Hi everyone,
I’m using isaac sim 2022.2.1 with foxy
i’m following this tutorial-> 7.2.8. ROS2 Navigation — Omniverse IsaacSim latest documentation
I’m trying to run the following command
ros2 launch carter_navigation carter_navigation.launch.py
keep getting this error:
Package 'carter_navigation' not found: "package 'carter_navigation' not found, searching: ['/.local/share/ov/pkg/isaac_sim-2022.2.1/ros2_workspace/install/isaac_ros_test', '/opt/ros/foxy']"
what am I doing wrong?
in which folder should that command be run?
rchadha
December 15, 2023, 10:36am
3
hi @alexander.aasmann , the package you are running (carter_navigation) cannot be found by ROS. Please make sure you build the ROS 2 workspace containing the package and source it before attempting to run it.
Follow the instructions here
hi @rchadha . Thank you for the reply. I don’t seem to be able to access the page in the link
Hi @alexander.aasmann , apologies for the incorrect link please try this updated one
Hi, I followed this tutorial and it didn’t work. I had to source ros twice for it to work.
source ros2_workspace/install/local_setup.bash
source /opt/ros/foxy/setup.bash
any ideas why that’s the case?
Hi @alexander.aasmann , can you please elaborate on what did not work? A log/repro steps would be appreciated!
Sure, I followed all the steps from the tutorial, when i got to the point i which i was suppose to run the line,
i gave me the error mentioned on the initial question.
but running both commands before ros2 launch carter_navigation carter_navigation.launch.py solved my problem
1. source ros2_workspace/install/local_setup.bash
2. source /opt/ros/foxy/setup.bash
now it works
