371s] [ext: omni.physics.tensors-110.1.11] startup
[13.418s] [ext: omni.physx.tensors-110.1.11] startup
[13.432s] [ext: omni.usdex.libs-2.2.2] startup
[13.479s] [ext: isaacsim.core.simulation_manager-1.15.4] startup
2026-11-07T02:25:17Z [13,368ms] [Warning] [isaacsim.core.simulation_manager.plugin] USD stage is not available; stage-opened subscription is deferred
[13.570s] [ext: isaacsim.test.docstring-1.3.1] startup
[13.645s] [ext: isaacsim.core.experimental.prims-1.8.8] startup
[14.951s] [ext: isaacsim.core.experimental.primdata-0.3.2] startup
[14.968s] [ext: isaacsim.core.experimental.materials-0.7.0] startup
[15.030s] [ext: isaacsim.core.experimental.objects-0.8.0] startup
[15.441s] [ext: isaacsim.asset.importer.heightmap-2.3.3] startup
[15.460s] [ext: isaacsim.asset.transformer.rules-1.7.8] startup
[15.589s] [ext: isaacsim.asset.importer.mjcf-3.10.0] startup
[15.622s] [ext: omni.kit.usd.collect-3.0.5] startup
[15.647s] [ext: omni.kit.usdz_export-1.1.0] startup
[15.672s] [ext: omni.kit.tool.asset_importer-5.2.0] startup
[15.742s] [ext: isaacsim.asset.importer.mjcf.ui-1.4.3] startup
[15.982s] [ext: isaacsim.asset.importer.urdf-3.11.0] startup
[16.028s] [ext: isaacsim.asset.importer.urdf.ui-1.4.2] startup
[16.065s] [ext: isaacsim.asset.transformer.ui-1.1.1] startup
[16.100s] [ext: omni.asset_validator.core-1.19.3] startup
[16.536s] [ext: isaacsim.asset.validation-1.3.5] startup
[16.570s] [ext: isaacsim.storage.native-1.9.2] startup
[16.596s] [ext: omni.debugdraw-0.1.4] startup
[16.617s] [ext: omni.kit.manipulator.selector-1.1.4] startup
[16.638s] [ext: omni.kit.manipulator.transform-107.0.0] startup
[16.702s] [ext: omni.kit.widget.toolbar-2.1.0] startup
[16.797s] [ext: omni.kit.manipulator.tool.snap-1.5.14] startup
[16.855s] [ext: omni.kit.viewport.manipulator.transform-107.0.4] startup
[16.879s] [ext: omni.kit.manipulator.prim.core-108.0.2] startup
[16.950s] [ext: omni.kit.manipulator.prim.usd-107.0.3] startup
[16.969s] [ext: omni.kit.manipulator.prim-108.0.0] startup
[16.970s] [ext: omni.kit.manipulator.selection-109.0.1] startup
[16.988s] [ext: omni.kit.viewport.actions-107.0.2] startup
[17.010s] [ext: omni.kit.window.cursor-1.1.5] startup
[17.021s] [ext: omni.kit.viewport.menubar.core-107.2.2] startup
[17.220s] [ext: omni.kit.viewport.menubar.display-107.1.3] startup
[17.238s] [ext: omni.physx.commands-110.1.11] startup
[17.256s] [ext: omni.usdphysics.ui-110.1.11] startup
[17.346s] [ext: omni.physx.ui-110.1.11] startup
[17.491s] [ext: omni.usd.metrics.assembler.physics-110.1.11] startup
[17.519s] [ext: isaacsim.core.utils-4.1.6] startup
[17.559s] [ext: isaacsim.core.prims-0.11.6] startup
