Issue: ros2_control_node Segfault in Isaac Manipulator Pose-to-Pose Workflow (Jazzy + Isaac Sim)
Hi NVIDIA team,
I’m running the Isaac for Manipulation Pose-to-Pose tutorial exactly as documented, with no modifications:
  1. Setup guide:
    https://nvidia-isaac-ros.github.io/reference_workflows/isaac_for_manipulation/tutorials/setup/setup_guide_isaac_sim.html
  2. Pose-to-Pose workflow:
    https://nvidia-isaac-ros.github.io/reference_workflows/isaac_for_manipulation/tutorials/isaac_sim/tutorial_isaac_sim_pose_to_pose.html
The workflow consistently fails with a segmentation fault in ros2_control_node during launch.
Environment
  • OS: Ubuntu 24.04 (Noble)
  • ROS 2: Jazzy (apt install)
  • Isaac ROS: Version 4.0 built in docker via isaac-ros-cli
  • Isaac Manipulator: Built from source inside docker container following the tutorial
  • Isaac Sim Version: 5.1.0
  • Host Machine Python Version: 3.12
Workspace built using:
export MANIPULATOR_INSTALL_ASSETS=1
colcon build --symlink-install --packages-up-to isaac_manipulator_bringup
Steps to Reproduce
  1. Launch Isaac Sim, load the provided scene, press Play.
  2. In terminal:
isaac-ros activate
cd /workspaces/isaac_ros-dev
source install/setup.bash
export RMW_IMPLEMENTATION=rmw_cyclonedds_cpp
  1. Run the pose-to-pose workflow:
ros2 launch isaac_manipulator_bringup workflows.launch.py \
  manipulator_workflow_config:=$(ros2 pkg prefix --share isaac_manipulator_bringup)/params/sim_launch_params.yaml
Observed Behavior
ros2_control_node immediately crashes:
[ERROR] [ros2_control_node-7]: process has died [exit code -11]
Segmentation fault (Address not mapped to object)
hardware_interface::ResourceManager::load_and_initialize_components(...)
After this, the entire launch is torn down (move_group, spawners, gripper driver, etc.).
This happens every time, even with a clean rebuild and no modifications to NVIDIA configs.
Troubleshooting Already Tried
  • Removed system robotiq_description and robotiq_controllers Debian packages to avoid overlay conflicts
  • Clean rebuild: rm -rf build install log
  • Rebuilt manipulator with assets:
    export MANIPULATOR_INSTALL_ASSETS=1 && colcon build
  • Verified CycloneDDS is being used
  • Verified Isaac Sim ROS bridge is active and joint states are being published
  • Confirmed no local modifications to launch files or configs
  • Followed the tutorial steps exactly on a fresh setup
The crash remains identical.
Request for NVIDIA Support
Could you help clarify:
  1. Is this a known issue with ROS 2 Jazzy + ros2_control in the Manipulator workflow?
  2. Are there additional patches or steps required to run Manipulator on Jazzy/24.04?
Happy to provide:
  • Full logs
  • Container info
  • Isaac Sim version
  • Stack trace
  • Console output
Thank you!
Hi, this is not a known issue; the workflow has been tested and shown to work on 24.04 / Jazzy. There shouldn’t be any additional steps or patches required. Here are two things to try:
  1. Run the launch with --ros-args --log-level debug and capture the full ros2_control_node backtrace from coredumpctl or gdb, so we can see which plugin crashes.
  2. If possible, try the same tutorial inside the officially documented Isaac ROS Manipulation container; if it works there but not natively on Jazzy, we can treat this as a Jazzy‑specific compatibility issue to reproduce.
