Hi all,
I, too, and having similar problems with the Jetson TX2 Development Kit. When I first received it, applying 14.5Vdc to the barrel connector only lighted LED CR5 (VDD_IN), as expected, but the unit wouldn’t respond to the standard Force Recovery button turn-on sequence (off / push Force Recovery button / power on / with FR button pushed, momentarily press On button / release On button / release FR button). I mention the Force Recovery sequence in case someone spots a significant error.
Anyhow, after MANY MANY trials of doing this, and also trying other combinations (involving Reset button), one time the unit turned on! Namely, green LEDs CR1 (SOC Enabled) & CR2 (Power), and red LED CR6, all turned on. During this period I was able to flash the OS successfully (JetPack 4.4.1, I think) using SDKManager on my other Linux computer.
Subsequently, the unit turned on normally (i.e., with only a press of the Power On button) for several instances over the next few days, and I began to setup my Ubuntu desktop preferences. HOWEVER, yesterday the DevKit refused to turn on again , with behavior now having only CR5 lit when power is applied, with no other response (other than the PCIE/SATA red LED CR6 briefly flashing every time Power On button is pressed). The only thing I can imagine that happened is that perhaps there’s a problem with ESD protection as I plugged in the nominal 12V external power into the barrel connector (??). I have downloaded the DevKit schematics, but as of now have not figured out a possible culprit for why the unit ceased to turn on, especially since it worked flawlessly for several days.
I really don’t know what to do at this point. Please help! I invested a bit of $ into providing the DevKit with a mini-ITX case and a SATA SSD, and planned on making this my main Linux computer, so it would be great to find out how to fix this!!
Thanks very much for anyone’s insight.
Regards,
Andy