[21.232s] [ext: isaacsim.core.api-5.2.12] startup
[21.274s] [ext: isaacsim.core.cloner-1.7.2] startup
[21.285s] [ext: isaacsim.core.experimental.actuators-0.1.0] startup
[24.538s] [ext: isaacsim.core.rendering_manager-0.4.2] startup
[24.574s] [ext: omni.graph.image.core-0.6.1] startup
[24.584s] [ext: omni.graph.image.nodes-1.3.1] startup
[24.593s] [ext: omni.graph.nodes_core-2.10.3] startup
[24.634s] [ext: omni.graph.nodes-2.11.1] startup
[24.674s] [ext: omni.graph.scriptnode-2.10.2] startup
[24.712s] [ext: omni.syntheticdata-0.6.15] startup
[24.804s] [ext: omni.replicator.nv-1.1.1] startup
[24.824s] [ext: omni.videoencoding-0.2.1] startup
[24.839s] [ext: omni.replicator.core-1.13.25] startup
2026-11-07T02:25:29Z [24,675ms] [Warning] [pxr.Semantics] pxr.Semantics is deprecated - please use Semantics instead
Warp 1.13.0 initialized:
CUDA Toolkit 12.9, Driver 13.5
Devices:
“cpu” : “ARMv8 (64-bit) Family 8 Model D87 Revision 1, NVIDIA”
“cuda:0” : “NVIDIA RTX Spark N1X (6144-core Blackwell RTX GPU)” (110 GiB, sm_121, mempool enabled)
Kernel cache:
\?\C:\Users\darre\AppData\Local\NVIDIA\warp\Cache\1.13.0
2026-11-07T02:25:29Z [24,970ms] [Warning] [omni.replicator.core.scripts.extension] No material configuration file, adding configuration to material settings directly.
[25.549s] [ext: isaacsim.core.nodes-5.10.4] startup
[25.665s] [ext: isaacsim.core.throttling-2.3.3] startup
[25.672s] [ext: isaacsim.robot.surface_gripper-3.6.1] startup
[25.727s] [ext: isaacsim.robot.manipulators-3.4.4] startup
[25.778s] [ext: isaacsim.robot_motion.lula-4.1.2] startup
[25.805s] [ext: isaacsim.robot_motion.motion_generation-8.2.8] startup
[25.832s] [ext: isaacsim.cortex.framework-1.0.17] startup
[25.840s] [ext: isaacsim.cortex.behaviors-2.0.16] startup
[25.846s] [ext: omni.kit.widget.zoombar-1.0.7] startup
[25.851s] [ext: omni.kit.browser.core-2.3.18] startup
[25.868s] [ext: omni.kit.browser.folder.core-2.0.2] startup
[25.887s] [ext: omni.kit.widget.stage_icons-1.0.8] startup
[25.893s] [ext: omni.kit.window.stage-2.6.1] startup
[25.905s] [ext: omni.kit.menu.stage-1.2.7] startup
[25.911s] [ext: omni.kit.tool.collect-2.2.19] startup
[25.920s] [ext: isaacsim.examples.browser-0.3.1] startup
[25.931s] [ext: isaacsim.cortex.examples-0.2.3] startup
[25.962s] [ext: isaacsim.examples.base-1.3.1] startup
[25.968s] [ext: isaacsim.examples.extension-2.3.0] startup
[25.979s] [ext: isaacsim.robot_motion.experimental.motion_generation-6.1.2] startup
[26.013s] [ext: isaacsim.robot_motion.cumotion-1.3.0] startup
[26.062s] [ext: isaacsim.robot.experimental.manipulators.examples-0.2.0] startup
[26.114s] [ext: isaacsim.robot.experimental.wheeled_robots-0.2.9] startup
