Hello!
I have an issue importing certain edited point clouds into Create. I have no idea what causes this and it’s quite a hinderance to my work when it happens. It seems the point cloud imports successfully but Create crashes upon rendering. It’s possible to see the point cloud for a brief moment before this error is displayed.
The phrase ‘success has failed’ is rather amusing though.
Here is my ….nvidia-omniverse\logs\kit folder
Kit.zip (529.3 KB)
The last two lines of the log are:
2022-03-23 18:23:00 [516,301ms] [Warning] [carb.flowusd.plugin] Maximum Flow blocks of 32768 in use, either reduce cell size or increase max blocks.
2022-03-23 18:27:02 [758,748ms] [Error] [carb.input.plugin] Subscriber 7 not found
That first warning is normal and it just means the default memory ‘blocks’ setting is too low - after import I turn it up ~16x
As for the second - At first I thought ‘subscriber’ meant one of my GPUs wasn’t responding but that doesn’t seem to be the case.
Please let me know what causes this error and how I might avoid it in the future.
Thank you!
-Matthew
