ROS 2 installation on Ubuntu 24.04 (noble)
Could you kindly let me know, will it work if I install ROS 2 on Ubuntu 24.04 (Noble), while following link below?
https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/Isaac/Documentation/Isaac-Sim-Docs_2022.2.1/isaacsim/latest/install_ros.html
Did it work?
This document indicates that ROS 2 Humble binary packages supports only Ubuntu 22.
https://docs.ros.org/en/iron/Releases/Release-Humble-Hawksbill.html
So I think you cannot install ROS 2 Humble binary packages.
If you would like to use ROS 2 Humble with Ubuntu 24, you should try to install from source code.
But Ubuntu 24 is not supported by Isaac Sim 4.1.0.
Please refer the latest documentation.
https://docs.omniverse.nvidia.com/isaacsim/latest/installation/install_ros.html#ros-and-ros-2-installation
Another approach is to use docker.
I’m using official docker image with Ubuntu 24.
https://docs.omniverse.nvidia.com/isaacsim/latest/installation/install_container.html