[26.177s] [ext: isaacsim.robot.wheeled_robots.nodes-0.1.2] startup
[26.270s] [ext: isaacsim.examples.interactive-4.16.0] startup
[26.308s] [ext: omni.kit.search.files-1.0.4] startup
[26.314s] [ext: omni.kit.widget.calendar-1.0.9] startup
[26.321s] [ext: omni.kit.widget.extended_searchfield-1.0.31] startup
[26.349s] [ext: omni.simready.content.browser-0.3.7] startup
[26.941s] [ext: isaacsim.gui.content_browser-0.4.2] startup
[26.951s] [ext: omni.kit.selection-0.1.6] startup
[26.957s] [ext: isaacsim.gui.menu-2.10.5] startup
[26.981s] [ext: isaacsim.gui.property-1.6.2] startup
[26.999s] [ext: isaacsim.gui.sensors.icon-2.2.0] startup
[27.011s] [ext: omni.behavior.scripting.core-110.1.0] startup
[27.022s] [ext: isaacsim.replicator.behavior-1.5.3] startup
[27.026s] [ext: isaacsim.replicator.experimental.domain_randomization-1.2.4] startup
[27.089s] [ext: isaacsim.replicator.domain_randomization-1.2.1] startup
[27.234s] [ext: isaacsim.replicator.writers-1.5.3] startup
[27.323s] [ext: isaacsim.robot.policy.examples-5.2.11] startup
[27.385s] [ext: isaacsim.robot.wheeled_robots-5.2.3] startup
[27.395s] [ext: omni.kit.numpy.common-0.1.3] startup
[27.402s] [ext: isaacsim.sensors.camera-1.7.8] startup
[27.463s] [ext: isaacsim.sensors.experimental.physics-3.0.1] startup
[27.494s] [ext: omni.sensors.net-1.0.1] startup
[27.528s] [ext: omni.sensors.nv.common-3.0.0] startup
[27.664s] [ext: omni.sensors.nv.materials-2.0.0] startup
[27.700s] [ext: omni.sensors.nv.acoustic-3.0.0] startup
[27.725s] [ext: omni.sensors.nv.ids-2.0.1] startup
[27.738s] [ext: omni.sensors.nv.lidar-3.0.0] startup
[27.764s] [ext: omni.sensors.nv.radar-3.0.0] startup
[27.790s] [ext: isaacsim.sensors.experimental.rtx-1.4.3] startup
[28.212s] [ext: isaacsim.sensors.physics.nodes-1.5.2] startup
[28.240s] [ext: isaacsim.sensors.physx-2.5.4] startup
[28.271s] [ext: isaacsim.sensors.rtx-15.17.0] startup
[28.307s] [ext: isaacsim.simulation_app-2.18.3] startup
[28.313s] [ext: omni.anim.curve.core-1.6.0] startup
[28.352s] [ext: omni.graph.ui_nodes-2.10.5] startup
[28.445s] [ext: omni.hydra.scene_api-0.1.3] startup
[28.458s] [ext: omni.kit.manipulator.camera-110.0.0] startup
[28.471s] [ext: omni.kit.menu.create-2.0.2] startup
[28.477s] [ext: omni.kit.property.audio-1.0.16] startup
[28.484s] [ext: omni.kit.property.camera-1.0.14] startup
[28.490s] [ext: omni.kit.property.geometry-2.1.2] startup
[28.500s] [ext: omni.kit.property.light-1.0.14] startup
2026-11-07T02:25:32Z [28,327ms] [Warning] [omni.usd] Encountered USD Warnings but USD Diagnostics are currently muted. To view USD Warnings, please set the ‘/persistent/app/usd/muteUsdDiagnostics’ setting to false in Preferences page.
[28.538s] [ext: omni.kit.widget.imageview-1.0.5] startup
[28.542s] [ext: omni.kit.window.quicksearch-2.4.4] startup
[28.553s] [ext: omni.kit.property.material-1.14.2] startup
[28.577s] [ext: omni.kit.property.render-1.2.2] startup
[28.582s] [ext: omni.kit.property.transform-1.6.9] startup
[28.592s] [ext: omni.kit.property.bundle-1.5.1] startup
[28.599s] [ext: omni.kit.ui.actions-1.0.5] startup
[28.605s] [ext: omni.kit.viewport.menubar.camera-107.0.10] startup
[28.622s] [ext: omni.kit.viewport.menubar.lighting-107.3.2] startup
[28.631s] [ext: omni.kit.viewport.menubar.render-107.0.10] startup
[28.640s] [ext: omni.kit.viewport.menubar.settings-110.0.1] startup
[28.653s] [ext: omni.kit.window.console-1.1.8] startup
[28.671s] [ext: omni.kit.window.status_bar-0.1.11] startup
[28.680s] [ext: omni.kit.window.toolbar-3.0.3] startup
[28.690s] [ext: omni.ocio-0.1.1] startup
[28.698s] [ext: omni.replicator.replicator_yaml-2.0.12] startup
[28.745s] [ext: omni.rtx.window.settings-0.8.0] startup
[28.767s] [ext: omni.rtx.settings.core-0.7.0] startup
[28.781s] [ext: omni.usd.metrics.assembler.ui-110.1.1] startup
[28.801s] [ext: semantics.schema.editor-2.0.2] startup
[28.812s] [ext: semantics.schema.property-2.0.1] startup
[28.821s] [ext: omni.kit.menu.common-2.0.2] startup
[28.827s] [ext: isaacsim.exp.base-6.0.0] startup
[28.829s] [ext: isaacsim.replicator.behavior.ui-1.2.0] startup
[28.836s] [ext: isaacsim.replicator.episode_recorder-0.1.3] startup
[28.867s] [ext: isaacsim.replicator.episode_recorder.ui-0.1.2] startup
[28.879s] [ext: isaacsim.replicator.grasping-1.1.4] startup
[29.508s] [ext: isaacsim.replicator.grasping.ui-1.1.3] startup
[29.518s] [ext: isaacsim.replicator.synthetic_recorder-2.4.3] startup
[29.527s] [ext: isaacsim.robot.manipulators.examples-2.0.0] startup
[29.534s] [ext: isaacsim.robot.manipulators.ui-2.2.1] startup
[29.541s] [ext: isaacsim.robot.poser-1.1.2] startup
[29.554s] [ext: isaacsim.robot.poser.ui-1.1.1] startup
[29.570s] [ext: isaacsim.robot.schema.ui-0.3.4] startup
[29.594s] [ext: isaacsim.robot.surface_gripper.ui-3.1.4] startup
[29.603s] [ext: isaacsim.robot.wheeled_robots.ui-2.3.1] startup
[29.611s] [ext: isaacsim.robot_setup.assembler-3.3.2] startup
[29.626s] [ext: isaacsim.robot_setup.collision_detector-0.2.1] startup
[29.636s] [ext: isaacsim.robot_setup.gain_tuner-3.5.2] startup
[29.660s] [ext: isaacsim.robot_setup.grasp_editor-2.3.2] startup
[29.670s] [ext: isaacsim.robot_setup.xrdf_editor-3.6.1] startup
[29.692s] [ext: isaacsim.sensors.camera.ui-0.7.1] startup
[29.699s] [ext: isaacsim.sensors.physics.examples-1.2.3] startup
[29.718s] [ext: isaacsim.sensors.physics.ui-1.2.2] startup
[29.724s] [ext: isaacsim.sensors.physx.examples-2.4.3] startup
[29.739s] [ext: isaacsim.sensors.physx.ui-2.5.1] startup
[29.746s] [ext: isaacsim.sensors.rtx.ui-1.5.0] startup
[29.753s] [ext: isaacsim.util.camera_inspector-1.2.1] startup
[29.760s] [ext: isaacsim.util.physics-1.2.1] startup
[29.772s] [ext: omni.anim.asset-110.1.0] startup
[29.788s] [ext: omni.anim.navigation.core-110.1.4] startup
[29.824s] [ext: omni.anim.retarget.core-110.1.0] startup
[29.846s] [ext: omni.kit.mesh.raycast-110.0.0] startup
[29.861s] [ext: omni.anim.behavior.core-110.1.4] startup
[29.894s] [ext: omni.behavior.tree.core-110.1.9] startup
[29.940s] [ext: omni.anim.behavior.tree-110.1.3] startup
[29.962s] [ext: omni.kit.browser.sample-1.4.9] startup
[29.968s] [ext: omni.anim.behavior.ui-110.1.3] startup
[30.014s] [ext: omni.anim.behavior.bundle-110.1.0] startup
[30.019s] [ext: omni.anim.curve.ui-1.7.0] startup
[30.029s] [ext: omni.anim.curve.bundle-1.4.0] startup
[30.031s] [ext: omni.anim.graph.core-110.1.2] startup
2026-11-07T02:25:34Z [29,891ms] [Warning] [omni.graph.core._impl._registration.register_python_ogn] Python import process in omni.anim.graph.core failed - ‘NoneType’ object is not subscriptable. Aborting Python node registration
[30.087s] [ext: omni.curve.creator-110.0.0] startup
[30.099s] [ext: omni.scene.visualization.core-110.0.0] startup
[30.130s] [ext: omni.curve.manipulator-110.0.0] startup
[30.172s] [ext: omni.ramp-110.0.0] startup
[30.185s] [ext: omni.genproc.core-110.0.0] startup
[30.226s] [ext: omni.graph.bundle.action-3.10.2] startup
[30.234s] [ext: omni.kit.widget.graph-2.1.0] startup
[30.250s] [ext: omni.kit.graph.delegate.default-1.2.5] startup
[30.255s] [ext: omni.kit.graph.delegate.modern-1.10.15] startup
[30.262s] [ext: omni.kit.graph.editor.core-1.5.8] startup
[30.274s] [ext: omni.kit.graph.widget.variables-2.1.1] startup
[30.280s] [ext: omni.anim.graph.ui-110.1.2] startup
[30.313s] [ext: omni.anim.graph.bundle-110.1.1] startup
[30.319s] [ext: omni.anim.navigation.ui-110.1.1] startup
[30.335s] [ext: omni.anim.navigation.bundle-110.1.0] startup
[30.340s] [ext: omni.kit.property.skel-1.1.4] startup
[30.348s] [ext: omni.anim.skelJoint-110.1.0] startup
[30.373s] [ext: omni.kit.preferences.animation-1.5.0] startup
[30.384s] [ext: omni.anim.widget.timeline-0.4.0] startup
[30.407s] [ext: omni.anim.retarget.preview-110.1.0] startup
context created: omni.anim.retarget.preview-110.1.0 Preview Context 1
[30.468s] [ext: omni.anim.retarget.ui-110.1.0] startup
[30.489s] [ext: omni.anim.retarget.bundle-110.1.0] startup
[30.494s] [ext: omni.anim.shared.core-110.0.0] startup
[30.550s] [ext: omni.behavior.scripting.ui-110.1.0] startup
[30.560s] [ext: omni.behavior.scripting.bundle-110.1.0] startup
[30.562s] [ext: omni.kit.quicklayout-1.0.12] startup
[30.567s] [ext: omni.kit.window.title-1.1.8] startup
[30.571s] [ext: omni.behavior.tree.ui-110.1.12] startup
[30.635s] [ext: omni.behavior.tree.bundle-110.1.0] startup
[30.640s] [ext: omni.kit.graph.usd.commands-1.3.6] startup
[30.644s] [ext: omni.graph.window.core-3.10.4] startup
[30.673s] [ext: omni.graph.window.action-2.10.2] startup
[30.685s] [ext: omni.graph.window.generic-2.10.2] startup
[30.698s] [ext: omni.importer.onshape-2.0.3] startup
[30.723s] [ext: omni.kit.actions.window-1.1.3] startup
[30.740s] [ext: omni.kit.browser.asset-1.3.16] startup
[30.750s] [ext: omni.kit.browser.material-1.6.5] startup
[30.763s] [ext: omni.kit.converter.common-510.1.3] startup
[30.776s] [ext: omni.services.facilities.base-1.0.5] startup
[30.781s] [ext: omni.services.core-1.10.0] startup
[31.248s] [ext: omni.services.transport.client.base-1.2.5] startup
[31.256s] [ext: omni.services.client-0.5.6] startup
[31.265s] [ext: omni.services.facilities.monitoring.progress-0.2.4] startup
[31.278s] [ext: omni.services.transport.client.http_async-1.4.2] startup
[31.284s] [ext: omni.services.transport.server.base-1.1.2] startup
[31.288s] [ext: omni.services.transport.server.http-1.3.2] startup
[31.399s] [ext: omni.services.convert.cad-508.0.3] startup
[31.426s] [ext: omni.kit.converter.dgn_core-512.3.0] startup
[31.500s] [ext: omni.kit.converter.dgn-510.1.4] startup
[31.515s] [ext: omni.kit.converter.gsplat-0.1.14] startup
[31.531s] [ext: omni.kit.converter.hoops_core-511.3.0] startup
[31.603s] [ext: omni.kit.converter.hoops-510.3.0] startup
[31.618s] [ext: omni.kit.converter.jt_core-510.1.0] startup
[31.715s] [ext: omni.kit.converter.jt-509.1.2] startup
[31.724s] [ext: omni.kit.core.collection-0.2.4] startup
[31.730s] [ext: omni.kit.hotkeys.window-1.4.10] startup
[31.754s] [ext: omni.kit.property.collection-0.2.4] startup
[31.761s] [ext: omni.kit.property.layer-1.2.6] startup
[31.772s] [ext: omni.kit.property.physics-110.1.11] startup
[31.815s] [ext: omni.kit.stage.copypaste-1.2.4] startup
[31.826s] [ext: omni.mdl.usd_converter-1.0.38] startup
[31.836s] [ext: omni.kit.stage.mdl_converter-1.0.8] startup
[31.842s] [ext: omni.kit.stage_column.payload-2.0.5] startup
[31.852s] [ext: omni.kit.stage_column.variant-1.0.20] startup
[31.883s] [ext: omni.kit.stagerecorder.core-110.0.9] startup
[31.910s] [ext: omni.kit.stagerecorder.ui-110.0.0] startup
[31.928s] [ext: omni.kit.stagerecorder.bundle-110.0.0] startup
[31.930s] [ext: omni.kit.tool.asset_exporter-4.0.7] startup
[31.941s] [ext: omni.kit.tool.remove_unused.core-0.1.4] startup
[31.947s] [ext: omni.kit.widget.material_preview-1.1.3] startup
[31.960s] [ext: omni.kit.window.material_graph-2.2.0] startup
[32.342s] [ext: omni.kit.window.material-1.8.0] startup
[32.360s] [ext: omni.kit.tool.remove_unused.controller-0.2.0] startup
[32.367s] [ext: omni.kit.ui_test-1.4.4] startup
[32.374s] [ext: omni.kit.usda_edit-1.1.19] startup
[32.389s] [ext: omni.kit.widgets.custom-1.1.2] startup
[32.411s] [ext: omni.kit.variant.editor-107.5.8] startup
[32.440s] [ext: omni.kit.variant.presenter-107.1.3] startup
[32.451s] [ext: omni.kit.viewport.bundle-107.0.0] startup
[32.453s] [ext: omni.kit.viewport.rtx-107.0.0] startup
[32.455s] [ext: omni.kit.viewport_widgets_manager-1.0.9] startup
[32.462s] [ext: omni.kit.widget.live-2.1.12] startup
[32.469s] [ext: omni.kit.widget.cache_indicator-3.0.12] startup
2026-11-07T02:25:37Z [32,424ms] [Warning] [omni.kit.widget.cache_indicator.cache_state_menu] Unable to detect Omniverse Cache Server. File C:/Users/darre/.nvidia-omniverse/config/omniverse.toml is not found. Consider installing it for better IO performance.
[32.621s] [ext: omni.kit.widget.collection-0.3.3] startup
[32.631s] [ext: omni.kit.widget.timeline-107.0.2] startup
[32.641s] [ext: omni.kit.window.collection-0.3.5] startup
[32.649s] [ext: omni.kit.window.commands-0.2.9] startup
[32.656s] [ext: omni.kit.window.script_editor-2.0.7] startup
[32.666s] [ext: omni.kit.window.usd_paths-1.0.9] startup
[32.671s] [ext: omni.physics.isaacsimready-110.1.11] startup
[32.685s] [ext: omni.physics.physx.ui-110.1.11] startup
[32.740s] [ext: omni.physics.ui-110.1.11] startup
[32.751s] [ext: omni.asset_validator.ui-1.19.3] startup
[32.799s] [ext: omni.physx.asset_validator-110.1.11] startup
[32.843s] [ext: omni.physx.demos-110.1.11] startup
[32.905s] [ext: omni.physx.vehicle-110.1.11] startup
[32.955s] [ext: omni.physx.camera-110.1.11] startup
[32.983s] [ext: omni.physx.cct-110.1.11] startup
[33.074s] [ext: omni.physx.graph-110.1.11] startup
[33.219s] [ext: omni.physx.supportui-110.1.11] startup
[33.255s] [ext: omni.physx.bundle-110.1.11] startup
[33.258s] [ext: omni.resourcemonitor-107.1.1] startup
[33.273s] [ext: omni.services.facilities.monitoring.metrics-0.3.1] startup
[33.307s] [ext: omni.services.convert.asset-510.0.2] startup
[33.330s] [ext: omni.simready.explorer-1.1.4] startup
[33.350s] [ext: omni.kit.converter.cad-209.4.0] startup
[33.352s] [ext: isaacsim.app.setup-1.12.0] startup
[33.358s] Isaac Sim Full Version: 6.0.0-rc.59
[33.363s] [ext: omni.kit.window.stats-0.1.8] startup
[33.369s] [ext: omni.kit.profiler.window-2.5.0] startup
[33.386s] [ext: isaacsim.exp.full-6.0.0] startup
Warning: Possible version incompatibility. Attempting to load omni::fabric::IStageReaderWriter with version v0.16 against v0.14.
Warning: Possible version incompatibility. Attempting to load omni::fabric::IStageReaderWriter with version v0.16 against v0.15.
2026-11-07T02:25:39Z [35,230ms] [Error] [omni.rtx] Raytracing is not supported on GPU: 0. Hardware, driver or Operating system upgrade is required.
2026-11-07T02:25:39Z [35,231ms] [Error] [carb.scenerenderer-rtx.plugin] rtx driver verification failed.
2026-11-07T02:25:39Z [35,235ms] [Warning] [omni.hydra.rtx] HydraEngine rtx failed creating scene renderer.
2026-11-07T02:25:39Z [35,235ms] [Warning] [omni.usd] UsdManager::initializeHydraEngineInstance - unable to create shared hydra engine context for engine: uid: 1024 type: rtx flags: 0 tickRateInHz: 0 deviceMask: 1 creationIndex: 0
2026-11-07T02:25:39Z [35,236ms] [Warning] [omni.usd] UsdManager::addHydraEngineWithConfiguration - Invalid sync scope created. Failed to add Hydra engine: uid: 1024 type: rtx flags: 0 tickRateInHz: 0 deviceMask: 0 creationIndex: 0
2026-11-07T02:25:51Z [46,816ms] [Warning] [omni.kit.material.library.material_library] get_mdl_list_async: mdl_list_cache is not complete
2026-11-07T02:25:51Z [46,817ms] [Warning] [omni.kit.material.library.material_library] get_mdl_list: mdl_list_cache is not complete
2026-11-07T02:25:51Z [46,818ms] [Warning] [omni.kit.material.library.material_library] get_mdl_list_async: mdl_list_cache is not complete
2026-11-07T02:25:51Z [46,819ms] [Warning] [isaacsim.asset.transformer.rules.utils] omni.kit.material.library.get_mdl_list_async returned no ${kit}/${app} entries; using hardcoded built-in MDL list (15 basename(s)).
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
(Describe any troubleshooting steps you’ve already taken)
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here)
